Old 10-17-2012, 03:40 PM   #31
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,529
Originally Posted by Airhead Wrangler View Post
Third, it says you can kill the engine by holding the high beam and left turn signal at the same time.
Way too complicated. KISS logic is the way to go.
Rob Farmer is online now   Reply With Quote
Old 10-17-2012, 03:56 PM   #32
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,468
Originally Posted by Rob Farmer View Post
I like the idea of those M Units. Are the relays replaceable? What current can they switch?
No relays, it's all solid state with built in fault detection that automatically cuts power to a circuit in the event of a short. Read the manual here. It shows the max load for each circuit in one of the diagrams. With his setup, near zero load is going through handlebar switches. No relays or fuses required either. The downside is that the only replaceable part is the whole unit.
http://motogadget.com/media/download...l_en_3.1_k.pdf
EDIT: I just looked up the max loads for each circuit:
L+R turn signal circuits 10A (!) each
Horn 10A
Starter 30A (enough to go straight to a Valeo or Bosch solenoid w/o starter relay)
High and low beam circuits 10A each
Brake light 10A
Ignition/Aux 18A
All switches only take .01A, so very small signal wire can be used.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 10-17-2012 at 04:03 PM
Old 10-17-2012, 03:57 PM   #33
Airhead Wrangler
Adios Mexico
Oddometer: 6,468
Agreed. I didn't elaborate further on the fact that I DON'T like that function and wish it could be disabled.
Old 10-17-2012, 04:10 PM   #34
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,529
Great stuff. Thanks
It's the zero load through the switches that causes most problems on vehicles. At least with a bit of current behind it the crap is generally burnt of the contacts.
Times are GMT -7.   It's 09:20 AM.
