Old 10-06-2012, 08:59 PM   #1
tenderfoot OP
PRJ
tenderfoot's Avatar
Oddometer: 1,409
R50/2 Ignition switch
My bike's switch is stuffed.
Headlight and ignition stays on.
The ignition switch unit inside the headlamp appears to have been roughly repaired some time in the past and is in a sorry state.
Are these easy to fix, or where can I get hold of a replacement unit ?
My usual sources of parts do not even list such an item.
tenderfoot is offline   Reply With Quote
Old 10-07-2012, 01:23 PM   #2
no5s
Terror at 2 mph
no5s's Avatar
Oddometer: 314
/2
Talk to Vech at Benchmark motor works.
93 R100GSPD
84 R80 ST
64 R50/2
92 K75S
no5s is offline   Reply With Quote
Old 10-07-2012, 06:23 PM   #3
SDVET
SDVET's Avatar
Oddometer: 165
The switch itself is pretty simple, getting it out of the headlight shell can be tedious. You have to bend back 4 small tabs and the switch assembly will come out. The tabs are stiff and the switch plate is fragile, so be careful. Once out it is a simple circuit to diagnose. The key pushes a contact down, and a wiper goes side to side for the lights.
Mine was labeled (terminal #'s) just like the manual.
SDVET is offline   Reply With Quote
Times are GMT -7.   It's 10:21 AM.
