Old 03-29-2013, 12:42 PM   #151
blaine.hale
blaine.hale's Avatar
Oddometer: 3,068
Originally Posted by Kai Ju View Post
so you're obviously not running 38s, are you ?
The 38s are essentially the same size as the 32 Bings.
34s. Vurrry loose in the intake boot so I had to clamp down pretty far. Definitely potential for a leak.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 03-29-2013, 12:44 PM   #152
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 659
I'm running 32s and my bing hoses do just fine, no leaks. Of course, they are brand new, if that matters?
Kt-88 is online now   Reply With Quote
Old 03-29-2013, 06:24 PM   #153
blaine.hale
Oddometer: 3,068
According to the carb cleaner AND propane test, I'm leak proof everywhere.
Hmmm. Sure wish these Mikunis had a place for me to hook up my balancer.
1974 BMW R90 /6
Old 03-29-2013, 09:21 PM   #154
supershaft
Oddometer: 9,110
I would put a vacuum take off on them before I installed them. I did on my Dellorto's. Dellorto's have a very handy unused mixture screw boss to turn into a VTO. Maybe those Mikuni's have something similar? Bing and Dellorto make VTO kits.
Old 03-29-2013, 09:27 PM   #155
Kai Ju
Kai Ju's Avatar
Oddometer: 1,817
Me too, on the vacuum pick ups. I'm going to figure something out tho.
Both carbs are the same and there is a lot of acreage on the left side that could accommodate a vacuum port. That will make it easy access on the left but a bit of a pain on the right. I'll let you know what I come up with.
Kai Ju is offline   Reply With Quote
Old 04-02-2013, 09:36 AM   #156
blaine.hale
Oddometer: 3,068
Great price on a set of 32mm for anyone looking.
http://marketplace.ibmwr.org/ads/view/id/208803
1974 BMW R90 /6
Old 04-04-2013, 03:02 AM   #157
SVARTH
reset and go further
SVARTH's Avatar
Oddometer: 51
Hi there...
sorry to bother,
I have a pair of 38 cv Mikunis off my 900ss Duc (i replaced them with Keihins..) and I am thinking to use them on my 100gs PD.....
has anyone tried this conversion (CV mik not VM...)
thanks
and fly low...
R100GS PD 91'
Ducati 900ss 94'
BETA ALP 250 97'
SVARTH is offline   Reply With Quote
Old 04-16-2013, 12:11 AM   #158
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 659
Well, now my results will be useless for anybody. I am now using R100 pistons and cylinders on r90 heads, with vm32s.
This is a pretty unlikely setup.
Old 04-16-2013, 12:59 AM   #159
Kai Ju
Kai Ju's Avatar
Oddometer: 1,817
How does it run ?
Old 04-16-2013, 07:53 AM   #160
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 659
How does it run ?
Well, I'll let you know today. So far fantastic but that's less than a mile of testing.
Old 04-25-2013, 06:03 PM   #161
blaine.hale
Oddometer: 3,068
I'm not having much luck in the tuning department. Still bellowing black smoke out of both sides, despite being 4 turns out now on the mixture screw. Then there's the weird habit where it will start up and idle just fine but if I go for a 2 minute ride, it won't idle anymore...just dies.
Then there's both sides being completely out of sync. No amount of cable adjustment seems to be aiding.
hmmmm
1974 BMW R90 /6
Old 04-25-2013, 08:05 PM   #162
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,298
hmmmm
What main and pilot are you on right now?
Old 04-25-2013, 11:27 PM   #163
oldroadie
Two wheel addict
Oddometer: 468
That sounds like the pilot jet is too large, black smoke and dull exhaust note.
oldroadie is offline   Reply With Quote
Old 04-26-2013, 01:10 AM   #164
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,771
hmmmm
I would think you should be a lot closer to 1 to 1 1/2 turns out on the mixture screw. The reason it dies after a short ride is the carbs are too rich.
The cables do need to be set to keep the carbs synced at least till the rpm has come up a bit, However, the carbs should be synced by turning the slide adjustment screws. these are fine adjust, and allow for easy sync.
Sorry if I'm talking basics you already know. But, it sounds like your still a ways off.
Old 04-26-2013, 07:44 AM   #165
blaine.hale
Oddometer: 3,068
I figured as much. I found out that I'm running a 35 pilot...which some of you r100 folks are running. I'm seeing the trend that the r75 folks and r80 folks are running a 30. Luckily, Jenna loaned me some jets and there's a 30 pilot in there to try out <3
1974 BMW R90 /6
Times are GMT -7.   It's 12:30 PM.
