Old 10-02-2012, 02:25 AM   #1
dalla OP
dalla's Avatar
Oddometer: 63
Lester wheel question
Hi guys
I recently found this picture
It really looks to me like the front wheel is 18"? Is this possible? Did the ever make an 18" Lester front wheel?
Also can anyone thell me the bearing dimensions of the Lester front wheel. I am most interested in the outer diameter of the bearing seat.
And if anyone has a set, please sell them to me.
dalla is offline   Reply With Quote
Old 10-02-2012, 05:14 AM   #2
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 547
The brake discs don't appear to fill up the wheel, as it does on a 18" rim.
However, Lester did make a lot of different wheels for many brands.
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Old 10-02-2012, 05:23 AM   #3
bmwrench
Oddometer: 2,195
Those aren't Lesters. They are most likely Morris.
bmwrench is offline   Reply With Quote
Old 10-02-2012, 05:59 AM   #4
dalla OP
dalla's Avatar
Oddometer: 63
Thanks for your answers guys. Morris wheels? Sounds interesting. Any more info on them?
Any other suggestions for a set of 18" cast wheels for a BMW R90. Wheels that are not snowflakes.
Old 10-02-2012, 07:18 PM   #5
bmwrench
Oddometer: 2,195
Kosman Specialties welds rims to existing wheels. You might contact them and ask if they'll do a Lester Wheel. I believe Morris is long gone. The onle rear wheel they offered for BMWs was with a disk.
Old 10-02-2012, 07:35 PM   #6
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
I agree. I also believe the Morris mags might have been magnesium.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-02-2012, 08:09 PM   #7
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I always liked the Morris looks better than Lester. But I'm weird that way.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 10-02-2012, 11:16 PM   #8
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
That build could have square wheels and it would still look beautiful
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 10-03-2012, 06:08 PM   #9
bmwrench
Oddometer: 2,195
Nah. You're just weird.
Old 10-03-2012, 06:11 PM   #10
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,639
Heck, I have Lesters (19" front wheel) and had to look twice to see what y'all are talking about.
So, the difference between Lester and Morris was the "ribs" in the radial arms? My lester has 2, this possible-Morris has 1.
crazydrummerdude is offline   Reply With Quote
Old 10-03-2012, 06:23 PM   #11
bmwrench
Oddometer: 2,195
Lookswise, yes-or at least partially. Later Lesters have a flat rim surface which I think detracts slightly from their looks. Mechanically, I think the Morris wheels had ball bearings instead of the Lester's OEM-style tapered rollers.
Old 10-03-2012, 10:36 PM   #12
mattcfish
R90SS/6
mattcfish's Avatar
Oddometer: 253
OEM bearings
Don't Lesters use stock OEM bearings? Never had to change mine, always thought they did.
mattcfish is offline   Reply With Quote
Old 10-03-2012, 10:48 PM   #13
Boxer Metal
Mad Scientist
Oddometer: 3,521
Someone must have an old R.P.M BMW brochure showing Reg Pridmore's custom BMW's in the mid 70's? That was his wheel of choice.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-04-2012, 10:53 AM   #14
supershaft
because I can
Oddometer: 9,116
Yes they do run OEM bearings which is part of their problem on a couple of different levels. The main one being that they made the bearing spacer a bit long so that you could adjust it. Very few people did resulting in a lot of loose bearings and tank slappers.
Racers prefered Morris wheels because they prefered Magnesium wheels. Big diff over aluminum. I hot rodded a R1100S once and put Dynamag custom magnesium wheels on it. Night and day difference. I was ready for the much easier turn in but the difference in acceleration and braking was huge! Weight reduction? THE place to start is the wheels. Unfortuneately, it's an expensive place to start.
Times are GMT -7.   It's 10:26 AM.
