Old 01-09-2013, 08:22 PM   #76
hardwaregrrl OP
ignore list
hardwaregrrl's Avatar
Oddometer: 7,611
Originally Posted by RecycledRS View Post
Suggest you use blue locktite on all nuts and bolts. Did the head of the allen screw wear into the aluminum? Do you need a washer to spread the head load to a bigger area? PS love your ongoing updates.
Thanks for the suggestion....but they're most certainly was loctite on the bolts, and almost every bolt on the bike. I guess you're unfamilliar with "my final drive came loose" story.?!
Photo & Video Sharing by SmugMug
Obviously I NEED to check every bolt, screw, and nut on this bike AFTER I race it....lesson learned the "not so hard" way.
Old 01-10-2013, 01:15 PM   #77
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,094
So Jenna, is that now a semi-floating front caliper, or full-floating?
Glad that didn't turn out worse.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-10-2013, 04:23 PM   #78
hardwaregrrl OP
ignore list
Oddometer: 7,611
he he....The bolts that came with the HE bracket did not pass through the other side. I didn't like that so went ahead and made my own. 32mm is what they came with and 35 wasn't enough, so I got some 40's and shortened them to about 38mm.
Removed the neutral switch and installed my plug.
Uploaded from the Photobucket iPhone App
Shrink wrapped the wires up.
Spotted this next to my little SUV at the grocery store.....Brian was a really great guy. Going to his shop for a beer sometime soon.
Old 01-10-2013, 04:25 PM   #79
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,971
Jeana- if you want a neutral switch that doesn't leak the brass one from Hucky's is a good one. I've had mine in for a while now and still no leaks. It's cheaper too.
That bearing doesn't look to good. So you replaced the rode bearings right?? How are the journals?? When I did the top end on the G/S the rods and pistons were weighed, and we very close to equal. Don't remember the weights but no balancing needed.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-10-2013, 04:32 PM   #80
hardwaregrrl OP
ignore list
Oddometer: 7,611
New rod bearings and piston rings. I really f'ed things up while reassembling my left conrod while talking on the phone. I reversed the cap and pressed the pins into the rod...they were mushroomed. So Beater let me steal the con rods off of a 74 R90 motor and they were quite a bit heavier than my ST rods. On the 74 rods there is a relief to knock the pins back in case you pull a "jenna", but no relief on the ST rods. So I did have a big difference between the two sides and went to town with a dremel. Journals looked great! Got lucky, I pulled them off just in time, that right side rod would not drop without assistance....
Old 01-10-2013, 04:48 PM   #81
One Less Harley
Oddometer: 4,971
Did you run low on oil?? Glad you caught it in time. I ruined a main cap recently on my TR6 by not lining it up right...luckily not to hard to fix, line bore the journals...it's only money right?
be careful with the dremel as you don't want any scratches or gouges perpendicular to the length of the rod. Any file or scratches are potential breakage points.
This rod is from a Triumph TR6 (car), but shows, what you don't want to see, stock rod. You don't have casting marks like these rods, but all those lines are potential fracture spots.
after sanding.
BTW- use assembly lube on the bearings, or STP oil treatment.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 01-10-2013 at 04:56 PM
Old 01-10-2013, 04:59 PM   #82
hardwaregrrl OP
ignore list
Oddometer: 7,611
Bikes back together and running very well....I used a moly on the bearing shells. I've already run it about 300 miles for ring break in. My understanding is you do not want to abrade the top of the rod but the sides. Which is what I did, and I'm not the only one.
after sanding.
Old 01-11-2013, 02:41 AM   #83
YOUNZ
Oddometer: 324
Looking at the image of that rod bearing shell with the babbitt all worn off, reminded me that in my experience the replacement never lasted very long. The crank journal looked OK but in reality, not good enough. I hope you have better luck.
YOUNZ is offline   Reply With Quote
Old 01-11-2013, 05:04 AM   #84
hardwaregrrl OP
ignore list
Oddometer: 7,611
It broke off when I stepped on it.
hardwaregrrl screwed with this post 01-11-2013 at 05:17 AM
Old 01-12-2013, 05:36 AM   #85
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,625
You know that feeling you get when you look over a cliff or a really high bridge? That's what I felt when I read your third sentence.
I don't know how many times I've stood in the shop, shoulders drooped, staring, with that "You dumb motherfucker" feeling.
But, there's always a way back:
And breakin' shit is a good first step! Lookin' good, Jenna!
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 01-12-2013, 06:21 AM   #86
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,583
So ... how's she running? Smoother? More power?
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 01-12-2013, 06:31 AM   #87
hardwaregrrl OP
ignore list
Oddometer: 7,611
Thanks man I have learned way more from making mistakes than I have by the book. When you have to sit back and scratch your head, I consider that a win in my brain book. I realize these machines are pretty simple to work on from a motor stand point but it has changed my attitude when it comes to diving into something you're unfamilliar with. i've been able to keep this bike rolling since '07 almost completly independently. And this isn't the kind of bike that's ridden once a week. I totaled my mileage up recently and on average, I've put around 12k a year on this bike.
The power is certainly there.! I still think the Dobber is an anomaly as my A$%hole is nowhere near as smooth....although it could be my socked D606s on the bike. They're pretty toothy in the front.
Old 01-12-2013, 06:48 AM   #88
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,625
That's gold right there!
Simple, complicated, it's no different, you're still only doing one thing at a time.
In a given week I'll work on a six cylinder Porsche, a flathead Ford tractor, and a sump pump.
The main thing is no matter what it is, no matter how much experience you have, slow down, look at it, and see what's there.
Then fuck it up, and kick yourself in the ass!
Old 01-17-2013, 03:19 AM   #89
hardwaregrrl OP
ignore list
Oddometer: 7,611
Bike is running very well. Went out to a local secret spot on Sunday just before the Falcons game to have a little fun. Still need to learn how to EDIT. So I apologize for the length.
Old 01-17-2013, 03:40 PM   #90
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,625
Wow. Fun place to ride! Lots of variety. That Jeep/ATV place at the end reminded me of the strip mine where I rode growing up.
And then, at the end, I see that you were riding all that with a bucket saddle! Man, I could not do that. Props!
Times are GMT -7.   It's 06:33 AM.
