10-07-2012, 04:21 AM
#16 | |
Oddometer: 506
Imo the oil might be the reason they slide over the tubes to far and than start to burst.
BMW R100'91/R80'93/R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920 R100GS'91 (sold) |
10-07-2012, 01:24 PM
#17 |
because I can
Oddometer: 6,070
+1 I think you are better off installing them dry with the mold release rubbed off inside and out and I have installed a bunch of them.
supershaft screwed with this post 10-07-2012 at 01:32 PM |
10-07-2012, 09:20 PM
#18 |
Beemerholics Anonymous
Oddometer: 7,354
I've always used silicone grease with never a problem. Maybe I shouldn't bother and install them dry.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
10-09-2012, 12:47 AM
#19 |
Yeah, right!
Oddometer: 4,251
I've just asked the same question, hadn't seen this. However, I pinched an o-ring and had the bike running. Since I've also pulled the head, can I reuse the gasket. The blue sealant around the pushrod tube holes and the upper studs has been slightly pulled off. Can I just smear a bit of sealant on there? Is it enough just to replace the damaged 0-ring, or will I need to replace the large o-ring as well. Sorry to ask the same questions again, but my bike has been running for a minute or two.
I just had to check what the problem was and didn't want to leave the head attached by two bolts over night. Are these o-rings special, or can I just get a generic one, of the same size?
R1150GS R80GS Basic __________________ |
10-09-2012, 03:46 AM
#20 |
Beastly Gnarly
Oddometer: 287
FWIW, I replace the pushrod tube seals on my /7 two days ago. All I did was remove the exhaust and carburetors then set the cylinder to TDC and torque (per Oaks recommendation) the cylinder bolts incrementally until they were loose. The rocker assembly and pushrods were removed and oriented for replacement in the same locations. The cylinder was slid out, seals replace, base recoated with Hylomar, o-rings inspected, and then slid back. The valve train reinstalled in the correct location, adjusted for rocker arm end float, retorqued (incrementally), exhaust and carburetors replaced.
Mine had no gasket or cylinder base o-ring to replace and the pushrod seal o-rings looked OK. I used lighter fluid (Ronsonol) to lubricate the new seals. The most difficult part was cleaning around the cylinder to remove old Hylomar, clean, and recoat. Getting Hylomar was not that easy. The valves were adjusted last before a test ride. Good luck! Stan_R80/7 screwed with this post 10-09-2012 at 04:17 AM Reason: made o-ring plural |
10-09-2012, 10:18 AM
#21 |
Yeah, right!
Oddometer: 4,251
Thanks, I guess I am manly worried about the headg asket.
10-11-2012, 04:25 AM
#22 |
Confirmed Curmudgeon
Oddometer: 3,891
Leave the two short-stud head nuts at 6&12 just snug (5-10 ft-lbs, not at full torque, not loose) when removing the head-cylinder assembly and the head gasket will be fine.
'73 R60/5 Toaster |
10-17-2012, 07:31 AM
#23 |
Oddometer: 281
I ended up ordering new seals for the one side. I left the head attached to cylinder but loosed the nuts at 6 and 12 o'clock. The seal that was bad was torn longitudely about half way down. It might have been fine but then one never knows. The large and small o-rings looked fine and the head gasket was a little warped from hanging up on the threads of the studs as I was pulling the cylinder off but no real damage. It'll flatten back out as I retorque the head nuts. I cleaned off the head gasket reapplied Halomar and buttoned everything back up. Here's hoping nothing leaks.
Thanks for everyone's help. Maybe I'll get this project finished at some point.
--------<>-------- 2004 R1150GS Adventure (The Valdez) 1973 R75/5 Red Toaster (Amy) |
10-17-2012, 07:40 AM
#24 | |
More tacos than you
Oddometer: 5,112
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
10-18-2012, 12:49 PM
#25 | |
Oddometer: 281
