Old 02-07-2013, 03:03 PM   #1
bastimentos OP
Oddometer: 87
17x4.25 or 18x4.25 wheels for greatest choice of tubeless tyre?
Hey gents,
So I am building a nice F800GS and have a good deal on either a 17x4.25 or 18x4.25 rear wheel to run tubeless tyres.
I know very little about wheels and tyres, and was hoping that some people that do could help me understand which choice of these specific sizes (none other are available in my offer) would open up the greatest selection of tubeless tyres for the F800GS?
Looking for the 50/50 tyres like a TKC80 etc
Really appreciate the help, thanks!
bastimentos is offline   Reply With Quote
Old 02-07-2013, 03:31 PM   #2
picard
engage!
picard's Avatar
Oddometer: 673
with that width rim your recommended tire size will be 150/70. I would think that 17" would offer you everything tubeless out there in that size. Also with that big a tire you might run into clearance issues when going to 18"
"Rumors of my assimilation are greatly exaggerated." (Capt. Picard)
picard is offline   Reply With Quote
Old 02-07-2013, 04:42 PM   #3
bastimentos OP
Oddometer: 87
Cap'n
Duly noted, one vote for the 17's registered. Thanks for the 150/70 heads up.
Old 02-07-2013, 06:01 PM   #4
bastimentos OP
Oddometer: 87
18" TL's quite hard to find in this width
Found an interesting one here from Mitas - might be the ticket combined with a 21" TKC front.
http://www.mitas.eu/index.php?strank...id=52&pid=2846
Edit: Metzeler Karoo comes in a 140/80 - 18 M/C 70R TL - not sure if this would be another option if i was desperate to replace one and they had it in stock
bastimentos screwed with this post 02-07-2013 at 09:46 PM
Old 02-08-2013, 12:29 AM   #5
LukasM
Oddometer: 4,914
What riding are you going to be doing? 17"x4.25" is a nice street size, 18"x4.25" is a bit weird because 18" tires are mostly off-road biased but the 4.25" is way too wide and will bend very easily.
If you are getting a second wheel I would keep the stocker with a street tire and then add a 18"x2.5" or 3.5" for offroad.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 02-08-2013, 07:03 AM   #6
bastimentos OP
Oddometer: 87
Lukas
Hi,
Thank you for your thoughts, I would prefer to go to a 3.5 rear for strength offroad but I do not have that option (package deal with suspension and other bits) so its the specific options listed in 17x4.25 or 18x4.25 only.
My riding will be 50/50 but I will not be riding at a speed offroad that would punish the rims, i've no deadlines when I head off pavement so I tend to travel in a more "sightseeing" pace and I hoped the wider (forged 7075 aluminum alloy) rim may hold up alright for that.
That said, would the 18" option help increase clearance and roll over obstacles easier to a degree that it would be the one to go for? I know I will have to change the gearing to accomodate it but like I said before, I ride slow so I would prefer to have a bias towards making offroad easier than tearing up asphalt :)
I appreciate your experienced opinion.
bastimentos screwed with this post 02-08-2013 at 10:06 AM
Old 02-09-2013, 04:52 PM   #7
bastimentos OP
Oddometer: 87
Screw it, I can't find anything worthy aside from the E09 Dakar - but that looks like it will do the trick so 18" it is
Old 05-06-2013, 08:21 AM   #8
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 1,003
I was slabbing home on my '09 F800GS from Ohio to central Pennsylvania last night, and I thought that if I had a flat at 11:00PM alongside the Pennsylvania Turnpike in 40F degrees, I'd be wishing they were tubeless. I have two sets of wheels, and had swapped out the TKC80s for the Scorpions because I knew this trip would be paved roads only. It brings me back to considering sending one set to Woody's Wheelworks to install a new front rim and sealing both so I can run one pair of street tires without tubes.
But then again, I don't use the street tires very often. Decisions, decisions....
Fred
FredRydr is offline   Reply With Quote
Old 05-06-2013, 02:56 PM   #9
rmhrc628
rmhrc628's Avatar
Oddometer: 1,576
Originally Posted by bastimentos View Post
Hi,
Who even makes an 18inch bigger than 2.5?
If the 18inch wheel and tire combo is taller than the 17inch combo then yes your bike will glide over rough terrain far easier. The bike should also handle a little better as I think the 18in tires are lighter.
All bets are off if I'm wrong on my contention :)
rmhrc628 is online now   Reply With Quote
Old 05-06-2013, 05:13 PM   #10
bearclaw952
Oddometer: 1
Woody won't seal the front because there's no safety bead on the rim. You can do it yourself though.
bearclaw952 is offline   Reply With Quote
Old 05-06-2013, 05:28 PM   #11
FredRydr
FredRydr's Avatar
Oddometer: 1,003
That's why the rim would be replaced.
Fred
Times are GMT -7.   It's 05:43 AM.
