Old 11-20-2012, 05:58 PM   #91
petzi-baer
Oddometer: 184
Originally Posted by Konflict Motorsports View Post
I have been using the Shiver's, but have since swapped to WP for the last 2 sets with much better performance...
So are you planning to offer this new setup to customers and how much would ask for it?
Sorry if that was discussed before ...
petzi-baer
petzi-baer is offline   Reply With Quote
Old 11-21-2012, 08:29 AM   #92
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 624
petzi-baer
Petzi,
I'd like to keep pricing and such out of this form as I am working on putting something together for a Vendor section post. If you would like more info email me at alex@konflictmotorsports.com so I can forward over my rider profile form for you to fill out.
Alex
Konflict Motorsports & Suspension Services
www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 11-21-2012, 11:21 AM   #93
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 307
That's not how I understood it. I think they meant for major setup work you can take it out and adjust compression and rebound independently - since one leg is for compression and the other for rebound.
petzi-baer
I have photos of the parts (was asked to not post them yet.) But the top caps look like the usual Ohlins kit. Allen damping adjustment screw inside the preload 'nut'. Looks like externally adjustable to me.
NCD is offline   Reply With Quote
Old 11-22-2012, 06:10 AM   #94
FreeTheBeast
equitem casus
FreeTheBeast's Avatar
Oddometer: 2,623
Cool2 Best logic yet...
Originally Posted by RandomZ View Post
Good grief, haven't even got the bike and already trying to change what you "think" is a lousy component? Wait till you get the bike, ride it, and then decide. It blows my mind when working with customers who are looking at a new bike who say "well if i buy the bike i'll need to get a taller windshield" or "i'll need to change the stock tires." People give the interwebs too much credit, just ride the bike and see. For 2013 the F800GS is vastly improved over it's predecessor. Buy it, ride it, and then tweak as needed
Rant over, GL with the new bike
This is the best piece of logic I've seen. It could potentially save $$$$. Thank you for stating the obvious.
I'm in talks with my dealer to trade my R12GSA & g450x for a new F8GS. I believe the F8 will be better suited for the riding I do most often and enjoy the most.
So, it's not completely clear to me...the forks in the 2013 model have changed? I have seen mention that they are now [better?] 43mm WP whereas before they were [crap] 45mm Marzocchi. Is that correct? If this is the case, I'm certainly going to buy the bike and ride it before replacing the suspension.
Think beyond yourself.
~ap blog
Max the Motorcycle - children's book written by Mrs. FTB
SmugMug Photo Gallary
FreeTheBeast is offline   Reply With Quote
Old 11-22-2012, 06:53 AM   #95
ebrabaek
Oddometer: 2,828
They are 2mm thinner..... I don't think they are better. I thought the stock 45 Z's were ok when I bought my bike back in 2009.....but that changed as the bike went off road. Unless the rider came from the 2012 8GS to the 2013 8GS, and compared, I wouldn't think they could make an accurate comparison. Unless you are rock hopping from the getgo..... you will find it adequate....... I personally don't like the stockers, but does not find it detrimental to the operation. I do plenty of rock hopping, you just gotta brush up on your riding skill, as you cant plow through things.... imho.
Erling
Old 11-22-2012, 09:28 AM   #96
itsatdm
NoMoTDM still Gary
itsatdm's Avatar
Oddometer: 3,711
They are 43wp instead of 45mm zokes. They might be better if they were rebuild-able, but I have not seen a post saying that they are.
In the beginning of the suspension threads there were some posters who said being able to tune the suspension is overrated. That is only true, if the sealed up one size fits all is true, but it is not. If you can respring and revalve them to your weight and style that argument has more merit.
The Esa option will be an improvement, because it is an adjustment of the compression valving. Whether that is compatible with any spring changes is yet to be seen.
As to what is wrong with the Marzocchi forks, this was my finding too:http://www.motorcyclistonline.com/ho...s/viewall.html
Unfortunately, the last I heard After Shocks is no longer in business for a cheap fix, though Phil Douglas may be around? Desert Dave had one of his fixes.
Old 11-22-2012, 09:43 AM   #97
wipe-out
wipe-out's Avatar
Oddometer: 92
so i just received an answer by the öhlins distribution & test center in germany. they're saying that they were introduced at the intermot as prototypes and would probably be made available in spring 2013. first models are for the f800gs & the tiger 800. no further information is available. he "assumes" they will be plug & play.
maybe if someone has more personal relationships to some öhlins representive there's more details. that's the official bit from "customer support & product manager".
wipe-out is online now   Reply With Quote
Old 11-22-2012, 11:24 PM   #98
Snowy
Oddometer: 1,116
Oh, I get it...because you're from Germany they'll answer your emails.
On another note, the Emig triples were fitted up after some minor tinkering/modification/alteration.
Wheel fits easy, same axle diameter as an 06 and earlier Suzuki. I already had a sleeve turned up out of alloy for the left axle clamp, so I just need to shorten the axle 5mm and it's good.
My 4 piston (thanks Ian) caliper doesn't fit, because it's too wide.
I have the high mount mud guard sorted, the new brake line is coming, and I've ordered some fancy new plastic fork leg protector thing-a-majiggers. Mid next week. Then I'll post pics.
But it's already far stiffer, and spring wise feels about the same as the 0.55kg/mm. I can't remember what spring rate I had in the Showa's. But the static sag is perfect as they are, and they are super firm and stiff as a teenage boy in a room full of naked women.
My trail videos. Yes, I need to learn to edit. Baby steps...
https://www.youtube.com/user/DRMZ650?feature=mhee
Snowy is offline   Reply With Quote
Old 11-22-2012, 11:38 PM   #99
wipe-out
wipe-out's Avatar
Oddometer: 92
i threatened to throw a lot of superlong concatenated words at them.
Gesendet von meinem GT-I9300 mit Tapatalk 2
Old 11-24-2012, 11:19 PM   #100
Snowy
Oddometer: 1,116
Well I changed the front end over.
The problems in no particular order:
The steering head bearings had failed. Badly, as in rachet action. Never noticed until the wheel was off the ground.
The steering stops on the Emig triples are not machined right. I don't have full lock, and I had to use a dremel on them for about 30 mins to get them to clear the steering head and allow the bearing to fully seat.
The Emig steering damper was pissing oil everywhere. There was a missing o-ring on one of the drain screws.
The mount for the steering damper post will only mount if the welds on the frame are neat and tidy. Mine were not.
The steering damper post was too high. Had to trim it down.
The front wheel mounts up without great drama, I used an existing sleeve I had turned up from alloy to allow the use of pre 06 RMZ front wheels in an 07 front end. The BMW axle is the same diameter as the 06 Suzuki. I trimmed 5mm off the axle because the axle clamps are a little narrower than the standard ones.
The bores for the fork tubes were done exactly to the measurements I gave them. But, the triples are so solid that despite being a very tight fit, it's difficult to get the clamps to do up tight enough to stop the fork tubes moving. I got it in the end, but they are tighter than I like alloy being.
I removed one disc, had a new stainless braided line made, and solo the braking is more responsive than it was. I'll wait and see what happens 2 up. I plan on fitting an aftermarket wheel with billet hub and motard disc anyway. It's getting the ABS sorted that's the pain.
So....first ride...I took it up the hardest spurline track I know. I now have no need of my DR with the RMZ suspension front and rear. The BMW is now truely a "trail bike". A big, heavy, hard to stop trail bike, but it's absolutely a trail bike. It is great fun off road now. I can safely say it will bang along at very un-BMW speeds. The looks on the faces of the 2 trail bike riders who were gingerly picking their way down a steep gravel covered trail as I blew past climbing at 60kph and airborne off the erosion bars was priceless. They were like...WTF...and I was like...BWAAAHAHAHAHAHA...BLAT...
Unleash the angry ponies and it is a awe inspiring ride now. The front end works so well that I can feel every little issue from the rear now. I've already spent a small fortune on the Ohlins rear, 3 resprings and 2 revalves...it is light years better than standard, but now I can push hard enough to find the limits of the rear very quickly.
Now I'm going to go and measure the RMZ rear shocks I have in the garage. I'm thinking a hybrid Ohlins/Showa rear may be on the cards.
Pics to follow.
Old 11-24-2012, 11:43 PM   #101
Snowy
Oddometer: 1,116
Unpacked....excited....
OOOOOHHHH goody...
new versus old
Removed some bits
MWAHAHAHAHAHA ...the evil...it grows....
Old 11-25-2012, 01:41 AM   #102
chadams
Oddometer: 189
Looks like a tidy setup, any details on the forks and custom triples? What wheel are you running?
Current ride:- 09 f800gs
Previous rides:- 05 z750, 81 z1000j, 84 gpz1100, 98 dr250, 99 dr250, 96 dr350, 93 rf900, 93 nx650, 98 xtz660, 97 dt200r
chadams is offline   Reply With Quote
Old 11-25-2012, 02:46 AM   #103
Snowy
Oddometer: 1,116
Triples are from Emig Racing...www.emigracing.com
Forks are RMZ 450 with 0.49kg/mm springs.
Wheel is standard BMW for now. Stage 2 will see the billet alloy off road race wheel built and installed. Motard sized brakes.
Old 11-26-2012, 03:22 PM   #104
petzi-baer
Oddometer: 184
OOOOOHHHH goody...
new versus old
Removed some bits
Now your screen looks hideous :-)
petzi-baer
Old 11-27-2012, 06:54 AM   #105
wipe-out
wipe-out's Avatar
Oddometer: 92
Originally Posted by Angryrican View Post
wouldn't it be really cruel if this set up was for the new WP legs that are on the 2013's?
Originally Posted by biodieselandon View Post
I hope it's for both!
according to öhlins odtc it (probably) won't fit the new model. up until 2012 only. just received the answer to exactly that question.
Times are GMT -7.   It's 07:54 PM.
