Old 02-23-2013, 02:51 PM   #61
chollo9 OP
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
Wheels
Got the wheels laced today. Not done, but lightly tensioned, and roughly trued. They sure do look nicer than the poor things that came off--I'll feel a lot more confident beating the crap out of them too!
If your gonna be dumb, you gotta be tough
When you get knocked down you gotta get back up,
I ain't the sharpest knife in the drawer but I know enough, to know,
chollo9 is offline   Reply With Quote
Old 02-23-2013, 03:16 PM   #62
BeardThrone
...in bat country.
BeardThrone's Avatar
Oddometer: 69
+1 for more fairing pictures!! The whole build looks good by the way. Who makes those square auxiliary lights?
BT
BeardThrone is offline   Reply With Quote
Old 02-23-2013, 03:40 PM   #63
chollo9 OP
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
Okay okay I'll get some more fairing pictures up tomorrow! You guys are gonna be seriously disappointed, I'm tellin' ya!
The square lights are Rigid Industries. The one with four LEDs is a Dually, the one with six is a D2.
Old 02-23-2013, 03:52 PM   #64
BeardThrone
...in bat country.
Oddometer: 69
I am thinking about working with a tall windscreen from a F650 Dakar, trim it to fit the round headlight and just painting it. Thanks for the info on the lights.
BT
Old 02-23-2013, 03:54 PM   #65
ME 109
ME 109's Avatar
Oddometer: 605
Those driving lights are wickidly good, so I believe.
Anyone know where they can be bought in Australia?
Or is overseas purchase the go?
Lord of the Bings
ME 109 is offline   Reply With Quote
Old 02-23-2013, 04:07 PM   #66
chollo9 OP
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
The D2 is great, the Dually isn't in the same league.
Don't know about availability in AUS, but I had to source my front disc from there (Metalgear) and it got here reasonably quickly, for about $60 post.
Old 02-23-2013, 04:38 PM   #67
ME 109
ME 109's Avatar
Oddometer: 605
A quick look on ebay shows there are a few option for D2 lights. Homework required.
Lord of the Bings
Old 02-24-2013, 10:22 AM   #68
bmwrench
Oddometer: 1,462
Originally Posted by chollo9 View Post
The nuts both have a threaded shoulder on the backside (one piece). The tensioner spring sits in the recess of the lower one, and rides over the upper one. I didn't pay any attention to it since that's how it was when it came apart, but since you asked, I looked at MAX's fische and it doesn't show a special nut like this.
What do other folks have? I'm starting to think I have a freakmobile . . .
The nuts on your motor are the usual type. Finding the correct parts and illustrations can be difficult with the online parts finders.
bmwrench is online now   Reply With Quote
Old 02-24-2013, 05:03 PM   #69
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 4,998
You have the correct nuts for the bearing holder that also provide a mounting place for the tension spring.
---Albert Einstein
Old 02-26-2013, 12:43 AM   #70
chollo9 OP
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
Good to know my nuts are correct. Now about a shoitage in ze other depoitment . . .
Ba Dum Pum
I'm here all week.
Tip your waitress.
Old 03-05-2013, 03:47 PM   #71
chollo9 OP
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
Latest updated from the Bodge Garage
There's been far too much workin' and not enough wrenchin' goin' on around here, but there is some progress being made.
Wheels are built, and I was able to overcome the factory misalignment by offsetting the rear rim 5mm toward the drive side. I used the tried and true string method:
5mm was as much as I was comfortable dishing the wheel without using different length spokes, which I didn't have, so I also cheated the swingarm to one side by 2mm via the bearing adjusters. AND it is still 1mm out of alignment, so that shows how far off it was originally!
Next, look at the beautiful job that bmwrench did on my heads:
All new guides, new exhaust seats, valve job, new exhaust valves, and a super cleaning. Everything else is ready for assembly, so that's happening this week.
These shiny parts are making my steed look a little grungy, but it all will look dirty (like it should) pretty soon.
chollo9 screwed with this post 03-05-2013 at 10:50 PM
Old 03-05-2013, 06:34 PM   #72
bmwrench
Oddometer: 1,462
Who made that brake rotor? It's beautiful.
You gonna have room for your rear tire with that much rim offset?
Old 03-05-2013, 09:42 PM   #73
chollo9 OP
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
The rotor came from Metalgear in Australia--it's for a first generation GSXR 750.
I run a 110 rear tire, so clearance will be fine.
Old 03-06-2013, 01:49 PM   #74
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,004
All the Airheads came from the factory with the swingarm centered and some offset built in. That is where the 5mm came from. There is no need to spend time correcting this at all. It will track as true as anyone might need.
Your logic was right, but in this case it is in fact correct as is.
Great project, will be watching.
DoktorT screwed with this post 03-06-2013 at 02:07 PM
DoktorT is offline   Reply With Quote
Old 03-06-2013, 02:49 PM   #75
chollo9 OP
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
Um, I can't quite see the logic in that, no offense meant in any way. While I'll agree that a road bike (versus a road race bike) doesn't need perfect alignment (and that's why I didn't try to get the last little bit, plus the tolerances of strings and rulers being what they are . . .), it was quite noticeable that the wheels were out of alignment. If I took my hands off of the bars, the bike would strongly pull to one side, and it would turn easier one way than the other (i.e., fall into corners one way, and require more handlebar pressure the other direction). Whether or not it is worth the bother to correct is up to the individual--to me, it was.
Thanks for the kudos.
Times are GMT -7.   It's 05:29 AM.
