Old 09-27-2012, 11:16 AM   #1
BMW Kurt OP
Exorbitant Tax Payer
BMW Kurt's Avatar
Location: People's Republic of the United States of America
Oddometer: 7,428
85 R80RT fork seal replacement
I need to replace my front fork seals on my '85 R80RT and would like to know if there is a tutorial or something here on this site. I have done this before on an R90S and do not remember it as being as difficult as Clymer describes. Clymer calls for removal of the fairing and total disassembly of the forks if I am reading it correctly. All I need to do is replace the turquoise colored seals. I think when I did this before all I had to do was remove the lower forks.
Any links to help a fellow out??
"We blew it." -- Wyatt in Easy Rider
My Riding Blog
My Travel Blog
Kurt Nugent Photography
My Adventure Page
BMW Kurt is offline   Reply With Quote
Old 09-28-2012, 09:49 AM   #2
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 752
Happily consuming fermented beverages since 1974.
"We are of two groups: 1, beer drinking, mechanically inclined, semi-normal airhead riders, and 2. the others."- Mista Vern
squiffynimrod is offline   Reply With Quote
Old 09-28-2012, 11:03 AM   #3
BMW Kurt OP
BMW Kurt's Avatar
Oddometer: 7,428
Hmmm! Maybe I need to rephrase my question.
Do I really need to dismantle the fairing and entire front fork assembly to replace the fork seals on an '85 R80RT?
I replaced the fork seals on an R90S once and I swear it only took a couple of hours (if that!).
My Riding Blog
My Travel Blog
My Adventure Page
Old 09-28-2012, 07:44 PM   #4
bmwrench
Oddometer: 1,483
Renewing the fork seals in your current bike is not a lot different than on your R90S. Remove the front wheel and fender, then remove the 8mm bolt that retains the slider, which is visible once the axle is removed. You may need an impact wrench to remove these screws because the damper rod tends to rotate with the bolt. Once the bolts are out, pull the sliders and fork brace as one. Renew the seals. Reassemble and refill the oil through the holes at the top of the fork.
bmwrench is offline   Reply With Quote
Old 09-28-2012, 08:22 PM   #5
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 1,644
This is what I do for a 1982 model R100RS.
Changing BMW fork Seals/ springs/ gaiters/ oil
Nomenclature: I call the chromed tube the fork tube. The fork leg is the lower forged bit that the calipers attach to.
1. Put new seals in the freezer for 1 hour beforehand.
2. Loosen, remove, the top fork bolt to allow drainage and refill of fork oil..move h/bars to get to bolt.
2a. To replace the springs, you need to remove the large hex bolt at the fork top, therefore no need for point 2. That bolt is very tight and easy to round off. Make sure your tool fits well.
3. Remove the lower drainage small bolt. Allow oil to drain.
3a. Replace springs, loosely replace top bolt.
4. Disconnect brake calipers from fork legs...hang carefully.
5. Loosen, don't remove, the retaining bolt at the bottom of the fork. You get better leverage before the axle comes out.
6. Remove axle/wheel/front guard.
7. Now remove retaining bolt, drop fork leg down, leaving the fork tube on the bike. Remove old gaiters/boots.
8. Clean fork leg internals.
9. Carefully lever out the old seal. I use a blunted straight screwdriver. You must not score the inner surface of the fork leg where the seal sits. Insert the cold new seal, use old seal to seat the new seal.
10. Slide upper gaiter spacer then gaiters onto fork tube.
11. Install fork leg with new seal carefully over the fork tube..
12. etc, etc...both sides
13. Reinstall drain bolt, refill oil, tighten top bolt.
14. wheels etc back on...
15. fiddle with the gaiter spacer, locate it into the breather tube on the inside of the lower triple clamp.
One hour max. Quicker the next time.
boxerboy81 is offline   Reply With Quote
Old 09-29-2012, 07:09 AM   #6
BMW Kurt OP
BMW Kurt's Avatar
Oddometer: 7,428
Thanks! That's what I was looking for!
My Riding Blog
My Travel Blog
My Adventure Page
Old 10-05-2012, 01:02 PM   #7
BMW Kurt OP
BMW Kurt's Avatar
Oddometer: 7,428
Just out of curiosity... why put the seals in cold? Do they contract in the freezer making them easier to put in and then swell to make a better fit??
My Riding Blog
My Travel Blog
My Adventure Page
Old 10-05-2012, 01:11 PM   #8
supershaft
because I can
Oddometer: 6,208
It seems that everyone is missing the hardest part: removing the snap ring above the seal. I use a tiny Vise Grip that I ground on a bit to remove the seal out from under the snap ring and then remove the snap ring. If your careful, it can be done without gouging anything. I have seen some muffed up sliders for people trying to get theose snap rings out the hard way. Good luck!
Old 10-05-2012, 01:35 PM   #9
bmwrench
Oddometer: 1,483
That might be because his bike doesn't have a snap-ring above the seal.
Old 10-05-2012, 01:51 PM   #10
BMW Kurt OP
BMW Kurt's Avatar
Oddometer: 7,428
Thanks! Scared the hell out of me for a second!
My Riding Blog
My Travel Blog
My Adventure Page
Old 10-05-2012, 01:52 PM   #11
supershaft
because I can
Oddometer: 6,208
That could be it! Sorry everybody. I got my later model forks mixed up.
Times are GMT -7.   It's 08:39 PM.
