Old 02-01-2014, 05:10 PM   #1
pizzaboy OP
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,103
FD Outer seal removal issue
I followed standard procedure of:
remove dust cover and circlip
drill hole just through seal in dimple, just piercing
screwed in sheet metal screw just until it bites in hole
pulled with pliers
ITS NOT BUDGING
Bottom photo shows the 3 holes in seal I have tried 2,3 and 8 o'clock and the screw I'm using.
Should I spray some lube in there see if that helps or maybe open the fill plug on other side to help release any possible suction affect ??
Open to some help
Thanks,
Barclay
Before:
Where I'm at now:
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is offline   Reply With Quote
Old 02-01-2014, 05:18 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,243
Use a slightly larger more aggressive screw and a pair of wire cutters prying against the center of the axle.
Old 02-01-2014, 05:38 PM   #3
pizzaboy OP
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,103
Thanks Jim, I had a good bite but was pulling straight out. I'll try your suggestion.
'09 BMW R1200GSA
Times are GMT -7.   It's 05:53 AM.
