Old 09-01-2013, 07:32 AM   #1
wienerdog_racing OP
Oddometer: 58
Question need help with 2000 1150 gs misfire
I bought a gs that sat for four years....i own a second gs..2001...i replaced fuel lines and disconnects..cleaned injectors slightly by soaking them in seafoam...ive got a misfire at idle that eventually stops engine from running...seems worse as it warms up...ive swapped fuel tank..plug wires..plugs...coil..ecu..checked thottle cables..air filter and i still have misfire..wtf??!??..any thoughts
wienerdog_racing is offline   Reply With Quote
Old 09-01-2013, 07:36 AM   #2
wienerdog_racing OP
Oddometer: 58
Also notice when i tug on throttle cable on air intake side...bike revs up...when i do other side throttle cable...nothing...kinda sounds like it flooding out on that side...dunno what this neans tho
Old 09-01-2013, 08:08 AM   #3
tjt94
Oddometer: 594
Check if the throttle cable is seated on the right side of the bike. If it is, sync the TB's.
tjt94 is offline   Reply With Quote
Old 09-01-2013, 08:24 AM   #4
Tmaximusv
Tmaximusv's Avatar
Oddometer: 765
This^. It might look right, but the cable needs to sit inside the ferrule on the right side or nothing works right. DAMHIK.
Illegitemi non-corundum est.
Tmaximusv is offline   Reply With Quote
Old 09-01-2013, 08:45 AM   #5
wienerdog_racing OP
Oddometer: 58
Right side as i sit on it??....rear brake pedal side?
Old 09-01-2013, 11:21 AM   #6
wienerdog_racing OP
Oddometer: 58
Right side cable looks correct...just adjusted valves n no change...sync tbs nxt..lets see
Old 09-01-2013, 11:30 AM   #7
wienerdog_racing OP
Oddometer: 58
Sync done n still got a miss at idle...wtf
Old 09-01-2013, 12:36 PM   #8
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,106
adjust cable at throttle end?
A bad HES can have similar effect. My understanding is the HES controls when the fuel injectors spew fuel.
Transmitted through a Paradyne 1200 baud rate Hayes compatible modem.
Just remember, once you're over the hill, you begin to pick up speed.
Devil's advocate. Hell conscientious and informed and downright argumentative dissenter.
krellheat is offline   Reply With Quote
Old 09-01-2013, 12:58 PM   #9
wienerdog_racing OP
Oddometer: 58
Laugh
Problem solved....bad injector
Old 09-01-2013, 05:27 PM   #10
wienerdog_racing OP
Oddometer: 58
Problem came back....then left again.....strange.....
Old 09-01-2013, 05:56 PM   #11
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,106
Missing gremlin bell.
Old 09-01-2013, 06:59 PM   #12
wienerdog_racing OP
Oddometer: 58
I think its just pushin out a terd thru the fuel system....
Old 09-01-2013, 07:32 PM   #13
krellheat
Pepsi Challenged
krellheat's Avatar
Oddometer: 2,106
did u run techron or seafoam through it?
Old 09-01-2013, 09:06 PM   #14
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 1,801
This sounds like the HES check out some of the threads here on the topic of HES or Halls sensor
Sent from my GT-I9505 using Tapatalk 4
None
dirtsurfer is offline   Reply With Quote
Old 09-03-2013, 08:11 AM   #15
wienerdog_racing OP
Oddometer: 58
From what i read it says hall sensor failure causes bike to die...mine doesnt die..just a miss at random times...
Times are GMT -7.   It's 07:38 PM.
