Old 03-04-2013, 06:17 AM   #46
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,097
Originally Posted by oldroadie View Post
The old rule of thumb is one groove on the needle equals three main jet sizes.
Who made that rule? Needle position and main jets aren't adjusting the same thing at all. Your needle regulates mix from idle all the way up to WFO, Whereas your main jet just limits the amount of gas at WFO and just below.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Airhead Wrangler screwed with this post 03-04-2013 at 06:30 AM
Old 03-04-2013, 07:30 AM   #47
oldroadie
/5 dirt road wannabe
Oddometer: 341
Moving the clip changes the fuel mix by a factor of 5-8%. So maybe in Mikuni terms that's a skosh over two sizes, rules of thumb aren't truly precise and VM jets aren't available in 2.5 increments, only in 5s. Still every move he makes is 8% of 190 at the baseline. 8% of 190 is slightly over 15 and that's three jet sizes. Or it could be 5% and thats 9.5 so it's two jet sizes. Damn rule of thumb variance.
It is true that the main jet determines max fuel flow at WOT but it also determines the baseline that the needle begins with, nothing can change that fact. Then the taper and clip height come into play.
Bottom line, all of the circuits in a Mikuni interact except the "enrichner" which is a totally independent circuit.
Ref: chart 13 page 9 Mikuni tuning manual
oldroadie is offline   Reply With Quote
Old 03-04-2013, 05:01 PM   #48
supershaft
because I can
Oddometer: 6,056
+1 I have head the 'one notch equals two needle jet sizes' before. Which is complete BS too but at least I can tell where they are coming from.
The bottom line is that unless you have a too lean main jet. Jet needle adjustment will not effect the main. Sure jets overlap and different combos of jets should be tried if best performance is your goal but . . . .
Old 03-04-2013, 08:01 PM   #49
Uncle Pollo OP
Von Hochstaden's son
Uncle Pollo's Avatar
Oddometer: 44,968
Originally Posted by DeutschMark View Post
Keep an eye on that coolant hose. It might not stand up to ethanol.
If it fails I will know rather quickly.
mikuni vm32-33 both sides :\ 5000 feet altitude/
140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide
35 mpg around town riding like a asno
Uncle Pollo is offline   Reply With Quote
Old 03-04-2013, 09:03 PM   #50
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 3,782
Can Mikuni jetting numbers help me tune a Keihin? If the jets are measured in the same unit, it ought to at least get me in the ballpark right?
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-05-2013, 05:06 AM   #51
oldroadie
Oddometer: 341
I think they use different measurements; one company by diameter and one company by flow. What kind of Keihin? I've had a few CV types and those tune the same no matter what they're on.
Jet needle height adjustment affects the flow, main jet restricts the amount. Bigger mains allow more fuel into the needle jet, smaller mains allow less. Higher needles allow more fuel flow, lower needles allow less. A low needle and a big main or a high needle and a small main work pretty much the same until you reach WOT. Such an easy concept, even a super tuner such as yourself should recognize this.
oldroadie screwed with this post 03-05-2013 at 05:17 AM
Old 03-05-2013, 08:51 AM   #52
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 3,782
These are flat-slides. Similar carb to the Mikuni TM that Jenna has. She had more bling than me and it was making me feel inferior Call it 'keeping up with the Jennas" After I get the carbs sorted out I'll start feeling bad about how she has bigger forks than me.
Old 03-05-2013, 12:12 PM   #53
supershaft
because I can
Oddometer: 6,056
I can recognize how someone might think that until they tried it.
Old 03-05-2013, 01:26 PM   #54
oldroadie
Oddometer: 341
Then you should document your experiences to the contrary and enlighten us.
Old 03-05-2013, 02:39 PM   #55
supershaft
because I can
Oddometer: 6,056
Would a picture of me holding a jet above a work bench with a micrometer and a shiny new Snap-On 8mm wrench in the background help? Maybe a clean BMW tool kit rag spread out underneath it all? Then it would be gospel! On the idiotnet at least.
Old 03-05-2013, 02:58 PM   #56
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 3,782
I love not knowing anything. I never get in arguments
Old 03-05-2013, 05:27 PM   #57
supershaft
because I can
Oddometer: 6,056
The smarter you get the dumber you are.
Old 03-05-2013, 05:40 PM   #58
oldroadie
Oddometer: 341
No. Your noted experiences with the 26 variants of the #159 needle jet would work. The documentation from the Mikunis on your personal airhead would work.
Examples of successful installation of Mikunis on customers bikes would work.
oldroadie screwed with this post 03-06-2013 at 04:19 AM Reason: Removed insult.
Old 03-09-2013, 11:09 AM   #59
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 351
Back on track. I'm going to do a good hour test ride today up some mountains and get more precise answers on what clip position and mix screw adjustment do to rideability.
I am hooked on the instant starting I experience now. Feels like I don't even get a full spin of the engine before it fires to life.
Kt-88 is offline   Reply With Quote
Old 03-09-2013, 03:10 PM   #60
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 351
Okay. Good forty mile ride up and down some mountainy roads and here are my thoughts:
The whole damn thing is too rich. I have no snap or feeling of real torque. Sure it's smooth, starting is great, and it's certainly adequate for commuting, but I will need to go down on both main and pilot jets.
I'll have to research and see if the slide/needle/needle jet is correct, too.
Times are GMT -7.   It's 12:47 AM.
