Old 10-07-2012, 05:42 PM   #1
chau OP
Oddometer: 39
Best tire
Rear tire on my 2007 GS is leaking slowly. Tire is a Tourance and has about 1500 miles on it. Had a screw in it earlier this year and got it professionally plugged and patched. However if i don't ride the bike for week or so, i notice tire becomes under inflated. I've decide i'm going to change the rear tire.
I live on the east coast (NYC) and most of my riding is on streets and highway touring and I ride year-round except for when it snows. What is best tire for 95% street as I do not off road?
Do I need to match the front or is it ok to keep the front (Tourance)?
chau is offline   Reply With Quote
Old 10-07-2012, 05:45 PM   #2
yellowbirdrs
yellowbirdrs's Avatar
Oddometer: 966
Tourance is a great tire but if you don't need the off road capability try the Scorpion Trail or the Conti Trail Attack
yellowbirdrs is offline   Reply With Quote
Old 10-07-2012, 06:06 PM   #3
'05Train
Mind is not for rent
'05Train's Avatar
Oddometer: 1,086
Michelin Pilot Road 3. Smooth, comfortable, quiet ride, stellar grip in corners, sheds water like no one's business.
2005 FXSTB/I
2014 K1600GTL
2014 KLR650 NE
'05Train is offline   Reply With Quote
Old 10-07-2012, 06:19 PM   #4
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,623
Conti trail attacks.
I preferred them over the pr3.
ST1300 - IRON BUTT # 23,716
GAS GUY is offline   Reply With Quote
Old 10-07-2012, 06:26 PM   #5
'05Train
'05Train's Avatar
Oddometer: 1,086
Doesn't look like much siping on them. How are they in the rain?
2005 FXSTB/I
2014 K1600GTL
2014 KLR650 NE
Old 10-07-2012, 07:11 PM   #6
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,623
They always felt good in the rain
They are smoother and more quiet than pr3.The rear pr3 tire sings.
Pr3 turns neutral, TA turns in quicker.
Pr3 feels worse on hot tar strips.
Old 10-08-2012, 05:11 AM   #7
JLeather
Bike Butcherer
JLeather's Avatar
Oddometer: 300
I've always been very happy with my Tourances. By the way, have you tried replacing or atleast tightening the core in the valve stem? The shop that plugged your tire likely removed the core to deflate it. Sometimes they don't get tighetened up all the way or they get a piece of dirt under the seal when you remove them. I'd replace the valve stem core (costs about $1.00) and see if it stops leaking before I replace the tire.
JLeather is offline   Reply With Quote
Old 10-08-2012, 05:17 AM   #8
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,505
I agree with JLeather, check the stem.
I'm also a big fan of the Tourance if you have no offroad to do. Great stick, great mileage.
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 10-08-2012, 05:31 AM   #9
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,738
Check the stem/core.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 10-08-2012, 05:43 AM   #10
RTCHIEF
Oddometer: 332
leak
Check the valve cap for debris. It can push down on the core and allow air to be released. Jon
RTCHIEF is offline   Reply With Quote
Old 10-08-2012, 07:39 AM   #11
'05Train
'05Train's Avatar
Oddometer: 1,086
Interesting. I've got no issues with tire noise from the PR3s, but it sounds like I should try the Conti.
Thanks.
2005 FXSTB/I
2014 K1600GTL
2014 KLR650 NE
Old 10-08-2012, 07:53 AM   #12
ragtoplvr
Oddometer: 6,598
Shinko Raven or Verge. They have bigger grooves and deeper tread than other tires, I ride on gravel frequently and these do very nice for street tires. And I have drug foot pegs, they simply work. And inexpensive.
There have been a LOT of substandard valve stems out there. On some the rubber will be bad in less than a year, as it was inferior grade.
On my 2 year old riding mower, I heard a pop while mowing, the metal part just shot out. Instant flat. All the valve stems were were very bad. Same size as used on motorcycles.
Always check your valve stems.
Rod
ragtoplvr is offline   Reply With Quote
Old 10-08-2012, 08:14 AM   #13
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,390
+1 on the Pirelli Scorpion Trail, if you can't patch that Tourance. The Scorpion has been excellent on road, and decent off road.
High Country Herb is offline   Reply With Quote
Old 10-08-2012, 08:47 AM   #14
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,844
+1
Love 'em.
The name is misleading because they are definitely a 90/10 road oriented tire. I would not put anything else on my GSA.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 10-08-2012, 09:07 AM   #15
viperh
StormChaser
viperh's Avatar
Oddometer: 122
I always ran the Anakee 2's got anywhere from 10 - 14K miles out of them, handled well in the rain and ok in light snow <.5" (I ride year round). Hardly any road noise when new however when you get a flat spot (live in Indiana not much turning) they sing. I didn't really have to spend hardly any time scrubbing them in either.
viperh is offline   Reply With Quote
Times are GMT -7.   It's 06:38 AM.
