Old 07-31-2013, 08:29 AM   #451
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,362
The hoops are pretty nice. I too thought about talking the racks off when not needed, but then figured out it was not worth the hassle and the wear on the components (tank threaded inserts).
The wolfman racks are pretty slim and unobtrusive. They also help reinforce the rear subframe and protect the bike in case of tip overs.
The Hoops are a nifty idea. They are priced as a set. The volume is a bit small, but unavoidable given the diameter of the rack opening.
I can snugly fit a med duty front and rear tube on one side and a Nalgene bottle in the other. Perfect size to stuff a rain shell in or some tools.
Yellow Pig is online now   Reply With Quote
Old 08-05-2013, 04:49 AM   #452
cowchaser
Oddometer: 16
Rode mine tonight for the first time on my test track behind my farm. Can't wait to get it to the desert.
cowchaser is offline   Reply With Quote
Old 08-05-2013, 06:17 AM   #453
GravityDT
Oddometer: 58
Anyone with the Evo2 Tanks/Shrouds only have the new Rally Raid graphics kit installed? Got a pic you could post, curious how it came out. Seen a bunch of the fairing kit w/ graphic - just interested in the new tank/shroud graphics kit
11 690 Enduro R
07 640 Adventure SOLD
12 350 XCF-W SOLD
GravityDT is offline   Reply With Quote
Old 08-06-2013, 03:44 PM   #454
kingoftwins
kingoftwins's Avatar
Oddometer: 98
Flipping the Throttle for Cable Play
Great idea and mod in order to get that extra bit out of your throttle cables. In the future you can get a true +4 inch longer throttle cable sets at KTMTwins.com cheaper than a set of OEM cables from KTM. They have all the adjusters including all the adjusters you are looking for that aren't typically found on aftermarket replacement cables. For future reference.
Originally Posted by Yellow Pig View Post
Clutch line is fine. Throttle had to be rotated 180 pointing down. The BRP mount gives X amount of rise. I got the additional 1.5cm from a cheap handle bar spacer kit.
Similar to this:
Ron Nichols
www.ktmtwins.com
69 Duboce Ave
San Francisco, CA, 94103
415-968-9467
kingoftwins is offline   Reply With Quote
Old 08-12-2013, 04:36 PM   #455
jonnykilo
Traveller
Oddometer: 205
Your "farm's" test track includes stunning beachfront cliffs? WOWOW
jonnykilo is offline   Reply With Quote
Old 08-19-2013, 01:41 AM   #456
cowchaser
Oddometer: 16
Yes lucky to live in a lovely part of the world.
Old 08-22-2013, 04:46 PM   #457
hobbes67
Oddometer: 38
Mine finally completed!
bold new graphics added and fully serviced bike, after 7000 kms across turkey.
many thanks to John for a fantastic customer service!
Gianluca
hobbes67 is offline   Reply With Quote
Old 08-22-2013, 06:56 PM   #458
nevgriff64
Spelt with 2 ffs
nevgriff64's Avatar
Oddometer: 13,910
Gianluca
That's a really nice looking bike, Hobbes.
Any photos from other angles that you can share with us?
nevgriff64 is offline   Reply With Quote
Old 08-22-2013, 08:04 PM   #459
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,362
The white and orange graphics look great
Sent from my Nexus 7 using Tapatalk HD
Old 08-22-2013, 11:39 PM   #460
gen
gen's Avatar
Oddometer: 799
Gorgeous scenery you have.
Question: you've chosen to stick with the high fender. Did you consider a low fender or not really?
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is offline   Reply With Quote
Old 08-23-2013, 12:17 AM   #461
hobbes67
Oddometer: 38
thank you!
let me take some more and I will post. just installed the graphics
Old 08-23-2013, 12:18 AM   #462
hobbes67
Oddometer: 38
thank you Yellow Pig!
I like yours in orange too. What is the rear rack and tail bag you have on your bike? are they both from Wolfman? happy with them?
cheers
Gianluca
Old 08-23-2013, 02:21 AM   #463
Xico
Oddometer: 16
Which lights are those, on the grille, bellow the front fairing?
Do they fit nice in there, or do you have to trim the plastic to make it fit?
Xico is offline   Reply With Quote
Old 08-23-2013, 08:15 AM   #464
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,362
The racks and top plate are Wolfman. Great product 100% recommended.
The LED light is a Baja Designs SII. The light fits perfectly in the KTM 990 grill, you just need to trim the mesh screen. The installation and fitment is a bit difficult and the space is tight.
I made a large square U shaped bracket that bolts to the sides of the rally fairing support frame and holds the LED light at the bottom of the U.
Old 08-23-2013, 08:17 AM   #465
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,362
Gianluca,
Che anno e' la tua 690? Io ho la 2013 e sulla mia il parafango basso batte sotto il triple clamp piu basso a massima compressione e mi sta' ammaccando il sopra del parafango.
Times are GMT -7.   It's 07:04 PM.
