Old 10-07-2012, 11:06 PM   #16
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
Ok thanks! I think I got the hang of it. Basically loosen the bolts again so that I can have zero VERTICLE play on the rockers then shim the valves correct?
Thanks for helping out a noob!
'79 BMW R65
'03 KLR650 Sputnik Sidecar
sh1bby69 is offline   Reply With Quote
Old 10-08-2012, 02:44 AM   #17
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,813
We are talking about the end play of the rockers. Later rockers have shims. Your rockers need to have the end blocks pushed together. Sometimes you will have to make a large clamp tool with sockets on the ends to push the blocks together. But usually you can do the pushing with your hands. You can also push the blocks together by partially loosening the nuts and whacking the blocks with a rubber mallet. Or putting a socket over the block and hitting it with a regular hammer, but not too hard, a couple of small whacks is better than big whacks.
What ever method is used eliminate the end play.
---Albert Einstein
Times are GMT -7.   It's 09:08 AM.
