10-03-2012, 11:38 PM
#16 | |
Mercedes
Oddometer: 515
Also, meant to say to the OP. On the bigger bike, 'Stand Up', I'm sure you do that a lot on smaller bikes in the gnarly stuff, but it will help you to get the feel of the bigger machine, particularly if you are doing that in the drier more compact stuff for long period. IMHO it's a good way to get to learn the bike. S1
1975 Suzuki GT750A, 1986 Kawasaki KL600, 2001 BMW R1150GS, 2011 Husqvarna TE630 The Great Pacific Northwest SPOT map (Automatically updates in real-time) ; http://www.advrider.com/forums/showthread.php?t=719703 |
10-04-2012, 03:58 AM
#17 | |
Oddometer: 1,116
If you watch that Touratech video with the pro rider and the sand tyre, watch it in slow motion and you'll see he hits the throttle just prior to turning, and he tends to hold the bike a little more upright and actually "steer" until the front end starts to bite. Once he has the traction he starts to tip in more. Sort of "body in, bike out" style. Reminds me of MX and slippery berms a little. It seems to work with the weight and balance of the F800. I notice far less instances of the front wheel seeming to push out from under me. Technique is everything, and everything is technique. At least that's what one of my Warrant Officers used to yell at me while throwing grenade simulators at me. |
10-04-2012, 04:08 AM
#18 | |
Unreasonable
Oddometer: 2,246
TransLab a Go Go 2011 Nova Scotia Fresh Air Inspectors Investigate the Cabot Trail "Second star to the left and straight on till morning” ― James T. Kirk |
10-04-2012, 10:31 AM
#19 |
NoMoTDM still Gary
Oddometer: 3,711
Most of my summer riding in the hood, looks like this: Hard pack with an overlay of gravel. A tire like a Shinko actually works better than a semi knobby, at least on the rear. Knobbys made the bike skittish. My theory, more contact area.
![]() Some times you have to much of a good thing, especially if there is a hill involved. Knobbys work better. ![]() They also work better in soft snow ![]() In sticky mud, nothing works well ![]() The point is the bike is capable of it, if you are having problems, it is probably you more than the tires. I think the bike is designed for a stand up rider in order to weigh the front tire. The front is light 47 vs 53% according to http://www.mcnews.com/mcn/features/2011AugTriBMW.pdf, more if you are a sit down rider. Various ways to fix that. More preload on the rear, slip the tubes up 1/2" or some combination of both. Irritating, but if you weigh over 185lbs, respring it. Snowy is right about turns, stock set up and the bike runs wide and the front won't hook up unless you are over the tank. Set up or mods compensate to some extent. It will not tolerate backing off the throttle in really deep/loose conditions. In sand, silt, and deep gravel it will go where it wants, unless you apply some throttle. Don't grab a fistful, just enough to accelerate. In sand you want to get it up to planing speed. How fast, depends on the type, depth, wet or dry, it differs. The only constant is you need more speed than a lighter bike. There is merit in learning to ride on a smaller bike, but it still a different skill set involved. It is a tall heavy bike, you not going to horse it around unless your name is Schwarzenegger. There is a relearning curve. Practice, once you have confidence in it, it is quite capable. I personally don't see enough difference in tire brands to make me any better rider. They either got knobs or they don't. If they do, the ones that have longer knobs more widely spaced hook up better in loose stuff. Maybe that is why I spoon on different ones all the time, searching for that perfect tire. I think TKC's are a compromise tire. A brand I keep going back to, because if you are truly on adventure, who knows what the terrain will look like?
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." itsatdm screwed with this post 10-04-2012 at 09:26 PM |
10-04-2012, 11:51 PM
#20 |
Oddometer: 1,116
Throttle control, and the effect on the bike as a whole was brought home to me the other weekend.
I got about 40 mins up a steep, muddy and rock strewn fire trail, and I was fairly focussed on staying upright, when I realised that I had about 10 mins of smooth red clay/very steep section to climb out of it all. Lots of rain over the preceding 2 weeks meant it was going to be acres of fun. I thought over the sense of turning back, plotted the length of the detour in my mind, looked at the fuel gauge, recalculate, extrapolate, fudge factor.....oh shit. OK then, lets get on with it. On the climb out I used everything I've learned about keeping a big fat skaty bike upright on smooth wet steep red clay. The E07 rear has nearly 9000km on it and about 6mm tread depth left at the centre. The Pirelli Scorpion MT90AT on the front is about 4000km old and in fairly good condition. It was all throttle control. At times it wouldn't turn and I was on and off the throttle searching for the right amount of load on the front, trying to stay upright, trying not to stall at really low revs in 2nd as I searched for more torque. It gets a bit funky when you are fast running out of track coming into hairpin turns. Downshift to 1st and wheelspin to a stop. The only surface I've ridden on that was worse is frozen red clay. That hurt. I think my friend recorded 5 face plants from me on the BMW that morning.Plus, 3 stall and falls while climbing over snow covered logs. 1 cross rut and face plant in a frozen puddle when the ice broke half way across. 1 slide off track into bush at the bottom of a long descent with an off camber right hand hairpin. It gets old fast. I was getting very cranky. One second upright...the next second on face. I've found that knobbies make very little difference on this type of surface. BMW and snow riding isn't something that you should "just go and have a crack at". You need to learn a little more about big heavy bikes and limited traction first. It doesn't snow here much. Thankfully. I've done it 2 up and I am still amazed by how completely wrong it can go and how fast it goes wrong. Try doing a 360 when you are 2 up with gear rolling along the track at about 50 kph. See what that does for your heart rate. See what that does for the knee you had a reconstruction on when you slap the foot on the ground and take all the weight while dragging your boot sideways. My wife insisted I stop IMMEDIATELY. I couldn't. I had dislocated my knee and my boot was dragging along the ground next to the bike. It didn't tickle. Took a while to fix. I was a tad worried, as I couldn't get off the bike, couldn't really stop with the load I had on. I stood up on my left leg and let the right hang and jiggle until it seemed to fix itself. It didn't hurt as much, but it still hurt like crazy. You ride along and you think, "yep, I've got it all under control" and then it suddenly just spins around and around and everything you do has the exact opposite effect. You realise that you never had control at all. It's an illusion. You are always that fine line away from failure when there's ice and snow in the equation. But I suppose some of you Northern Hemisphere types already know that. Ahhhh....ridiculously heavy fully loaded bikes and frozen dirt roads....what's not to love? ![]() This is pretty much most fire trails within 500km of my front door. There's a few of them. Unfortunately the Forestry workers use red clay as the base and cover it with gravel that ranges from 1/2 inch ball bearing stuff, to base ball and even house brick sized stuff in the really wet spots. Long steady gradients tend to end up as smooth red clay wheel ruts. Then winter comes. Not so good. Snowy screwed with this post 10-05-2012 at 12:00 AM |
