Old 05-13-2013, 07:22 AM   #196
amschnellsten
Oddometer: 93
Idle=good
Idle to half =good
Wot= good.
Half to almost wife open = sluggish and I think lean.
I adjusted the needle height but that actually only effects up to half ish throttle. I am having problems past this range. I guess that would be needle jet or maybe a half size main would work.
amschnellsten is offline   Reply With Quote
Old 05-13-2013, 09:27 AM   #197
Uncle Pollo OP
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,548
Originally Posted by amschnellsten View Post
It's me again. I have been swapping main Jets and I am getting somewhere. I synched the carbs this morning and started over. I started @ 190 mains and the bike barely went down the street. I spent the day going up and down and ended up with a 200 main that seems to work pretty well. Here is my problem..... idle, 1/4, and half throttle feel spot on. 1/2ish to 3/4 feels crappy and wot feels pretty good.
I ran a 190 main jet and it was lean and the 200 feels pretty good but I did not try a 195. Should I get a 195 and see what that does for my problem?
Or does it sound like my needle and needle jet combination is off. I am running a 6dh4 needle and a 159 p-0 neddle jet. I have a 6dh3 needle, should I try that or should I try some different needle jets. I am not getting how these are coded according to rich or lean.
Sorry, one more question. Where can I add a barb for vacuum?
6F4 needle is what I have and is the most even taper needle that mikuni makes.
START with that one ... and probably that will be it.
Uncle Pollo is offline   Reply With Quote
Old 06-19-2013, 11:13 PM   #198
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
Am I missing something
Ok the carbs on the RS mono were in need of a rebuild ... bad fuel economy and more importantly it was running out of legs at just before the Ton.
Saw a nice near new pair of 34 mm Mikuni on Ebay so I thought I would give them a bash. There are pre set at
210 main jets
35 idle jets
6DH4 jet needles
169-P0 needle jets
2.5 slides (piston valves)
I think they are Rocky Point ( by way of the nice cables ) .
Anyhoo threw them on today ... kicked it over and it idled nicely ... took it for a short burst ... and all seems well.
Am I missing something or am I incredibly lucky to have it working straight out of the box ???
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 06-19-2013, 11:59 PM   #199
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 889
I'm at 185 / 30 main and idle and I'm running super rich on my 1050cc vm34 setup.
Kt-88 is offline   Reply With Quote
Old 06-20-2013, 12:16 AM   #200
supershaft
because I can
Oddometer: 9,116
I think we have need to include our airbox setups when sharing jet info. They change everything.
Old 06-20-2013, 02:57 AM   #201
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
Using the K&N pods until I can find some tubing to connect to the airbox.
Running at sea level .
Will do a quick blast around the block ( about 100km's of back roads ) to see how it goes tomorrow ... weather pending.
SS I do understanding about going a tad bigger than the 34's .. but at the price I got all of this ... it was too good an offer ... Will be going to 38 Dells when I warm up the RS some ... and move these 34's to the LT
Old 06-20-2013, 07:51 AM   #202
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 889
I'm running the stock airbox.
Old 06-20-2013, 07:59 AM   #203
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,607
VM34, stock air box, stock intake tube, 2"->2.25" silicone reducer with 1cm cut off both ends, intake tube cut off just inside of reducer. Reducers came from siliconeintakes.com and are heat/fuel proof.
(Yes, the battery is currently ziptied on. Yes, I know that's not a good idea)
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 06-20-2013, 10:25 PM   #204
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
So I tried to start the bike this morning after a night of below 0 C and thick fog . It took awhile to finally kick over with a few back fires ... and I was thinking that I spoke too soon about the set up.
Once I got it going for a quick spin on the back roads for 100 km's ... and WOW what a difference ... REALLY REALLY fun to ride now ... especially in the 120-160 km zone ... just a delight. So much fun coming up behind a pack of 6 HD's and zipping through them ... I don't think they were as impressed with the bike as I am.
Only complaint that after a bit of hard riding ... coming to a complete stop .. it idled at 2000 rpm's for a sec before going down to 1100 rpm's.
It has me thinking that I will probably scrap the idea of going for a 1070 kit later in year and just getting some high compressions pistons ... and spend that money towards better Shockies and getting Dell 38's for the RS and move these 34's to the LT.
The Bing are going into deep storage now ... may never see the light of day again
Old 06-21-2013, 07:37 AM   #205
rockitdoc
rockitdoc's Avatar
Oddometer: 402
R90S with Mikunis?
Anyone know if 34mm Mikunis will work on an R90S?
If not, which Mikunis are recommended? I've pretty much given up on my Del's. They go on the shelf for originality if I want to later.
'60 BSA Gold Star Clubman,'76 BMW R90S,'77 BMW R100RS, '85 Laverda RGS1000SFC
rockitdoc is offline   Reply With Quote
Old 06-21-2013, 07:44 AM   #206
Airhead Wrangler
Adios Mexico
Oddometer: 6,607
I'd stick with the dells. 34s would work. I run them on my 1000cc motor and they work really nicely, but I'd be willing to bet your 38mm dells would work better. What about them is giving you problems? Have you tried disabling the pumps on them? That seems to be a pretty popular (necessary?) mod when using them on airheads.
Old 06-21-2013, 12:16 PM   #207
supershaft
because I can
Oddometer: 9,116
I think 36's or 38's are the size to use. 34's are too small. Low end performance? 38 Mikuni's or Dellorto's have way better low end performance than 32mm Bings AND way better top end. Why just look at your cake when you can eat it too?
Personally, I run Dellorto's. I think Mikuni's might perform a tad better? Not much if any. The advantage in Dell's IMO is that they fit the stock airbox snorkels perfectly and you can use R90S cables. I have seen a lot of dirt get by setups getting Mikuni's run back to the airbox! Disconnecting the pumps in Dellorto's isn't necessary at all. On my own bike? I disconnected the pumps for a lot more power. Better mileage and easier throttle turn were added bonuses!
Old 10-02-2013, 05:55 AM   #208
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,583
Bumpetty-Bumpersons for this thread.
Found a set of VM32's and since my GS's carbs REALLY needed a rebuild ... I'm throwing them on. The GS is small valve, and dual-plugged. Should be interesting. I'll be starting the tuning tonight. The VM32's came off a heavy flywheel R80 ... and that bike was a screamer.
Both my bikes will be 'Mikunied' ...
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 10-02-2013, 08:42 AM   #209
blaine.hale
blaine.hale's Avatar
Oddometer: 3,267
I still have the treasure chest of jets. I'm close to reassembling the r90 and jetting my mikunis but lemme know if you need them. I can run them over any time.
1974 BMW R90 /6 | 1968 Bultaco Matador MK3 | 1973 BMW R75 /5 Toaster LWB | 1966 Ducati 250 Monza | 1976 Ducati 860 GT | 1977 Moto Guzzi LeMans 850
blaine.hale is offline   Reply With Quote
Old 10-02-2013, 11:19 AM   #210
Beater
Beater's Avatar
Oddometer: 3,583
You gonna be home today around 6p? I can drop by ...
Times are GMT -7.   It's 02:20 AM.
