Old 09-27-2012, 07:54 PM   #1
davidb21 OP
Oddometer: 90
klr 250 mods
Mods ive done to my 2004 klr 250 in case any other klr 250 riders find the info useful.
exhaust & airbox- FmF Q4 slip on, pulled out the snorkle to the airbox, and replaced the stock air filter with a uni filter.
jetting- i used the dynojet kit with the dj118 main and kept the pilot at the stock 35 keihin, i used the dj needle and set the e-clip at the 2nd position from the top of needle, slide lift hole drilled out with the provided bit, and put the fuel mixture screw at 3.5 turns out.
random stuff added- trackside aluminum handguards with moose plastics, ricochet skid plate, magnetic oil drain plug, pro taper cr hi bend bars, and a UFO front fender.
The tires im running and will probably stick with forever on this bike are kenda k270's.
I have some progressive fork springs and 14 tooth front sprocket i need to install, will post update with results. Front sprocket is a JTF 512-14.
davidb21 screwed with this post 03-26-2013 at 05:13 PM Reason: changed the thread
davidb21 is offline   Reply With Quote
Old 12-29-2012, 03:49 PM   #2
davidb21 OP
Oddometer: 90
Update on my mods.
The main difference ive noticed with these mods is that it climbs through the lower rpms in each gear A LOT faster than stock.
davidb21 screwed with this post 03-13-2013 at 06:53 PM
Old 03-05-2013, 09:05 PM   #3
FuzzyNugs
Oddometer: 78
Thanks for posting this update, I'm in the same boat now and leaning towards the FMF because it's cheaper or even half of that is the DG exhaust on eBay....hmm.
Did you try changing sprockets at all?
FuzzyNugs is offline   Reply With Quote
Old 03-13-2013, 06:31 PM   #4
davidb21 OP
Oddometer: 90
No problem i'll keep updating this whenever i do more mods, i really like the fmf, i havent really heard about the DG before
i havent done anything with sprockets yet but im thinking about putting a 14 tooth front
Old 03-13-2013, 07:24 PM   #5
1994klr250
1994klr250's Avatar
Oddometer: 652
In the past I have used a 14 tooth counter sprocket on my klr250. In 6th gear it turns about 500 rpm's more at 45 mph over the 15 tooth. The 14 tooth helps a bit in off road slow riding.
I also have a big gun evo x full exhaust on it, which is fairly loud over the stock pipe. Between the carb mods and the exhaust its a great running bike.
2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239
Fall ride on a KLR250 http://www.advrider.com/forums/showthread.php?t=754065
1994 KLR250, 2009 F800GS, 2006 KLX351
1994klr250 is offline   Reply With Quote
Old 03-16-2013, 11:14 PM   #6
davidb21 OP
Oddometer: 90
Hey ive seen pics of your bike over at the klr650.net 250 forums, looks great
I ordered the 14t yesterday so i should be trying it out next week
Times are GMT -7.   It's 12:22 PM.
