Old 03-19-2006, 02:29 PM   #1
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
1981 g/s CR fork project
I'm in the process of retro fitting a CR250 front fork on my 81 g/s and have a few questions for the Airhead guru's. I'm worried about changing the geometry of the bike if the forks end up being a bit longer than the
stock unit. Any words of wisdom?
Just say'IN
crankshaft is offline   Reply With Quote
Old 03-19-2006, 02:52 PM   #2
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,491
This is a common questions and the answer is yes you will change the geometry of the bike if you put a longer fork on it. Unless you want a chopper you need to raise the rear and on the monolever I believe the only way to do this is to extend the swingarm . This is an involved process as you need to lengthen both the swingarm and the drive shaft. There probably are folks that do this in the US, I don't know who they are though. HPN does it in Germany and will deal with you here. I'm guessing in the meantime you can just raise the fork tubes in the triple trees to level things out. JT
jtwind is offline   Reply With Quote
Old 03-19-2006, 03:19 PM   #3
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
I'm planning on doing the swing arm also, but I was more concerned about what I might be forgetting. I'm going to add some gussets to the frame at the head tube and try to find a larger rotor and caliper to slow the beast down.
I'm having a machinist buddy make a jig and lengthen the swing arm for me. If I can find a spare swing arm I might have him make two since he'll be all set up anyway. Is the R80 swing arm the same internally with the exception of the hub (3 vs 4 lug)? I guess I need to find another swing arm.
Aaron
Just say'IN
crankshaft screwed with this post 03-19-2006 at 03:27 PM
Old 03-19-2006, 03:31 PM   #4
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,491
That's a good question, if the monolever swingarms are the same. Would be easy to pick up another to modify if they are. JT
Old 03-19-2006, 04:33 PM   #5
CMWoody
CMWoody's Avatar
Oddometer: 5,248
You could also cut the fork springs down a bit to cheat it down. Especially a good move if your 190+ pounds yourself as the stockers are very light, made for a 150-160 lb Japanese guy. Extra BMW heft carries is gotta count for something. Cutting the springs increases their load bearing.
That and sliding them up in the triple clamps a bit might do the trick.
CMWoody is offline   Reply With Quote
Old 03-19-2006, 04:43 PM   #6
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
I was 190 lbs about 10 yrs ago Cutting the springs sounds like a good idea.
Aaron
Just say'IN
Old 03-19-2006, 04:47 PM   #7
CMWoody
CMWoody's Avatar
Oddometer: 5,248
Here's some interesting reading on the subject
Old 03-19-2006, 05:00 PM   #8
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Thanks man!
Just say'IN
Old 03-19-2006, 08:08 PM   #9
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 11,978
Have you tried to install the triple clamp yet? I briefly tried to install a 1990 KTM 500 fork to my 88 R100GS. The triple clamp is about an inch too long.
Once you know that, you start looking at the HPN frames and realize that they added a welded extension to the headtube. That's going to also put more load on the head tube so they added gussets to the whole area up there at the front.
So have your machinist buddy make press-in collars for the upper and lower ends of the tube and get them welded in.
BTW: did you ever sell that ugly-ass Adventure
Greg
Donkey Hotey is offline   Reply With Quote
Old 03-19-2006, 08:24 PM   #10
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
I've been eye balling the fork all day and it looks like it will work. My buddy has a sweet lathe and a nice big Mill, so we can make it work I'm sure.
Looks like the ADV is staying by the way
Just say'IN
Old 03-19-2006, 09:11 PM   #11
tommcbride
tommcbride's Avatar
Oddometer: 1,072
What is that contraption on your wall in the photo?
Please pardon my hijacking your thread Crankshaft, but what is it?
Thanks,
Curious Tom
Tom McBride
tommcbride is offline   Reply With Quote
Old 03-19-2006, 09:15 PM   #12
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
Greg
You could just press the stem out of the KTM triple clamps. Machine a new stem the same dimensions as you BMW stem and press it into the KTM Triple Clamps.
Thats what I intend to do with 50mm WP extreme KTM front end into my R80G/S.
a lot easier than have your machinist buddy make press-in collars for the upper and lower ends of the tube and get them welded in.
Pezz :)
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 03-19-2006, 09:16 PM   #13
Donkey Hotey
De Jo Momma
Oddometer: 11,978
Damn nice looking bike. I still have to fix the engine in mine. It does look nice sittin' here in the kitchen but warm weather is coming and Death Valley is calling.
Greg
Old 03-19-2006, 09:48 PM   #14
Donkey Hotey
De Jo Momma
Oddometer: 11,978
Yes, except that the triple clamp would then be gripping the tubes 1" closer together. And that would put more load on the triple clamp.
I thought about both solutions but I figured the HPN guys had to have a good reason for extending the frame rather than shortening the stem.
Greg
Old 03-19-2006, 10:05 PM   #15
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
Yes, they have done it that way.
I will go with the shorter Stem. The increased load on the steering head would be minimal.
I am also using the older twin shock swingarm extended 100mm.
To each their own
Pezz :)
Airhead Tragic
Times are GMT -7.   It's 05:31 PM.
