Old 10-28-2012, 06:52 PM   #1
Rockman OP
Oddometer: 228
R80/7 clutch problem
I am in the process of reassembling a R80/7 I got as a semi basket case. I put the flywheel, clutch and gearbox back on. All seemed well. Bike starts and runs well and at first the clutch seemed fine. Suddenly though, the cluch freeplay increased a lot, and the bike now issues a graunching noise when I pull the clutch lever and pulling it right in can stall the motor. I cant see how I could have mis-assembled it but maybe I did.
If I dont touch the clutch lever all is well. It starts and runs as it should and the gearbox changes through all gears without problems.
Obviously the gearbox and probably clutch has to come out, but has anyone got any suggestions as to what is going on?
Rockman is offline   Reply With Quote
Old 10-28-2012, 07:08 PM   #2
pommie john
pommie john's Avatar
Oddometer: 1,113
I'd have a look at the thrust bearing ( throwout bearing) before I pulled the 'box off.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 10-28-2012, 07:13 PM   #3
Rockman OP
Oddometer: 228
Did that, its ok. Pulled the push rod out, its ok. Dunno what the problem is.
Old 10-28-2012, 07:16 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 4,980
This doesn't make sense. You kill the motor by pulling in the clutch lever, but you can shift the bike with out using the clutch lever? Actually it is possible to shift the bike w/o the clutch except for getting it out of neutral.
It does sound like you had the gear box with all the throw out pieces in the trans and maybe you put this in the bike with out removing them for cleaning and greasing. You can do that now with out removing the box. Leave the long rod, #1, in place but take out the thrust pieces and bearing. It's possible you need a new bearing. If this stuff is dry and/or corroded it can destroy the transmission rear cover.
---Albert Einstein
Old 10-28-2012, 07:23 PM   #5
Rockman OP
Oddometer: 228
Yes thats my problem, it doesnt make sense. And yes I have all the bits in the diagram above and they are all in good condition as far as I can see. The drive shaft is still diconnected, so its not a big problem to pull the box off and have a look so I'll do that I think.
Old 10-29-2012, 04:47 AM   #6
Rob Farmer
Rob Farmer's Avatar
Oddometer: 3,733
I'm not saying this is the issue but I had similar symptoms when the spot welds came away on my clutch. I only found the problem when I removed the whole clutch. If you're completely out of ideas when you've checked everything else it may be worth a look.
Rob Farmer is offline   Reply With Quote
Old 10-29-2012, 05:18 AM   #7
FR700
Heckler™©®
FR700's Avatar
Oddometer: 3,459
Was the crank chocked ? ... thrust washer fall off the back off the crank ?
Increased free play may suggest that the crank is moving forward taking the clutch and flywheel with it. Is the flywheel hitting the back of the engine block ?
I'm diagonally parked in a parallel universe .
FR700 is offline   Reply With Quote
Old 10-29-2012, 03:02 PM   #8
Rockman OP
Oddometer: 228
You've hit the nail onthe head there. I was looking through the box of bits that came with it last night and found the thrust washer . Took the gear box and clutch off. I'll order a new rear main seal before I go any further as I'll probably destroy the old one getting it out. At least I know what the problem is now.
Old 10-29-2012, 03:11 PM   #9
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,090
d
You guys are talking about two different things. Sounds like you left out the clutch spacer (not a thrust washer). If the thrust washer had fallen out of it's locating holes on the back of the block and you torqued down the flywheel, the engine wouldn't even turn, it would be locked, so it's not that. What you found in the box is #5 below, right? It belongs between your flywheel and #12
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Airhead Wrangler screwed with this post 10-29-2012 at 06:22 PM
Airhead Wrangler is online now   Reply With Quote
Old 10-30-2012, 03:50 PM   #10
Rockman OP
Oddometer: 228
Originally Posted by Airhead Wrangler View Post
d
The parts I have loose in my box of bits are 1 and 3 places forward of the seal - round plate with holes in it and round plate with copper? segments. I might also have #5, not sure..
I havent had time to pull the flywheel off yet but will on the weekend. Obviously something is missing, just not sure what.
Old 10-30-2012, 04:51 PM   #11
FR700
Heckler™©®
FR700's Avatar
Oddometer: 3,459
How much end float does the crank have now ?
from maxbm' -
http://www.maxbmwmotorcycles.com/fic...2&rnd=08102012
Old 10-30-2012, 05:56 PM   #12
Airhead Wrangler
More tacos than you
Oddometer: 5,090
Sounds like FR700's right then. Yikes. It might be time for a larger tear down. Pull that flywheel and see what's there... or more importantly what's not, I guess.
Old 10-30-2012, 08:49 PM   #13
Rockman OP
Oddometer: 228
Yup - weekend coming up. Funny thing is that it runs well - no odd noises. I'm still hoping for something simple.
Old 11-04-2012, 03:22 PM   #14
Rockman OP
Oddometer: 228
OK - pulled flywheel off. Bad and not so bad. The flywheel has been rubbing on the two pins that hold the thrust washer in place. The flywheel is scrap (bits of the pins stuck to the back of the centre flange) and the pins are sheared off, but there is no damage to the crank case. So, I need to extract the remnants of the pins, fit new ones, put the thrust washer in place, get a new flywheel and rear main seal, and reassemble from there. First trick is to get the old pins out.. I think I'll pull the motor out of the frame so that I can get a good go at it. Frame needs repainting in any case.
Old 11-06-2012, 06:18 PM   #15
FR700
Heckler™©®
FR700's Avatar
Oddometer: 3,459
So how are you going to check the front thrust washer for condition without taking the crank out ? The crank walked forward and the odds of the front one staying in place are slim. The omission of the rear one allowed the flywheel to be tightened without binding the crank.
... if all else fails my k is sidecar ready ... I'll be getting rid of it shortly. Either sell it in one piece or break it down to small ones that fit in a rubbish bin
Times are GMT -7.   It's 05:23 PM.
