Old 10-01-2012, 04:58 PM   #61
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
Originally Posted by itinerant View Post
Is POR-15 that much better than Kreem?
I've used POR15 before and was very happy with the results. I've since sold the bike to a friend, but it's still good after 5 years. I've never personally used the kreem stuff before, but I've seen some pretty horrific results with the stuff. It goes on very thick apparently doesn't stick that well as I've seen 3 bikes with failing kreem jobs in person. That and it seems like on the internet there are far more people saying bad things about it than good. I've just stayed away from it. Go check out this thread:
http://www.advrider.com/forums/showthread.php?t=732099
Apparently POR15 makes a stripper for removing kreem.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 10-01-2012 at 05:04 PM
Old 10-01-2012, 05:07 PM   #62
itinerant OP
itinerant's Avatar
Oddometer: 70
Ha, funny. I just found it: http://www.por15.com/HD-CYCLE-TANK-R...ctinfo/HDCTRK/
I think that's what I'll go with. The Kreem kits have sat in the basement for a few years - what's a few years more?
itinerant is offline   Reply With Quote
Old 10-01-2012, 06:27 PM   #63
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Another big thumbs up for the POR15.
Kreem has no staying power, witnessed more than once by me and others.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 10-01-2012, 06:30 PM   #64
supershaft
because I can
Oddometer: 9,116
I have seen at least ten Kream disasters over the years. I bet it is closer to twenty.
Old 10-02-2012, 12:16 AM   #65
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,690
By the way, that battery is a pain to get in and out - but once I removed the rear fender, it was a breeze.
Removing the shock from the top mount and swinging it back should give you enough clearance for battery removal / replacement.
There will be a next time for sure.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 10-02-2012, 06:36 AM   #66
itinerant OP
itinerant's Avatar
Oddometer: 70
Float pin
Any tips on how to get the carburetor float pin out? I haven't tried really gronking on it yet, but it seems to have no interest whatsoever in coming out.
Old 10-02-2012, 08:14 AM   #67
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
try going in the other direction. the pin is pointy on one end and larger on the other. make sure you punch is the right size, it takes a really small one.
www.wirewerkes.com
Old 10-02-2012, 03:02 PM   #68
itinerant OP
itinerant's Avatar
Oddometer: 70
Carbs
Well, I got totally stymied by the weather today. I'm working on the street, because my only garage space is over in Jersey, and I don't relish driving back and forth every time I want to work on the bike. Anyway, I got the carbs off, apart, and started soaking all the jets. The left idle jet was definitely clogged, so I'm thinking that was the reason only the right cylinder was firing. There was some pretty nasty fuel and water in the bottoms of the bowls, so I'm glad I did it.
There's horrible looking fuel coming from the petcock on the reserve setting, but it's nice and clean on the "on" setting. I ordered the POR-15 kit yesterday. I figure once I get the carbs back together I'll either wait for the kit, or just try running the bike without using the reserve, and just wait for the kit before I try to ride it.
I also fed some new fuel line through the airbox, all ready to be attached once the carbs are back together. I'm hoping the rain will hold out long enough tomorrow morning for me to get everything back together and (I hope) running. Then it's off to Jersey to pick up new strut mounts for the truck (and new Bosch plugs!).
I took some photos. I think carburetors are kind of beautiful objects.
Old 10-02-2012, 08:05 PM   #69
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,843
Your comment about the crappy fuel on "reserve".... I work with boat fuel tanks, and it immediately brought to mind the thought that the crud/crap sinks to the bottom (reachable by the reserve straw), while the "good" fuel floats on top. I would immediately pull the petcock and just let all the sheeit out of the tank, for beginners... then worry about the rest of it! All it takes is a little of that crap to really muck up the jets on the carb......
....Otherwise you are just going to be fishing the guck out of the float bowls every time the bike sloshes a little crap up as high as the longer "regular" straw top.....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 10-02-2012, 08:14 PM   #70
itinerant OP
itinerant's Avatar
Oddometer: 70
Yep, I think you're absolutely right.I'll drain the tank and flush it out tomorrow, then re-line it once I get my kit. Thanks.
Old 10-02-2012, 09:19 PM   #71
squish
Out of the office.
Oddometer: 6,318
The stock liner on theses tanks was a red colored finish, when it starts to go, it makes everything looks nasty that come out.
Regardless of what tank liner (if you chose to use one) prep prep prep is the key to making the system work.
I've not seen very many Por-15'd bikes, but every single Kreem tank I've seen has been bad.
On vacation for a spell
squish is offline   Reply With Quote
Old 10-02-2012, 11:08 PM   #72
Prutser
Prutser's Avatar
Oddometer: 1,021
The choke spring is mounted up-side down.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 10-03-2012, 05:25 AM   #73
itinerant OP
itinerant's Avatar
Oddometer: 70
Ha, thanks. I'm so careful about putting things back together the way they were when I found them - I don't always make sure that they were correct when I found them.
Let's close the discussion about POR-15 vs Kreem. I ordered the POR-15 kit, it should be here in a few days. I'll prep the tank carefully. Thanks again for all the insight!
Old 10-03-2012, 10:50 AM   #74
itinerant OP
itinerant's Avatar
Oddometer: 70
Hot diggity.
Well, this morning I buttoned up the carbs, replaced the fuel line, flushed out the tank, and fired 'er up. Lovely. I ran it for about 5 minutes at 1500 - 2000 rpm. Seems to be running quite nicely. There was a ton of smoke, mostly coming from the collector pipe, which seems to be fairly well coated in road grime. The clutch lever that comes out of the back of the transmission is prutty greasy too - there must be a seal there that's starting to go. Anyway, I'm assuming that the smoke was just that crap burning off. Figure I'll spray some S100 on it once it cools off. I took a little vid:
https://vimeo.com/50703009
So what do you all think? I'm feeling ready to change the final drive oil and have a little ride around the block and see how everything feels. So far I've replaced the engine oil and gearbox oil. Anything else I should absolutely replace/take care of before trying a little spin around the block?
Old 10-03-2012, 11:09 AM   #75
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,997
You need to crank longer, and give it a bit of throttle when starting initially from cold...
Also, change the oil for the shaft as well as the final drive.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Times are GMT -7.   It's 11:04 PM.
