Old 10-03-2012, 04:45 PM   #1
Yachtie OP
Oddometer: 105
Tach Ratio?
Might be doing a tach and speedo swap and was told before ordering to find out our tach ratio. Any ideas? My bike is a 76 r90/6
Yachtie is offline   Reply With Quote
Old 10-03-2012, 07:37 PM   #2
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
Here are final drive vs speedo ratios....not sure about "tach" ratios...
ratioring/pinion teethrpm @55mphrpm @70mphspeed @7200rpmspeedometer ratiousual model
2.9132/11305038811301.078R100
333/11314740051261.112R90S-R100
3.0934/11324141251221.144R90-R100/7
3.232/10335742731181.186R75-R80
3.3637/11352544861121.244R60-R75
3.4431/9360845921101.259
3.5632/9373447521061.318R60-R65
2.6234/13This was for racing, /5 and later
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 10-04-2012, 05:23 AM   #3
Yachtie OP
Oddometer: 105
Thanks. So here's another question, the speedo they carry that I wanted to go with has a ratio of 2240 rpms @ 60 MPH. Would I run into any significant issues with that? They carry tachs In a 1:4 1:5 1:7 an they think a 1:5 will work.
Old 10-04-2012, 07:10 PM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,156
You'll need a speedo that reads 60 when the cable spins at 1,144 RPMs. That is, if you've got the stock ratio final drive.
The tachs are all 1:2. In other words, the tach spins half engine speed.
Old 10-04-2012, 07:51 PM   #5
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,517
Since the tach is driven off the cam shaft which is turning one haft crank speed aren't the tachs spinning the same as cam speed? If the tach is spinning 1: 2 then it would be spinning 1: 4 to the crank or engine RPM.
---Albert Einstein
disston is online now   Reply With Quote
Old 10-05-2012, 07:09 AM   #6
Wirespokes
Wirespokes's Avatar
Oddometer: 8,156
Good point, Charlie! The tach would spin 1/4 engine RPM.
Old 10-05-2012, 08:17 AM   #7
Yachtie OP
Oddometer: 105
Great! SO 1:4 it is! Thanks so much guys!
Times are GMT -7.   It's 09:17 AM.
