Old 10-06-2012, 02:08 PM   #16
ME 109
ME 109's Avatar
Oddometer: 2,986
The op is referring to the 'boots' that go between the fairing and the forks, not the ribbed gaitors.
I have, and always will have ribbed gaiters to protect my forks.
Edit, I think that is what the op is referring to.
Gaiters work well in protecting fork legs from stones, but not from these........
http://www.youtube.com/watch?v=lpcz1qcxYuA
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 10-07-2012, 10:19 AM   #17
bushyb OP
bushyb's Avatar
Oddometer: 74
To be fair I have asked this on other forums as well, these are the contenders with the number of times mentioned: Gummi-pflege 2, Peanut oil, dielectric grease, Denatured alcohol, brake fluid 2, silicone spray 3, wintergreen oil 3, liquid Ivory soap, 303 Aerospace Protectant, Pledge furniture polish2, ATF (automatic transmission fluid).
I did a small experiment with what I thought would work based on the above and what I had in the garage at hand. I cut an old bicycle tube in ˝”strips and smeared them with multi-purpose grease, old engine oil, brake fluid, aluminium deoxidiser, ATF, pledge furniture polish, carb cleaner, painter’s thinners and CRC marine spray. I can tell you the only ones that seemed to work was the CRC, painter’s thinners and carb cleaner sprays.
The thinners is no-good it just makes the rubber deteriorate. The Gummi-pflege is a known rubber product for BMW door / sun roofs rubbers etc. Maybe once its soft a little bit of furniture polish or silicone spray will keep it soft.
bushyb is offline   Reply With Quote
Old 10-07-2012, 01:43 PM   #18
assquatch20
Hoss Cat
assquatch20's Avatar
Oddometer: 1,104
You know, I don't know what site it ever came from, maybe here or SOHC/4, but someone did a similar project with o-rings and a micrometer, and they had one that they didn't do anything to, for a control.
Some things shouldn't be left like you found them.
assquatch20 is offline   Reply With Quote
Times are GMT -7.   It's 09:04 PM.
