Old 10-01-2012, 05:28 PM   #1
tnktm OP
Oddometer: 43
If I get a Montana what else do I need?
I want a gps to download dual sport rides into gps and go ride them and to ride off road and overlay where I rode on a map. The Montana seems the best (although expensive) and I saw a "rugged mount" to hard wire it to bike (although it says some kind of ball socket not included). I see people talking about mapsource or basemap. I guess my question is do I need to buy 3 programs (topo map, regular map, mapsource or basemap)? I'm not sure what kind of maps to use for the 2 thinks I want to do. I might want to use google maps somehow if I could. I'd kinda like an idea what I need before I start purchasing. I saw a topo map that said 100k and a southeast (where I am) topo map that said 24k but the what looked like smaller map was more expensive (which didn't make since). Sorry if the answers are obvious and thanks for any advice.
tnktm is offline   Reply With Quote
Old 10-01-2012, 05:40 PM   #2
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,433
Back in 2010 I put Mapsource and City Nav on my 76Csx and got along fine doing the CDT.
I also bought the topo program but found it lacking and not as useful, so at the end of the day it was wasted money.
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 10-01-2012, 05:40 PM   #3
rickcj7
rickcj7's Avatar
Oddometer: 500
You need the GPS, rugged mount, handlebar ball mount, and whatever maps you want.
The 650t comes with topo maps on it
The 650 has camera no maps
The 600 has no maps or camera
Mapsource and basecamp are the programs you use on the PC to plan and map out you trips.
Husqvarna TE630
WR250R sold
FE450E sold
XT, NX, KLX, KLR, DR all long gone.
rickcj7 is offline   Reply With Quote
Old 10-01-2012, 05:52 PM   #4
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,718
Mounts. You've got three basic options:
1. Ram mount and cradle -the ball and socket deal. Doesn't lock, doesnt supply power, the least expensive route.
2. Garmin powered cradle - doesn't lock, but it does supply hard wired power. You've still got to mount it, a Ram ball and arm setup is a good way to go. Not terribly robust, use a tether.
3. The Touratech locking mount. This incorporates the Garmin cradle to supply power and adds a pretty stout lock. Again, you've got to mount it to the bike -directly to a handlebar crossbar is a good method.
I'm using option 1 with my Montana until I can afford option 3.
Software: Mapsource and base camp are Garmin's interfaces. It looks like Mapsource is being phased out, base camp has all the functions and a few other nice-to-have features. Both are free when you get a map set, both will work with topo and street maps.
Maps: the topo series has two versions; 100k and 24k. The 24k series are vastly more detailed than the 100k maps - roughly 4x the detail. These maps are split into regions and cost ~$130 each. They're also capable of auto routing to POIs and street addresses within both the interface and on the gps. Each region will fit on a 4gb micro sd card. For road maps, your options are the City Navigator series. I think they're up to 2012 v3, you'll get a free update if you purchase a new license for an older product. These maps also support auto routing on the computer and gps.
Twilight Error is offline   Reply With Quote
Old 10-01-2012, 06:04 PM   #5
tnktm OP
Oddometer: 43
Wow - thanks so much for the info. I'm wondering if the topo maps will show a road if you come up on it (I want an idea of the area I was in pertaining to local landmarks and also if I could find someone else's route if I put it on a topo map), or are there no roads at all? Also, is the Montana with the topo maps already on it the one with less detail (I would imagine it would be)? Thanks again for all the help.
Old 10-01-2012, 06:23 PM   #6
Twilight Error
Oddometer: 22,718
Yes, roads are on the topo maps. The 650t has the lower resolution map.
Old 10-01-2012, 07:16 PM   #7
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,660
Originally Posted by Twilight Error View Post
2. Garmin powered cradle - doesn't lock, but it does supply hard wired power. You've still got to mount it, a Ram ball and arm setup is a good way to go. Not terribly robust, use a tether..
Garmin's Rugged Mount is lockable. It comes with a Torx Security screw and tool. And at $33, it's a steal.
Stovebolt's making a mount for the Montana too, but it looks like it doesn't incorporate the Rugged Mount so it means you need to use USB if you want to power the gps. Not acceptable, IMHO. One of the biggest advantages of the Montana is its power source through the Rugged Mount.
And any mount system still requires a tether on the gps.
Old 10-01-2012, 08:00 PM   #8
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,347
+1.
I use it with an Adaptiv Mount.
It's a really deluxe version of a RAM mount. Rather than the big old knob it tightens with an allen wrench.
I figure my new Montana is just as secure with this setup as it ever was with the Touratech locking mount I used on my zumo. It works, but it's kinda cheesy truth be told. With my setup, you can get the GPS by a) having the correct small torx wrench or b) have the correct allen key. If you have that, you can get the whole mount, but then you also need something sharp to cut the cable out. Stealing a GPS is a quickie snatch & grab situation. I think it's pretty secure.
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain screwed with this post 10-02-2012 at 11:55 AM
levain is offline   Reply With Quote
Old 10-02-2012, 04:43 AM   #9
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,660
Originally Posted by levain View Post
+1.
I use it with an AdaptivMount™ Handlebar Gadget Mount
I fixed your link to the Adaptiv mount. It's not cheap at $85.
I used RAM parts but got rid of the knob and used a self locking nut instead to make it a little harder to steal.
Old 10-02-2012, 02:17 PM   #10
abhibeckert
abhibeckert's Avatar
Oddometer: 1,700
+1
I was lazy, i don't need a tether for riding down smooth highway roads! Even during the hardest trail riding and jumps I've ever done the quick release never failed.
Then one day I the guy sitting behind me at a traffic light walked up and told me I dropped something 2 minutes earlier... doh!
abhibeckert is offline   Reply With Quote
Old 10-02-2012, 07:34 PM   #11
tnktm OP
Oddometer: 43
You guys are helping me know what I want to go read about (which I've been doing) - thanks again. If I purchase just the topo map and I load someone else's dual sport route will it be hard to follow without turn by turn directions? Also, is the detail of the more expensive smaller area topo map worth the extra hassle over the 650t with the less detailed topo map? Thanks again.
Old 10-02-2012, 07:42 PM   #12
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,660
There's really no such thing as a 'Dualsport Route'. Routes are finicky since so much depends on you having the exact same maps and routing options as the route creator. For Dualsport, you'll be using tracks, and not turn by turn routing. It's more akin to a routebook in that your gps will show you where the track goes but it's up to you to follow it.
Often the best routes are turned into tracks as a last step to ensure they work with most gps units.
I have no idea if the 24k Topo maps will be better for you as I've never seen them. I use Topo Canada.
Old 10-02-2012, 08:32 PM   #13
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,347
How do you tether a Montana?
Old 10-02-2012, 08:39 PM   #14
Twilight Error
Oddometer: 22,718
There is a slot in the case at the bottom, I used an old camera lanyard I hand hanging around.
Old 10-02-2012, 10:45 PM   #15
SmellyGoatBoy
SmellyGoatBoy's Avatar
Oddometer: 88
Check to see what topo map comes with the "t" version as the topo 100 is useless. You can not create routes or tracks using the topo 100. i had this issue when I bought my Oregon T. I then had to go out and buy the topo 24k. So, price the low end, with the topo 24. i think it is about the same as the "t" version, and is more useful.
"It is better to live one day as a lion, than a life time as a lamb."
SmellyGoatBoy is offline   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 11:18 AM.
