Old 10-03-2012, 03:57 PM   #1
Kingsized OP
Kingsized Adventurer
Kingsized's Avatar
Oddometer: 792
Ohlins 436 question
I installed these Ohlins about a month ago and today had my seat off working on something else. I noticed a pin sticking up from the top of the shock about a half inch near where the remote pre-load adjuster is located. Can anyone who has a GS and this shock run out the garage and tell me if theirs is sticking up like this? I tried to press it down but it seems pretty solid.
Kingsized is offline   Reply With Quote
Old 10-03-2012, 04:03 PM   #2
Jazz62
Jazz62's Avatar
Oddometer: 1,061
Different bike and shock but the Ohlins rear shock I put on my '07 Multistrada 1100 had the same. Maybe 1mm shorter but that's it.
Jazz62 is online now   Reply With Quote
Old 10-03-2012, 04:03 PM   #3
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 992
That pin is necessary for the hydraulic preloader slave to function correctly and not change its clocked position. As you crank the preload knob watch the pin descend to a nearly flush position with the spring seat.
It's completely normal.
As a sidenote - I noticed that the bolt socket-head was rounded somewhat. Next time you remove the shock, loosen the nut first before cranking on the ratchet. That will save you from damaging the socket head further.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 10-03-2012, 04:14 PM   #4
Kingsized OP
Kingsized's Avatar
Oddometer: 792
Cool, thank you both. Amazing what little I know sometimes.
And, yes, I had some great help with the install but heavy handed. I didn't install the rear. I was putting the front back together and my friends worked on the rear and I saw the same thing. When I take it off for rebuild in the future, I'll probably order a replacement bolt.
Than you again!
Times are GMT -7.   It's 01:06 PM.
