07-20-2012, 09:15 AM
#1 |
Oddometer: 796
another versys powered klr
well here it goes guys another versys powered klr project. mostly because i saw a complete versys partout and couldn't pass up the deal and the proximity.
Here's the frame. and the engine. everyone knows it doesn't fit in. i plan on copying some of klrsys project because its the most well documented and makes sense to me as well. first thing's first, flip those carb boots their directional which is why you have to flip the carbs as well that's it for now. time to get out the sawzall
1969 CL350 permanent project 1983 CB650SC nighthawk that's not flying. ![]() 1985 GS700EF suzi the distraction ![]() 1989 KLR 650: the dream bike ; now stolen once. the klr/versys project: http://advrider.com/forums/showthread.php?t=810279 |
07-20-2012, 09:55 AM
#2 |
Oddometer: 155
subscribed
07-20-2012, 02:29 PM
#3 |
Oddometer: 659
Cool project!! I know this has been done before but never looked at a build. What fuel tank are you going to run? Just wondering about the fuel pump.
07-20-2012, 03:07 PM
#4 |
Oddometer: 796
Im basing most of my project on klrsys's build thread. He ran the stock tank and rigged it so the hose ran into an external fuel pump mounted under the seat. I'm looking at the fuel pump and figuring out my options but that looks like the simplest way currently.
07-20-2012, 04:05 PM
#5 | |
Oddometer: 659
07-21-2012, 07:21 AM
#6 |
Oddometer: 68
The stock Versys fuel pump has to be put in a can for cooling. If anyone knows of a suitable small external pump and regulator I would like to hear about it and I'm sure Tom would also. The specs for the stock pump:
With engine idleing: 294 kPa (3.0 kgf/cm2, 43psi) with fuel pump running Discharge: 60ml or more for 3 seconds (72 liters/hr) KLRsys screwed with this post 07-21-2012 at 08:02 AM |
07-21-2012, 08:46 AM
#7 |
Oddometer: 4,912
The Suzuki LT-R 450 quad pump is perfect. It's about 4-5" long and should put out enough juice for 65 RWHP.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
07-21-2012, 01:12 PM
#8 |
Oddometer: 659
The problem with an external pump is the fuel lines. If you was to wreck and break or crack a fuel line with that much fuel pressure it could be bad real bad.
07-21-2012, 02:53 PM
#9 |
Oddometer: 4,912
I don't really get the concern?
![]() The pump and lines would be tucked in under the tank, so they won't be damaged if you crash. If you use fuel injection rated hose it will not split either. And most importantly, the only difference between internal and external pump is the line going from the tank to the pump, and that is not even under pressure?
07-21-2012, 03:43 PM
#10 |
Oddometer: 659
The stock line thats under pressure on the ninja is very short when you move it under the seat you will have two long fuel lines. This bike should be able to run over 120 mph. It just scares me not saying it wouldn't work. The tank off of a KTM or Husky that has the fuel pump in it would work and be safer and easier. Just
my opinion.
07-21-2012, 07:30 PM
#11 |
Oddometer: 4,248
You sleep with the lights on don't you.
07-21-2012, 08:40 PM
#12 |
BrotherFromAnotherMother
07-21-2012, 10:00 PM
#13 |
Oddometer: 133
I've worked on a few bikes that had external pumps, never heard of them turning into fire balls.
Like that other guy said, the only difference would be a couple of inches of plain rubber fuel line from the tank to the pump, even mounted under the seat the bike would have to turn itself inside out for damage to occur. |
07-22-2012, 07:17 AM
#14 |
Oddometer: 3,814
Facet makes some really nice, small external fuel pumps. They are a common upgrade on KTM Adventures. DAMHIK.
As an example: http://www.aircraftspruce.com/menus/...telectric.html FAA rated, so.................... ![]() BTW, since you have a bare KLR frame, I would suggest welding a small plate over the spine above the shock mount/down tube area. There is a lot of stress on that point is it is known to fail and be a weak point. I'm in.
"Deeply flawed people make deeply flawed decisions." |
07-22-2012, 08:47 AM
#15 |
Oddometer: 796
service manual reveals fuel pressure is 294kPa, 41.81psi and discharge is 83mL (2.8US oz) and more/10 sec. i dont think it will work with that lower flow rate, anyone else know if it would or wouldn't?
