Old 01-09-2015, 09:02 AM   #1
russbryant OP
Oddometer: 1,121
Adding Lightness - R100 GS aND GSPD
There are a lot of posts scattered throughout the Airheads forum concerning the weight of the BMW R100GS PD. Specifically...what a heavy pig it is. So the question that comes up is how can it be made lighter?
I have a 1990 R100GS PD that is being stripped down and I have been weighing the parts as they come off. I also have an 1989 GS that has been lightened a bit and I hope to get it weighed soon to see where it is compared to the stock weight. In the meantime, maybe you can find some useful info here to apply to your own GS's weight loss program.
The goal is roughly...strip off any unnecessary weight and to replace heavy parts with lighter ones as long as reliability isn't compromised of course.
Here is a pic of my 1990 R100 GSPD that will be the donor of the parts that I will weigh for reference in this thread.
In case you're wondering why I would tear apart a perfectly good GSPD, well...it's not exactly "perfectly good" anymore thanks to a left turning cage.
The scale I am using is a Berkley 50 lb Digital Fish Scale, model # BTDFS50-1
The BMW published curb weight with full tank of gas:
BMW 1990 R100GS PD 236 kg = 519 lbs
BMW 1990 R100GS 210 kg = 462 lbs
57 lb. difference
The first thing to be mindful of is the amount of gas in the fuel tank itself.
There is a mind boggling 56 pounds of fuel in a full 9.25 gal. GSPD tank!!
That's not an issue when slabbing down the highway, but for riding off pavement it can really make a difference in the feel of the bike.
Gas weighs 6.073 lbs per gallon and listed below is the weight of just the gas for various GS tanks.
The R100 PD 9.25 Gallon (35 liter) tank = 56.2 lbs of gas.
The R80 G/S PD 8.45 Gallon (32 liter) tank = 51.3 lbs of gas.
The R100 GS 6.34 Gallon (24 liter) tank = 38.5 lbs of gas.
The R80 G/S 5.15 Gallon (19.5 liter) tank = 31.3 lbs of gas.
The empty gas tanks weigh:
GSPD 9.25 gal. tank w/petcocks & no cap 21 lbs. 2 oz.
GS 6.34 gallon tank TBD
G/S 5.15 gallon tank w/o petcock or cap 10 lbs. 3 oz.
G/S PD 8.45 gallon tank TBD
The heaviest combo of tank and fuel is 76 lbs 5 oz for the GSPD tank.
The lightest is 41 lbs 8 oz for the R80 GS tank
Largest GSPD tank with full tank
GSPD tank = 21 lbs 2 oz
9.25 gallons of gas = 56 lbs 3 oz
Front faring, Instruments, etc. = 18 lbs 4 oz
total = 95 lbs 9 oz
or
Smallest Tank with 3 gallons of fuel
3.00 gallons of gas = 18 lb 3.5 oz
G/S tank = 10 lb 3 oz
Front faring, etc. = 18 lb 4 oz
Total = 46 lb 10.5 oz
===> 95.5 - 46.7 = 48.8 lbs to play with!!!
Here are some of the parts I've weighed so far:
Items on the front end:
Windsheild w/no hardware (OEM) 1 lbs 2 oz
Insrtument fairing bracket 1 lbs 4 oz
Insrtument fairing, w/headlight, no instruments 4 lbs 15 oz
Speedo, tach, clock, small bracket, and screws 2 lbs 4 oz
Roo Bar w/headlight guard 6 lbs 7 oz
Handguards (both) 0 lbs 8 oz
Front left fairing cheek 0 lbs 14 oz
Front right fairing cheek 0 lbs 14 oz
Front Fender (Acerbis) 1 lbs 5 oz
Front fairing/headlight/roo bar etc. (forgot front turn signals) = 18 lbs 4 ozs
Left Side Cover 0 lbs 14 oz
Right Side Cover 0 lbs 6 oz
Rear Fender w/turn signals, tailight, etc. 4 lbs 4 oz
Rear Subframe w/dual seat rack 10 lbs 5 oz
Lower Engine Fairing w/clamps 1 lbs 9 oz
Seat (Dual) (no rack - included on subframe) 5 lbs 8 oz
Seat (Solo) 3 lbs 8 oz
Rack for Solo Seat 2 lbs 8 oz
Seat (Solo, Q-Tech) 3 lbs 4 oz
Rear Shock (Wilbers) 8 lbs ?
Exhaust OEM Stainless Steel 9 lbs 12 oz
More to follow...
Russ
Tucson
1989 R100GS
russbryant screwed with this post 01-09-2015 at 09:24 PM
russbryant is offline   Reply With Quote
Old 01-09-2015, 09:16 AM   #2
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,531
Thumb
in...and glad you're O.K., I hope...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is online now   Reply With Quote
Old 01-09-2015, 09:20 AM   #3
patrkbukly
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,167
Weights & measures
Wow, now this will be an intersting process. I see these mountain bicyclers that have those cycles down to the ounce.
Interesting approach to a never ending frame cracks issue maybe. Lighter parts on same frame maybe will fix that.
Cool.
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 01-09-2015, 09:29 AM   #4
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,983
I believe TAG sells carbon-fiber fuel tanks... both small and large.
Airhead Wrangler documented the weight reduction process for his R80ST that he built into an HPN... check there for great data.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 01-09-2015, 09:54 AM   #5
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,868
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 01-09-2015, 09:55 AM   #6
neil p
Oddometer: 88
Interesting project.
I swapped out the PD set-up for a regular GS tank and big headlight a few years ago.
I miss the fairing/screen on faster runs but not the extra weight in daily local use.
The whole roo-bar fairing has a significant bulk that really loads up the front end.
I still have the PD kit, and like the tank.
Definitely don´t miss the crappy PD headlight.
Looking forward to seeing which direction you go in.
R80GS,K75,Morini Kanguro 350,Guzzi V1000 Convert, Dnepr MT16,´96 Fireblade, XL200PD
neil p is offline   Reply With Quote
Old 01-09-2015, 10:48 AM   #7
ianboydsnr
Oddometer: 107
I lightened my R80Gs,
I actually took the roo bar and fairing off to refurbish, which I did, but it seemed so heavy that I decided to leave off!
Here it is before I finished it!
ianboydsnr is online now   Reply With Quote
Old 01-09-2015, 12:22 PM   #8
russbryant OP
Oddometer: 1,121
Thanks, I'm OK now...it was in Nov 2010
Russ
1989 R100GS
Old 01-09-2015, 12:32 PM   #9
russbryant OP
Oddometer: 1,121
Yep, I've read his thread and will likely need to use some of his data or at least use it for comparison.
Russ
Tucson
1989 R100GS
Old 01-09-2015, 12:39 PM   #10
russbryant OP
Oddometer: 1,121
My roo bar, instrument panel, and instruments, etc was over 18 lbs and the Trailtech Vapor and Trailech X2 headlight I'm using on my 1989 GS is under 2 lbs.
Russ
Tucson
1989 R100GS
Old 01-09-2015, 12:43 PM   #11
russbryant OP
Oddometer: 1,121
I'm right there with ya brother!!! I'm going to keep the tank and some other bits so that I can swap em around as needed.
Russ
Tucson
1989 R100GS
Old 01-09-2015, 12:51 PM   #12
MotorcycleWriter
MotorcycleWriter's Avatar
Oddometer: 1,174
The best way to reduce the weight of the GS and GSPD is to get a DR650.
MotorcycleWriter is offline   Reply With Quote
Old 01-09-2015, 12:52 PM   #13
_cy_
Oddometer: 6,337
there's all sorts of places, but among the easiest below. My R80G/S is about 350lb dry with these two changes .. about 375lb stripped trail weight w/3 gal fuel. sooo .. assuming you want to ride an airhead, easiest way to drop weight is to switch bikes to G/S
1. install an EarthX ETX 36 (14AH) about 3lb 12oz .. tested down to 15f on test mule R80G/S .. totally bombproof if your charging system is working correctly and putting out about 14.2v. weight saved depends on what's installed. Odyssey PC925 is about 28lb .. so that would save 24lb.
drawback is costs $$$ .. there's an electric bike 20AH actual LiFePO4, weight about 7lb, tested down to 20f and cost about $135. it's important to realize our carb airheads have much higher AH requirements vs modern bike with fuel inj.
all sorts of test data on my battery testing thread .. link in sig
2. change out stock muffler .. my preference is super trap. best of all it's tunable by adding or removing discs.
_cy_ screwed with this post 01-09-2015 at 01:05 PM
Old 01-09-2015, 01:15 PM   #14
russbryant OP
Oddometer: 1,121
So why stop there ?? Why not get a 317 lb KTM 690 and be done with it??
Russ
Tucson
1989 R100GS
Old 01-09-2015, 01:30 PM   #15
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,603
Why stop there, get an XL100.
But wait, bicycles are really light.
Shoes weigh almost nothing.
Barefoot does weigh nothing.
Now a hunger strike, that's the way to go!
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Times are GMT -7.   It's 12:06 PM.
