12-10-2012, 02:33 PM
#91 | |
Oddometer: 2,046
2008 KLR 705 2001 GAS GAS 321 |
12-10-2012, 04:13 PM
#92 |
My bikes Suck!
Oddometer: 779
Thing is, even with a brand new bike, big bore kit, full suspension, and every farkle you ever want to bolt up to the klr, your still less than half the price of a gsa. And all the fun.
Sent from my ARCHOS 80G9 using Tapatalk 2 |
12-12-2012, 03:30 PM
#93 |
Oddometer: 872
I hated to see even Eagle Mikes spring broke.
We should see if John Deere makes one that will fit. I've seen John Deere spings that were 50 years old..... |
12-12-2012, 07:09 PM
#94 | |
Oddometer: 2,046
With that original hole at 8:00 it is real tough installing the spring, and it would have alot of tension.
12-13-2012, 04:11 AM
#95 |
Oddometer: 2,046
If anyone is interested, Super bright leds.com is now having a 10% off sale.
The coupon code is XMAS12
12-13-2012, 07:21 AM
#96 |
2 Cheap 4 a KLR
Oddometer: 300
was having fun just reading the tread , now I get an bonus for reading it . Been meaning to order some leds for the camper and a tail light for my little super sherpa . Nice looking /setup klr , I about bought one when I got my super sherpa and still look at them hard at the show rooms or on the road . I think my next bike it going to be an used wee strom for the road and some gravel/fire trail running but if I had to have only have one bike it would be an klr.
09 Super Sherpa KL250 62 CJ-5 Trailering a bike is like hiring a prostitute just to jerk off in front of her . Hawk62cj5 screwed with this post 12-13-2012 at 07:27 AM |
12-13-2012, 05:54 PM
#97 |
Oddometer: 2,046
Valve clearance check
After buttoning up the left side cover after installing the Torsion spring and deep hole spacer, I pulled the valve cover and measured and recorded the valve clearances.
They were fine, and at the loose end of specs so it should be a long time before they need adjusted. While I had the cover off, I checked and made sure the cam cap bolts were tight. That is something I am paranoid about ever since a Drz 400 I had loosened up and destroyed the cam and head shortly after I bought it.I suspect someone before me had worked on the bike and forgot to tighten them properly. I also just read a ride report the other day of a KLR that put the decompression mechanism on the end of the exhaust cam up through the valve cover, and the caps and cam of course destroyed.From looking at the pictures it looks to me like the cam caps loosened up and with the cam chain pulling down in the front it destroyed the cam journals and cracked one of the caps and allowed the back of the cam to rise until the decompression mechanism hit the cover. Once again I suspect someone adjusted the valves and did not torque the bolts.Theres no way for me to know for sure But it seems likely. So just make sure your cam cap bolts are torqued, especially if you don't know who was in your engine !!
12-13-2012, 06:06 PM
#98 |
Oddometer: 2,046
Link to the ride report with top end problem
Here is a link to the RR I referred to.Its a great read also, and good pics of the damage on the Klr.
http://advrider.com/forums/showthread.php?t=843969
12-24-2012, 10:28 AM
#99 |
Oddometer: 2,046
Yesterday I disassembled all the suspension and swingarm linkages and lubed all the bearings and cavities with Maxima waterproof grease.
While the shock was off I verified the spring was a Eibach 550 in lb., which I was glad, as it is plenty of spring, and actually the heaviest spring that Eibach sells for the Klr now because anything more and it exceeds the Gvwr. I buttoned that all up and torqued it all to spec, and then pulled the carburetor to clean and verify all the jetting and replace the phillips screws on the float bowl and diaphragm cover with stainless allen bolts and add a T mod to the vent. The main jet is the stock 145 , but the needle is a Klx with the clip on the 2nd groove. The slide hole is stock. The pilot jet is stock #40, but I opened it a hair with a#78 number drill which isn't even a .001" bigger.It should put it between a stock 40 and a 42. The float level was dead perfect at .690". And the adjustable fuel screw was 2 turns out, I will have to play with that once I get back on the road. The airbox is stock except for the removed snorkel.I am going to open it up some more. I also installed a Sunstar 16 tooth sprocket.
2008 KLR 705 2001 GAS GAS 321 GAS GUY screwed with this post 12-24-2012 at 10:40 AM |
12-24-2012, 06:14 PM
#100 | |
Oddometer: 58
I am gonna do,the MHC ride Feb 28----,March. 3. 2013..I will post registration a date in the MTF. RRR section later in January....would like for you and you buddy to come down, ![]() Uncle jimmy . Hope you have a Merry Christmas.
12-24-2012, 06:58 PM
#101 | |
on the road o'dreams
Oddometer: 5,374
Don't know about the KLR but my DR650 really responded GREAT to opening the air box up. Also added a Dyno Jet needle which allowed tunability (stock needle is fixed). Huge difference in throttle response ... and still gets 50 MPG. Just a slightly richer main jet is all that's required. That DR loves L E A N ! KLR is probably similar. Let her breath, run her LEAN. They can handle it and your MPG will be fantastic ... and it will still run well up over 10,000 ft. (Hey, nice Blue Merrell Aussie there! I had a red years ago!) |
12-25-2012, 08:28 AM
#102 | |
Oddometer: 2,046
The subframe bolt is just a popular mod, especially for big guys and touring load. Yes, I am pretty much going through the whole bike, mostly maintenance and small mods as most of the big mods are already done.As a Mechanic by trade, I am anal about maintenance and try to limit chances of any problems during riding season.Also, it helps me during the winter months having somewhat of a project. I would love to get down there, but with work, and family, it really limits my mobility right now.But, sooner or later I will.Now that you got that sweet, lightweight 250L, you have at least another 20 years of riding left in you !!
12-25-2012, 11:47 AM
#103 | |
Forever N00b
Oddometer: 1,602
No KLR really "needs" this stuff *, but knowing what has been done before and knowing it's all clean for a new season is peace of mind for some of us (and unwelcome work for others). I think mine runs better with the KLX needle and whatever jet I eventually chose. (I'll open it up later this month and look -- just because.) *Some riders will need the subframe bolts for heavier loads or harder landings.
Motorcycles are magical. |
12-25-2012, 05:36 PM
#104 | |
Novice
Oddometer: 106
'06 Vulcan 900 |
12-25-2012, 05:44 PM
#105 | |
Oddometer: 872
Great thread, by the way. |
