Old 02-05-2013, 04:03 PM   #196
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
Originally Posted by Adv Grifter View Post
This is an impressive development. I'm glad to hear it's applicable to both KLR models (old and new).
I'm hoping you guys get enough early Beta testers to do this mod then go out and do the long, hard miles. Lets see how things hold up long term.
On our DR650's you can get a big bore kit. Expensive and requires expert skill to install. I've ridden a 720cc kit on the DR and was NOT very impressed. Really not much faster (if at all) than my moderately modified stock DR650.
Best of luck with these new mods. They sound awesome!
Same with the KLR, only very minimal gains are accomplished with big bore kits.
They are really performed to eliminate oil burning issues and reduce vibrations.
More power is gained through other mods, although Eagle Mike is working on some bigger big bore kits including a stroker so we will see what becomes of these.
He also has a Fuel injection kit almost ready for sale, but that doesn't interest me because I like the simplicity of the carburetor.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY screwed with this post 12-08-2013 at 04:12 PM
GAS GUY is offline   Reply With Quote
Old 02-06-2013, 01:15 AM   #197
marc11
Oddometer: 150
Originally Posted by GAS GUY View Post
It is mentioned that maybe Kawasaki retarded the exhaust cam to help with emissions.
Yeah, that is the only reason I was able to come up with too. I am going to keep an eye on the development for a while and see what is reported after people have been using it for a while.
2007 BMW R1200RT
2002 Honda XR400r
marc11 is offline   Reply With Quote
Old 02-06-2013, 08:20 AM   #198
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
Also keep in mind he is working on a adjustable sprocket to see if less than a tooth of advance is prefered over a full tooth.
But if it is you will have to buy the sprocket vesus the free mod.More than likely the free mod will be the way to go.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 04:13 PM
Old 02-06-2013, 11:27 AM   #199
IDRIDR
Take me to the River
IDRIDR's Avatar
Oddometer: 1,400
Checked mine last night. Exhaust valves tight. Will be doing the MC.
IDRIDR is online now   Reply With Quote
Old 02-06-2013, 03:18 PM   #200
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
Perfect timing on that !!
2001 GAS GAS 321
IBA # 23,716
Old 02-16-2013, 09:32 AM   #201
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
Shock fill and bleed.
I finished plumbing the shock and filled and performed the bleed procedure using Silkolene Pro RFS 5 weight oil, which is what is used in the Penske shocks also, so I still had a bottle on hand.
I also installed a new Moose Racing seal head.(Made by All Balls)
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 04:16 PM
Old 02-16-2013, 09:38 AM   #202
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
Final installation of shock.
Then I put 200 psi of nitrogen in the Fox remote reservoir and reinstalled the 550 inch pound monster Eibach spring with a Shop press at work and reinstalled the assembly on the bike.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 04:18 PM
Old 02-16-2013, 12:31 PM   #203
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
HID Low beam conversion.
Now it is time to move on to the Future Vision HID low beam conversion.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 04:31 PM
Old 02-16-2013, 04:58 PM   #204
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
The stock bulb mounting flange is alot thicker than the new HID, so I had to make up some plastic spacers so the retaining wire would hold the bulb in tight.
2001 GAS GAS 321
IBA # 23,716
Old 02-16-2013, 09:57 PM   #205
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
Its all buttoned up, with the ballast mounted in the space directly under the lights.
The bulb is a 35 watt and 4300k.
The light output should be much better along with freeing up 20 watts.I did not do the high beam because I don't like the delay in brightness when flipping the high beam on and off due to warm up time on HID lights.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 04:32 PM
Old 02-16-2013, 10:51 PM   #206
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I installed a DDM Tuning HID kit on my Triumph Tiger 1050 about 3 years OK. Big improvement in output. Then did the same with my DR650. Much better with HID ... I'd guess 3 times brighter than the stock 55W H-4 bulb. On both bikes I used the 35W / 4500K kits. perfect color temp, IMO.
The DR only puts out 200W max ... so picking up 20W is a good safety margin. The HID in the DR is now about two years old. Both Tiger and DR HID's going strong.
Old 02-17-2013, 07:28 AM   #207
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
For sure on the 35 watt kit.
A friend installed the DDM 55 watt kit on his Gsa and it throws too much scattered light pollution at oncoming cars and if he gets up behind a car the light bothers the driver from the side view and rear view mirrors, so he has to be careful not to get to close.
2001 GAS GAS 321
IBA # 23,716
Old 02-17-2013, 01:55 PM   #208
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
Front harness wire loom
While the front fairing is off I took the time to install plastic wire loom and tape over every inch of the harness and also unplug every connector and add electrical grease.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 04:33 PM
Old 02-17-2013, 05:46 PM   #209
Adv Grifter
Oddometer: 6,128
Remind me to leave my bike at your house next Winter. I love your attention to detail and expert technique! Excellence is rare.
Keep it up!
Old 02-17-2013, 08:28 PM   #210
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,287
Keep it up!
Thanks !!
Tinkering on bikes in the winter helps keep me partly sane till spring.lol.
2001 GAS GAS 321
IBA # 23,716
Times are GMT -7.   It's 03:04 AM.
