Old 09-20-2012, 12:30 PM   #1
gasolinePony OP
gasolinePony's Avatar
Oddometer: 27
The Solemn Airhead Pledge. As a lover of the 2-valve...
So I think that all Airheaders need to pledge some things. What would they be?
I'll start:
  1. As a lover of the 2-valve twin, I solemnly swear that I shall not refer in any serious context to my motorcycle as a "hog", as in "I had a day off from work, so me and the gal took the hogs up to North Conway." OR "I can see that your skills are improving as a rider. Have you considered buying a larger, more powerful hog?" If any serious reference is made to my bike as a hog, I will be prepared to accept that my credibility may be up for reconsideration. Conversations about bacon and other pig products that are made near motorcycles will not be subject to this restriction.
  2. I promise to always change my crushwashers when changing the oil, even if it means that I will be late to the bar.
OK NOW YOU.
gasolinePony screwed with this post 09-20-2012 at 01:22 PM Reason: I thought of a new rule.
gasolinePony is offline   Reply With Quote
Old 09-20-2012, 01:02 PM   #2
Renner
infamous wrench
Renner's Avatar
Oddometer: 2,177
pig ok?
as in, "that pig of mine was puking so much oil past the pushrod seals that I stuffed the gap with tampoons "borrowed" from my girlfriend."
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 09-20-2012, 01:11 PM   #3
Beater
Dirty
Beater's Avatar
Oddometer: 3,203
In my experience, a tampon only works well for the breather valve and the dipstick.
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is offline   Reply With Quote
Old 09-20-2012, 01:13 PM   #4
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 659
Maxi pads with wings: the way to go.
Kt-88 is online now   Reply With Quote
Old 09-20-2012, 01:16 PM   #5
gasolinePony OP
Oddometer: 27
*The term "pig" shall be allowed in cases where the Airhead in question is not performing in a manner that pleases.
Old 09-20-2012, 01:18 PM   #6
Renner
infamous wrench
Renner's Avatar
Oddometer: 2,177
you're right, my bad.
I meant to say "pig mat" borrowed from my girlfriend.
Old 09-20-2012, 02:46 PM   #7
Grayghost66
Grayghost66's Avatar
Oddometer: 213
  1. I will not apologise to anyone about the horsepower output on my 1000cc GS.
  2. I will not cuss,fuss, swear and throw things while trying to synconize my BINGs
  3. I will at least give the German engineer, as sadistic as he or she may be, that designed that hinged oil filter, double O Ring, secured with three Allen heads, total PITA maintenance chore......a running start :) The prize if you get it wrong....engine failure.
My GS pulls to the right...or the left...depending on what side of the road the Tim Horton's is on.
Grayghost66 is offline   Reply With Quote
Old 09-20-2012, 03:11 PM   #8
mykill
odd
mykill's Avatar
Oddometer: 1,162
I will not curse the clutch, splines, and main seal as they are accessed far less often than valves, carburettors and points.
I will not curse when I burn my forearm on my header pipes and wear that mark as a badge of honor.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 09-20-2012, 08:49 PM   #9
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,484
Squid: My Ninja is faster than your 60.
Me: OK, may be. Let's get together again in 30 years and we'll compare notes.
Said this in the '70's, still saying it today...
'73 R60/5 Toaster
Old 10-07-2012, 04:08 PM   #10
luxlogs
luxlogs's Avatar
Oddometer: 295
I will keep current on my Airhead Dues, those guys are the reason my Airheads run so sweet. Thanks Don in IN and Ed in IL, the two gurus who wrenched my bikes this past summer.
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
luxlogs is offline   Reply With Quote
Old 10-07-2012, 04:55 PM   #11
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,676
I acknowledge my airhead wants to outlive me and I will render all posible assistance to allow it to do so.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Times are GMT -7.   It's 05:31 PM.
