Old 09-10-2012, 10:37 PM   #1
2VEZR25 OP
Recuerde el 911
2VEZR25's Avatar
Oddometer: 52
Engine cut out at 60 MPH.
Anyone got first hand experience as to what the might cause of a brief engine cut out when running at speed?.. It occurred several times recently while out on a ride while traveling at 60mph. Just as quick as the motor cut out it would start again. It had been running fine all day when the fault came in 3 or 4 times and then things came good again and ran sweet for the rest of the day??.. Bike is a 91 R100RT. It hasn't been messed with in terms of wiring and it wasn't so long ago that I went through all of the connections to make sure everything was clean. The ignition module was serviced recently with heat sink paste and the electrics have never played up before. Anyone with similar experience find a likely suspect?
2VEZR25 is offline   Reply With Quote
Old 09-10-2012, 10:55 PM   #2
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 912
Intermittent electrical issues are a bixxxxch to find. First check the simple stuff like battery connections and ground connections Next try wiggling the ignition switch, stop switch and clutch switches to see if you can make it happen again. If no luck there I'd start cleaning all the connectors and wiring harness since its about time anyway. Best of luck.
__________________________________________
"There's a fine line between a skinning and a shearing"
RecycledRS is offline   Reply With Quote
Old 09-10-2012, 11:55 PM   #3
pommie john
pommie john's Avatar
Oddometer: 1,115
I'd be looking at fuel filters too.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 09-11-2012, 02:18 AM   #4
carpetburn
Oddometer: 110
water in your fuel, check filters as mentioned and drain tank into a clean white bucket[so you can see water]
carpetburn is offline   Reply With Quote
Old 09-11-2012, 04:17 AM   #5
bikerfish
flyfishandride
Oddometer: 970
I've had that happen and in my case it was the bean can. That said, best to start with the simple and cheap things first, like said above, fuel filters and such. drop float bowls, etc. Also, ground wires.
bikerfish is offline   Reply With Quote
Old 09-11-2012, 06:59 AM   #6
RaystheBMW
1986 R65
RaystheBMW's Avatar
Oddometer: 55
I've had a few such events and it's very disconcerting. In my case it was the ignition module heat sink paste, not once but twice. The first time I used some leftover hobbyist silver stuff meant for computers. That worked fine for a few months, but when the exact symptoms happened again, I took it back apart and replaced it with the white stuff (sorry I don't have the brand name). It's been several months now, and hasn't missed a beat since.
RaystheBMW is offline   Reply With Quote
Old 09-14-2012, 05:54 AM   #7
2VEZR25 OP
Recuerde el 911
2VEZR25's Avatar
Oddometer: 52
Thus far
Thanks for the suggestions people. Checks completed so far; Tank has been drained, fuel filters & float bowls checked. No water or restrictions were seen. Ignition module removed and heat sink paste checked (OK) and replaced again just as a matter of course. Ignition switch wires wiggled with engine running and all is in order. Will have to monitor for a while and carry a few more spares.
Old 09-14-2012, 06:23 AM   #8
97oilhead
97oilhead's Avatar
Oddometer: 174
Did you check the battery and ground connections as suggested?
'05 R1200RT
'00 R1100S
'01 R1200C Phoenix
'95 R100R Classic
97oilhead is offline   Reply With Quote
Old 09-14-2012, 06:37 AM   #9
eepeqez
eepeqez's Avatar
Oddometer: 2,027
I've had a 1984 R65 do that because of corroded battery leads...
eepeqez is offline   Reply With Quote
Old 09-14-2012, 06:56 AM   #10
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 789
Fuel cap venting?
baldwithglasses is offline   Reply With Quote
Old 09-14-2012, 07:08 AM   #11
trophymoto
MACDADDY!
trophymoto's Avatar
Oddometer: 395
coil cracks?
trophymoto is online now   Reply With Quote
Old 09-14-2012, 07:42 AM   #12
mykill
odd
mykill's Avatar
Oddometer: 1,092
Is it just the engine cutting out or are any lights going out? You say it dies briefly and restarts. Does this mean you poke the starter and it starts up or you let the clutch out and it resumes? is it just a hiccup?
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 09-14-2012, 08:09 AM   #13
eepeqez
eepeqez's Avatar
Oddometer: 2,027
Cracked coil failure (also Hall effect pickup in the beancan failure) tends to stop dead and not go.
Fuel cap not venting tends to be very variable depending on the volume of air in the tank, and is much less sudden than electrical issues.
When I had similar symptoms on my R65, the alternator warning lamp would come on when the ignition died (because the Df terminal of the alternator was powered by the alternator through the diode board and the other items on the ignition switch provided an earth path) and everything else would go out.
The visible effects of a +ve terminal failure are almost exactly the same as turning the ignition or kill switch off with the motor running.
Seriously, check the things which are most likely and simplest to check first. Usually this means check the fuel tap and kill switch! In this case, obviously make sure your kill switch isn't getting dodgy by gently wiggling it and seeing if it kills the motor when it shouldn't.
Then check for corroded battery leads and terminals including terminal fittings which are not making good contact with their leads, which are not visually obvious but are easy to check and are likely to cause exactly the symptoms described.
Old 09-14-2012, 10:11 AM   #14
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,532
Originally Posted by baldwithglasses View Post
Fuel cap venting?
Ha ha, always the first thing I think of! First time I saw it, I was so surprised I slapped my forehead....Doh! Mine was the tank bag sealing around the cap.
I saw a lot of tanks destroyed when I worked at the Ducati / Yamaha dealer, bad gas cap vents, caused the tanks to implode when brought in out of the sun!
Old 09-18-2012, 04:57 AM   #15
2VEZR25 OP
Recuerde el 911
2VEZR25's Avatar
Oddometer: 52
Findings so far
Thanks guys for all of your suggestions. To answer a few of your tips; Yes the ground terminals and all connections have been checked. I found one of the main connectors plugs was not making full connection and so I suspect this may have been the problem. I agree that the hall trigger would more likely have been either working or not rather than it being and intermittent factor. At least that has been my previous experience with failed hall triggers. I will test it again now the the wiring connector has been properly seated and wait to see if the symptom returns. I am not suspecting any fuel venting issues at this stage as the engine cut out was too sudden and not typical of any fuel starvation issues.
Regards further ignition system diagnostics; I was in the process of trying to remove the #5 pin from the ignition module harness plug to test for voltage, as per the workshop manual, but I found that I could not lift the one way locking detent from the plug.. I was using a piece of thin flat stainless steel filed to fit in the channel where the detent should be, but no matter how I tried to poke and prod I was not able to lift it. Has anyone got any advice on how to best remove the #5 terminal wire from the plug connector?
Times are GMT -7.   It's 03:06 PM.
