Old 10-08-2012, 06:37 PM   #16
brucifer
brucifer's Avatar
Oddometer: 2,460
Originally Posted by Yokomo View Post
Are you sure it's not #7? That looks more like the airscrew. (I could be wrong)
I misunderstood. I thought you wanted to know how to remove the slide needle to shim it. Sorry about that.
Yes, 7 is your mixture screw.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is online now   Reply With Quote
Old 10-08-2012, 07:07 PM   #17
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,300
Herb the pic makes it look better than it is in person, but thank you.
brucifer - ah yes thats how I recall the carb looking inside the XL250 I had. Can you remind me how to remove it? I recall a spring on the arm and having to remove a screw...
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 10-09-2012, 06:30 AM   #18
brucifer
brucifer's Avatar
Oddometer: 2,460
Yeah, the spring holds the link arm on; remove it. Then remove the two tiny screws that hold the link plate to the top of the slide. Make sure you use a screwdriver that fits well and lots of down force so as not to round out the screw heads. The linkage should now come out as well as the needle.
Old 10-09-2012, 11:17 AM   #19
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,300
I either watched a vid or step by step instructions online before; any idea where to see that?
So when I go to add the washer to rihen it up a tad bit, should I open both carbs and add a washer to both needles? Makes sense to me, but thought I'd ask.
Do you know of any easy/cheap way to get a little more throttle response and pep out of the bike? I could remove the snorkle but that won't do anything with the stock exhaust I assume.
Just wondering. Thanks!
Oh, let me go take a pic of the carbs...
Old 10-09-2012, 12:54 PM   #20
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,300
Left stock carburetor. I assume its an air screw to the lower right of the square. If so, I assume I have it set as rich as possible, correct?
The bottom of the carbs
The right carb. Idle screw is at the upper right.
Left carb after I dremeled off the tab. I turned it all the way in which would RICHEN an air screw. Stock setting was 1.75 turns out. I set it at 1 turn out. I forget, should this make it easier (richer) to kickstart, or is it the raising of the needle that makes it easier to start?
I hope this helps me and others to follow.
Old 10-09-2012, 01:16 PM   #21
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,515
Looks very similar to the '84-'87 XL250R setup...
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 10-09-2012, 01:50 PM   #22
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,300
Yes it does. Please tell me what you know about them. I'm looking for info! Thank you!
Old 10-09-2012, 02:00 PM   #23
Stretch67
Stretch67's Avatar
Oddometer: 6,515
I learned to not neglect a perfectly good carb. I bought my XL250 brand-new in '87, but in later years parked it for years at a stretch. On a couple occasions I left the petcock on, letting an entire tankful of gas evaporate through the carb bowl vets, coating every surface in the float bowls with slick, hard green varnish.
Don't do that.
And then while removing the carbs to clean them, I heard the intake boot crack. From then on it had a nasty intake leak and it never did run right. And the choke didn't work, making the bike nearly impossible to start without ether.
In a nutshell, keep the carbs clean and happy so you don't have to remove and disassemble them. Keep the tank filled with fresh high-octane gasoline, shut off the petcock when the engine's not running, and drain the carb float bowls if you're not going to run the engine for a couple days.
Here's how I fixed mine: http://advrider.com/forums/showthread.php?t=788941
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 10-09-2012 at 02:07 PM
Old 10-10-2012, 05:57 PM   #24
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,300
Anyone know of a site for XL XR 350R info? Even an old site with lots of info...
Old 10-10-2012, 08:15 PM   #25
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,300
Nowhere close to an XL350, but I think the description and pics sum up what has to be done to remove my XL's needle and raise it.
Anyone have any advice on raising the needle 1 or 2 little washers?
And should I raise the needle of the 2nd carb?
http://crfsonly.com/howto/450x/jetti...jet-needle.php
Ahh, I finally found it. Here's the pics I followed on my XR250L. I bet the XL350R carb is very similar.
http://rickramsey.net/CRF230Fcarb.htm
Yokomo screwed with this post 10-10-2012 at 08:24 PM
Old 10-10-2012, 08:30 PM   #26
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,530
Raising the needles is not the way to make it start easier. You can try a larger pilot jet.
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Old 10-11-2012, 07:11 AM   #27
Stretch67
Stretch67's Avatar
Oddometer: 6,515
More info: The XL Page...
http://www.oldrice.com/xl_page.htm
IBA # 33113
Alaska
XR400 Index
Old 01-26-2013, 08:34 PM   #28
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,300
I hope to get to this soon. Anyone have any advice on whether I should use 1 or 2 washers below each needle?
Old 03-02-2013, 08:35 PM   #29
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,300
Done, I put 2 washers below each needle.
Old 04-12-2013, 10:21 AM   #30
cyber104
Oddometer: 1
I've just done extensive work on this subject
Just joined the forum so that I had some place to share the information.
If the washers don't work I suspect I can help you.
The previous poster that suggested a different pilot jet was exactly right
cyber104 is offline   Reply With Quote
Times are GMT -7.   It's 12:32 PM.
