Old 12-30-2012, 08:34 AM   #121
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
I flattened out the drive gear ring and reinstalled it all properly and will run it as is.
The crack on the wheel hub feels solid and even if it lets loose later it should only take out my speedo.
I installed the new Anakee 2 front tire which for some reason the PO bought a 100/90-19 instead of the 110/80-19 that was originally on the wheel, along with a new tube.
This tire is 10 mm narrower and a tad bit taller.Only .158" taller, to be exact, so pretty much the same height.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY screwed with this post 12-08-2013 at 08:54 AM
GAS GUY is offline   Reply With Quote
Old 12-30-2012, 08:22 PM   #122
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
Changed out all fluids
Tonight I changed out all the fluids.
I replaced the brake fluid front and rear with LiquiMoly Dot 4.
I used Cummins Fleetguard blue coolant for the cooling system.
And Mobile 1 -15w50 Full Synthetic motor oil.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 08:56 AM
Old 12-30-2012, 11:15 PM   #123
brailman133
Oddometer: 46
Subed
brailman133 is offline   Reply With Quote
Old 12-31-2012, 03:16 AM   #124
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,647
You are really ripping through that KLR.
When you are done maybe I should drop mine off so you don't get bored
However, I am not complaining because I know that I am probably better today then I will be tomorrow, so I try and enjoy every day as it comes, and stay determined to live well and be appreciative of what I still can do..."Stromsurfer"
PWRCRZR is offline   Reply With Quote
Old 12-31-2012, 10:36 AM   #125
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Great maintenance routine! You could set up shop in some warm Latin American country .... and do full services on the dozens of KLR's passing through on their way to Tierra del Fuego!
I'll tell ya ... some of those riders really need to attend an ADV Riders maintenance 101 class! I see so many who forget about the basics:
chains/sprockets/doo hickey's/air filters/cracked/overloaded frames/racks/razor thin brake pads ... and ON and ON and ON.
Hope you get a break in the weather and get a chance to get out and RIDE!
While you're at the maintenance ... maybe have a look inside your fuel tank, clean petcock filter, flush tank. Often overlooked. A clogged Pilot Jet is easy to do ... and many never get them cleaned properly. I carry a spare!
Clear and cold here today in NorCal ... about 45F. I'm going riding!
Old 12-31-2012, 12:56 PM   #126
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
Bent forks !!!!
I put the front end back together and sure enough the front forks are bent.
I noticed the misalignment before, but was hoping they were just shifted and that after loosening it all and retorqing that it would be ok.But, no such luck.
If you look at the fender and tire you can see the misalignment, they should move together.
Also, I noticed the rear subframe is tweaked to the left a bit, causing the seat to tank fit to be too tight.
I am going to have to pull the rear subframe and front forks back off and replace them.
The PO is a stand up guy, and is going to send me replacement parts.
He swapped ends at 30-40 miles an hour on gravel and didn't realize the extent of the damage.
In the meantime , while I am waiting on parts,I am going to pull the shock off and freshen that up.
UPDATE-After dissassembly and measuring the fork tube runout, the triple clamps appear to be bent instead of the tubes.
After some more research, I have also discovered the stock KLR triples are on the soft side and prone to bending in a hard crash.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-10-2013 at 03:46 AM
Old 12-31-2012, 07:17 PM   #127
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
That would be a dream job, but I'm stuck here for awhile.LOL.
Probably won't be much of a break in the weather here for a few months, I will just have to keep tinkering in the garage for awhile.
Carb and pilot jet are done.
The 10 gallon Tank is clean.
I am going to eliminate the vacuum diaphram on the petcock.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-08-2013 at 09:00 AM
Old 12-31-2012, 07:21 PM   #128
Ragin Rabbi
Semper Fidelis
Ragin Rabbi's Avatar
Oddometer: 5,093
I have a complete front end, minus triples. Wheel, forks off of a 2006.
Each according to their need, each according to their ability.
It takes a village to raise a child.
Go You Spurs!!
Ragin Rabbi is offline   Reply With Quote
Old 12-31-2012, 07:32 PM   #129
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
Yeah, I'm trying to cover all the bases, so it's ready to roll in the spring.
If you weren't so far away I could give yours the treatment !! Lol.
I was out your way this past summer, I rode to Acadia NP., and Bar Harbor.I camped out in Acadia.
2001 GAS GAS 321
IBA # 23,716
Old 12-31-2012, 07:36 PM   #130
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
Thanks for the offer but I need 2008+ parts.The forks are bigger diameter 2008+.
2001 GAS GAS 321
IBA # 23,716
Old 12-31-2012, 07:58 PM   #131
SteelB12
SteelB12's Avatar
Oddometer: 3,015
Man, I really want to do all sorts of maintenance on mine, but I just can't stop riding it long enough to get any of it done
2003 Suzuki Bandit 1200S
2009 KLR650
SteelB12 is online now   Reply With Quote
Old 12-31-2012, 08:08 PM   #132
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
Thats a good problem to have !!!! Lol
2001 GAS GAS 321
IBA # 23,716
Old 12-31-2012, 08:11 PM   #133
SteelB12
SteelB12's Avatar
Oddometer: 3,015
I guess, but it also means I don't have time to work on my Barbie
2009 KLR650
Old 12-31-2012, 08:21 PM   #134
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
Just do it.Tear it down and ride one of your other bikes till it's done.
2001 GAS GAS 321
IBA # 23,716
Old 12-31-2012, 09:09 PM   #135
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,508
HAPPY NEW YEAR !! It's going to be a good year.
2001 GAS GAS 321
IBA # 23,716
GAS GUY screwed with this post 12-10-2013 at 03:44 AM
Times are GMT -7.   It's 08:53 PM.
