Old 10-01-2012, 08:06 AM   #1
RaystheBMW OP
1986 R65
RaystheBMW's Avatar
Oddometer: 171
Cracked headlamp ears
For months I have been trying to figure out the rattle coming from the headlight area at 2700-3000 rpm. Everything inside the bucket has foam tape on it, and all the cables are secure. I think I found the source though. Looking closely I found hairline cracks in the stamped steel on both ears. They start in the center of the bolt hole and go down to the outer edge. There is no rust or damage otherwise, and the headlamp feels like its solidly mounted. It's just during high vibration times that I get the rattle. But I think I may be looking at a bigger problem down the road if I don't do something about it now. What are my options?
RaystheBMW is offline   Reply With Quote
Old 10-01-2012, 12:18 PM   #2
scarygary
Drawing blanks
scarygary's Avatar
Oddometer: 385
I had the same issue with my R65. I think it was caused from the bike wearing a big windscreen with brackets that bolt up to the headlight adjuster bolts. I just bit the bullet and ordered a new set. The metal is too thin to repair. I figured it was going to be a one time purchase. They are not cheap.
Old and cracked.
Freshies
scarygary is offline   Reply With Quote
Old 10-01-2012, 01:51 PM   #3
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I disagree, I just welded the one on my 87 R80 the other day. Same crack same place etc. Turned the mig welder down low and gave it a bead on the back side.
If it cracks again, I will weld in a large washer to beef it up. the price on new ones is just ridiculous. BMW price gouging at its worst
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 10-01-2012, 04:16 PM   #4
pbarmy
pbarmy's Avatar
Oddometer: 1,818
That's what I was thinking,with the washer.Hell used ones are pricey,I found a pair at mid-Ohio this past summer tho for $30
"Nostalgia ain't what it once was"
pbarmy is offline   Reply With Quote
Old 10-01-2012, 05:06 PM   #5
RaystheBMW OP
1986 R65
RaystheBMW's Avatar
Oddometer: 171
I don't have a mig welder but was thinking of embedding a washer in epoxy on the back side. The price is over $200 for the new parts from BMW, and not sure about difficulty of R&R.
Old 10-06-2012, 12:27 PM   #6
RaystheBMW OP
1986 R65
RaystheBMW's Avatar
Oddometer: 171
Lacking other resources, I epoxied some large size washers to the outside of the flanges and gave them a quick shot of Rustoleum black rust reformer, which has a dried finish that's pretty close to the rest of the bike. I think it looks OK, and if it holds up, even better!
Times are GMT -7.   It's 06:56 PM.
