Old 11-27-2012, 11:01 AM   #106
biodieselandon
biodieselandon's Avatar
Oddometer: 358
Originally Posted by wipe-out View Post
according to öhlins odtc it (probably) won't fit the new model. up until 2012 only. just received the answer to exactly that question.
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Old 11-29-2012, 03:01 AM   #107
Snowy
Oddometer: 1,838
Now your screen looks hideous :-)
Yeah, but it keeps the rain off me, and I can drink coffee on the ride to work and look like a BOSS!
Snowy is offline   Reply With Quote
Old 11-30-2012, 10:54 PM   #108
Snowy
Oddometer: 1,838
The steering stop issues. Not quite the right shape. I'll use the die grinder and sort it later
Old 12-01-2012, 01:11 AM   #109
Snowy
Oddometer: 1,838
I made a new mount for the ABS sensor.
I ride mostly with the ABS switched on, rarely switching it off. No, it doesn't make you forget how to use your brakes.
But it does come as a shock when you launch into a gravel covered hairpin and discover that you forgot to hook it back up.
There was a significant drop on the outside of that hairpin. I had one of those moments.
Old 12-01-2012, 01:15 PM   #110
kenaroo
I am because i ride
kenaroo's Avatar
Oddometer: 873
Yep I gave up on that emig stabilizer a long time ago.. I've never had anything leak so much in my life.. send it back.. get it fix ride and it would leak.. I finally gave up on it.. I think I modified a BRP handle bar clamp to work with the emig triple so I could use my old reliable scotts..
what does your garage look like
http://www.garage-interiors.com
kenaroo is offline   Reply With Quote
Old 12-01-2012, 01:25 PM   #111
biodieselandon
Oddometer: 358
Originally Posted by Snowy View Post
What kind of header guard is that? I like!
Old 12-01-2012, 03:49 PM   #112
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
My money says its a Touratech
Motorfiets is offline   Reply With Quote
Old 12-02-2012, 03:06 AM   #113
Snowy
Oddometer: 1,838
The header guard was off the specials table at the local bike shop. I think it was $10.
I cut it in half and went half each header.
The Emig steering damper has done nothing but leak. I can't figure it out.
It had a missing o-ring on one of the fill screws, I fixed that, but still some leakage. I'm stumped.
It still seems to work ok though.
Old 12-05-2012, 11:21 PM   #114
Hamish71
Hamish71's Avatar
Oddometer: 409
looks good. wilk post my set up when i receive the last if the parts from lukas and fit it all.
Hamish71 is offline   Reply With Quote
Old 12-17-2012, 10:13 PM   #115
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 861
I've put an ad in the vendor section for my F800GS suspension
http://advrider.com/forums/showthread.php?t=849184
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 12-17-2012, 10:28 PM   #116
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Not bad. A bit more than I spent but I'm super happy with my shiver 45 forks in my F800GS
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 12-18-2012, 08:59 PM   #117
Fishlegs
Fishlegs
Fishlegs's Avatar
Location: Shawnigan Lake, dirt bike capital of vancouver isl
Oddometer: 14
entire aprilia front end
ok fellas...heres what happened to me...i had a friend come riding with me on his gs 800 and i was riding my aprilia rxv 550....this is getting good already isnt it...he slid out in a tight turn and toasted his entire front end..i ended buying the bike off him(written off)and literally slid an entire rxv 55o front end,(wheel,brakes,brake line,headlight,fender)in triple clamps and all right in perfectly!! all ihad to do was grind down the bearing nut(the one with the grooves)about a quarter inch cause the steering stem was that much shorter..i call it my gs 800 super enduro..and i mounted the beemer windshield unto the turn signal mounts ...check out pics at www.vibnb.com
Fishlegs is offline   Reply With Quote
Old 12-18-2012, 11:27 PM   #118
wipe-out
wipe-out's Avatar
Oddometer: 237
looks good! i like it much better than most of the high-fender mods which stay with the original headlight assembly. looks like that bike touratech built.
wipe-out is offline   Reply With Quote
Old 12-19-2012, 06:15 PM   #119
Fishlegs
Fishlegs
Fishlegs's Avatar
Oddometer: 14
My Beast
Fishlegs screwed with this post 12-19-2012 at 07:23 PM
Old 12-19-2012, 07:00 PM   #120
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
brother............................?
Ben
My Photo's
Times are GMT -7.   It's 02:07 PM.
