Old 11-07-2013, 01:44 PM   #556
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 487
Thats the one... fluorination. It is applied to thw inside of the tanks.
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 11-08-2013, 12:46 AM   #557
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 976
Well, it certainly doesn't work
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 11-08-2013, 03:01 AM   #558
Jan from Finland
Registered
Oddometer: 567
Originally Posted by overlandr View Post
In the unfortunate event of one's precious 690 sliding down the road on its side over tarmac (=blacktop?) at around 70mph, that protruding lower corner of the tank will be ground down in a second or two.
Have you tested your theory? Which part grinds first if bike is on its side? Would a fork crash-pad help?
If you are ever attacked by lion, your best defense is to shove your arm down
their throat, grabbing the back of their tongue and hope help arrives quickly.
- Pro Travel Tip by Overland Journal
Jan from Finland is offline   Reply With Quote
Old 11-09-2013, 08:52 AM   #559
overlandr
Dystopist
Oddometer: 5,900
Originally Posted by timolgra1 View Post
I'm very fortunate
Hope you've still got the 640a, Tim.
I'm not a 690 rider. Just thinking that sacrificial parts that protrude might help...
overlandr screwed with this post 11-09-2013 at 08:58 AM
overlandr is offline   Reply With Quote
Old 11-09-2013, 10:36 AM   #560
timolgra1
timolgra1's Avatar
Oddometer: 501
Yes mate, my all time favourite bike :)
timolgra1 is offline   Reply With Quote
Old 11-27-2013, 07:28 AM   #561
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
Pic's wanted..
Looking for pics of a 690 with Evo 2 tanks/shrouds and fenders/mask all in white. This is without the full faring kit, just tanks and shrouds. Especially with the RR White graphics kit.
Also, can someone school me on the quality of the RR graphics kit. @ $300+ for the set, they better stay awhile, not peel and look super sharp.....
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 11-28-2013, 03:32 AM   #562
cowchaser
Oddometer: 17
Mine have been on since August and have not peeled or bubbled. They are also one of the best fitting kits I have applied.
2002 CR500E
2013 KTM 690 Rally Raid
2014 KTM 300 EXC
Busted ass old TRX700XX
Oh and my Dakar finishers medal
cowchaser is offline   Reply With Quote
Old 11-28-2013, 11:47 PM   #563
canadius_maximus
Quaere verum - Seek truth
canadius_maximus's Avatar
Oddometer: 587
Slack in OEM speedo unit cabling/wiring?
I've got an EVO 1 kit I'm going to order - but I have a question for those who've bought the RR fairing kit. Should be the same whether it's EVO 1 or 2.
How much slack is there in the OEM speedo unit's cables and wires - in order form the unit to move up into a higher placement in the fairing? I'm travelling at the moment, so I can't check my bike - and would like to know if I need to order any other bits to make the speedo unit work sitting higher.
While supplemented by a GPS and perhaps a secondary odometer unit - to the extent that there is still some basic utility in the OEM computer, it' be nice to mount higher ...
Thanks so much for the help,
CM
By grace alone. Through faith alone. In Christ alone. From Scripture alone. Glory to God alone.
KTM 690 R Rally Raid Evo 1 (and 2) Kit Build for Dummies
canadius_maximus is offline   Reply With Quote
Old 11-29-2013, 12:01 AM   #564
NickW909
NickW909's Avatar
Oddometer: 576
CM
I have the EVO 2 fairing and the cables reach without modification to the intended place in the fairing, they wouldnt go any higher.
Nick
NickW909 is offline   Reply With Quote
Old 11-29-2013, 12:09 AM   #565
canadius_maximus
Oddometer: 587
Nick
Thanks - I should have mentioned that mine is the 2009 model - so the smaller digital unit, vs the larger unit shown on post # 427. Still if the 2009 speedo can be pulled up to sit where this one sits, that'd be just fine.
Thanks,
CM
Old 11-29-2013, 04:00 AM   #566
overlandr
Dystopist
Oddometer: 5,900
Phew! You had me worried there for a sec.
Old 11-29-2013, 05:04 AM   #567
timolgra1
timolgra1's Avatar
Oddometer: 501
It's growing on me though
Old 12-03-2013, 05:15 PM   #568
carlosbarrios
carlosbarrios's Avatar
Oddometer: 228
EVO2 Light low beam height
I've been struggling trying to aim my EVO2 low beam correctly. I know the high beam can be adjusted separately with the front torx screw, but the low beam can only be adjusted by moving the whole light around the 4 mounting bolts.
If I aim the low beam properly, then the front mask fairing doesn't fit flush against the light. In fact, the gap is so big, I can easily fit my fingers between them. If I adjust the light so that it fits flush against the fairing mask, then the low beam is aimed very very low. The only way to adjust it properly and have it sit flush against the fairing mask seems to be to somehow move the entire frame up.
Is anyone else having this issue? Is there another way to adjust the low beam?
It's not an adventure, unless at some point, you're not sure if you're gonna make it back...
2008 KTM 690 Enduro - RR EVO2 Rally Kit!
2008 KTM 250XC
carlosbarrios is offline   Reply With Quote
Old 12-03-2013, 05:33 PM   #569
NickW909
NickW909's Avatar
Oddometer: 576
Yes, with the low beam set correctly I have a large gap at the top. I have shaved away some of the fairing at the bottom to allow the light unit to move forward, but I'm looking for something to plug the gap at the top. Maybe some sort of foam cut to shape? I currently have a section of rubber tubing in the gap around the high beam.
Nick
Old 12-09-2013, 04:26 PM   #570
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
The DHL truck came today and left off a big brown box from the UK at my door.
Got the front sprocket billet, top and bottom tank bolts installed.
Tomorrow I start on the Evo2 tanks and shrouds, minus the faring.
I also got the graphics kit, so my question for you guys with all the experience is: Should I install the graphics before installing the plastic?? Or install the graphics after everthing is on the bike. Seams like it would be easy to bring the parts (tanks, fenders and maska) into my heated office and put them on there....
Also, any other advice on installing the graphics would be appreciated... Any how to's??
Seams like this it the kind of think about the time you get through, you've then learned how to do it.
Times are GMT -7.   It's 04:51 PM.
