Old 10-06-2012, 04:09 PM   #1
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
Tail light not working
So I picked up a Boxer Metal rear fender eliminator. I sent out and powder coated and now it won't work. I'm thinking it has to do with grounding it but I'm not sure what to do. Do I have to expose some metal to get the tail light to work?
'79 BMW R65
'03 KLR650 Sputnik Sidecar
sh1bby69 is offline   Reply With Quote
Old 10-06-2012, 04:30 PM   #2
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
The brown wire from the tail light harness need to be hooked up to one of the threaded studs on the back of the tail light and all will be well.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 10-07-2012, 09:58 AM   #3
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
Thanks!!
Sent from my Galaxy Nexus using Tapatalk 2
'79 BMW R65
Old 03-04-2015, 01:52 PM   #4
canehdian_guy
Oddometer: 66
Does anyone know why my tail light wouldnt be working although my brake lights still work?
My day time running lights and high beam are still functional and my fuses all seem fine.
canehdian_guy is offline   Reply With Quote
Old 03-04-2015, 01:59 PM   #5
CafeDude
CafeDude's Avatar
Oddometer: 1,727
Bad bulb?
CafeDude is offline   Reply With Quote
Old 03-04-2015, 02:29 PM   #6
east high
east high's Avatar
Oddometer: 955
Originally Posted by CafeDude View Post
Bad bulb?
It's usually this. It's a dual filament bulb.
'71 r75/5
east high is offline   Reply With Quote
Old 03-05-2015, 12:17 PM   #7
pietas
Oddometer: 21
If it is not the bulb, check the wiring and switches. Buy a new bulb to make double sure of this
If neither the front nor back brakes activate the brake light, check the brake light loom as well as the connector block between the looms. Use switch cleaner to clean the connectors and switches
Get a colour coded wiring diagram to understand which wire goes where
Use a multi-meter to check for connectivity on wires and switches
I had the same issue last year. Mine was a dirty connector but the loom can just be old
pietas screwed with this post 03-06-2015 at 11:19 AM
pietas is offline   Reply With Quote
Old 03-05-2015, 01:28 PM   #8
deafanddiabetic
Oddometer: 158
There's already great advice here, but we don't know which model is your bike.
If it's a /5 or /6, the tail running light is run off of the grey/violet wire in the headlight bucket.
It's likely the bulb though, it gets me every time!
deafanddiabetic is offline   Reply With Quote
Old 03-05-2015, 06:58 PM   #9
ewilly
Oddometer: 120
Jumping in
I need to jump in on this one!
My issue is the brake light is working but no running light at rear or gauge lights. I put knew rear light on rear when I changed fenders and have not had power past the rear connector since.
Popped Relay?
Looks like the fuses in bucket are good!
Ideas.
Hope I am not hijacking to bad.
ewilly is offline   Reply With Quote
Old 03-06-2015, 08:02 AM   #10
deafanddiabetic
Oddometer: 158
Popped Relay?
Ideas.
Have you physically tested the rear sub harness with a voltmeter to see if power is actually going to the bulb socket?
Again, depending on what model you have the tail light and gauge lights are on in "park" mode as well as run. My rear lights are run from my light relay by a grey/violet wire. But if I had it plugged into the wrong post I'd lose my running light/gauge lights but my brake lights did work. If yours started only after you changed your tail light to something else, start with the bulb and if not there, check the wiring again.
Old 03-06-2015, 08:08 AM   #11
Prmurat
Prmurat's Avatar
Oddometer: 1,063
No ground with the powder coat paint?
Prmurat is offline   Reply With Quote
Old 03-06-2015, 07:49 PM   #12
Warin
Retired
Oddometer: 2,266
The gauge lights and rear running light (tail light) usually run off the same circuit... Got head lights?
Not likely to all those bulbs blown at once, nor ist it likely to be the ground.. So look at where the power gets switched to those lights .. handle bar switch?
Which model and year of bike?
Warin is offline   Reply With Quote
Old 03-07-2015, 04:11 PM   #13
ewilly
Oddometer: 120
Lights
Yes got head lights and no power for tail at harness connector under seat.
It is an 84 r100
Old 03-07-2015, 10:15 PM   #14
Warin
Retired
Oddometer: 2,266
Pull out your wiring diagram.
There is a switch that turns on your lights (headlight/tail light) .. on the left handle bar ..
You want the wire from that that runs off to the tail light (and gauge lights) .. it goes to your headlight bucket .. that is where you want to test ..
Is there power coming out of the switch ? No .. And the headlight works .. that means there is power to the switch .. so then probably the switch ...
If power comes out of the switch then there is a connector from there to the gauge lights and the rear tail light .. check there.
Old 05-12-2015, 01:28 PM   #15
canehdian_guy
Oddometer: 66
Refresh: my running tail light is not working, but my brake lights, headlight and gauge lights are working.
I have a color diagram in front of me, but I'm having trouble making sense of this.
In the diagram there are three wires leading to the tail/brake light: one is the ground wire, another is connected to the front/rear brake switch, and the last one connects to the ignition switch.
Where should I start? Would it be a connection prior to the ignition switch? Because that's all I could think of.
Times are GMT -7.   It's 03:25 PM.
