Old 10-07-2012, 03:30 PM   #16
R100LT OP
Chasing 11
R100LT's Avatar
Oddometer: 631
The pick up screen was in place when I removed it .
What I am dreading is that when I installed the Enduralast Alt ... I had the local mechanic around the corner torque the bolt because I didn't have a spanner at the time . As he was putting it in ... he added lock tight ... so I think I might be in for a challenge when trying to remove it
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 10-07-2012, 04:05 PM   #17
Cordless
Two Wheel Addict
Cordless's Avatar
Oddometer: 2,039
Unless he used permanent locktite (red) shouldn't be a problem. Apply a bit of heat if you want it to release easily.
Cordless is offline   Reply With Quote
Old 10-07-2012, 04:24 PM   #18
R100LT OP
Chasing 11
R100LT's Avatar
Oddometer: 631
By memory I think he used the red permanent locktite ... he put it on whilst I was on the phone .
Might try and use a soldering iron first ... if that doesn't work I think I am off to buy a propane torch
Old 10-07-2012, 04:38 PM   #19
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,471
65K-km (40K-miles) it wouldn't be a bad idea to check and replace the timing chain, etc. Remember to check and possibly replace the crankshaft sprocket, too.
I hope the pick up screen wasnt laying there also.
The rubber bits collected there because of the oil flow towards the screen.
(mechanic)used the red permanent locktite ...
Might try and use a soldering iron first ... if that doesn't work...
Not good practice. You'll need to heat the part to 300-400 deg F to loosen the Loctite. Soldering Iron won't work. Try and break the bolt loose first, then try heat. DON'T snap the bolt or round it off-- it'll be hell to pay to repair it.
The taper-fit rotor needs to go on the taper oil free, even fingerprint free, inside and out. No exception.
How is the enduralast rotor removed? Same "removal bolt tool" as the stock rotor?
'73 R60/5 Toaster
Times are GMT -7.   It's 11:37 PM.
