10-07-2012, 11:07 PM
#1 |
Oddometer: 58
Partial Seizure or Fuel Vacuum?
Hi,
I'm part way through the running in process on my little KH100 after I did the top end: one run until warm on the centre stand, and 4 rides or so starting at 5-10 minutes and gradually working it up to 30 minutes or so while varying the RPM and not spanking it. So far so good, engine seems smoother and happier already and no signs of the overheating/partial seizure I was getting pre-rebuild. Engine gets nice and warm, I'd say hot to the touch, but there is no loss of power or change in performance, no noises, along the way. It seems to have done the trick. However, today a nice day of 21C I took it for the longer ride I've done and twice I had the engine stop suddenly on me. I am 99% sure it is not a seizure and is not due to overheating. I am fairly sure it is due to my tank cap not venting properly and the fuel flow cutting. This despite being certain it was fixed after a nice long soak in some white vinegar - now when opening the cap I get nowhere near the sound of opening a Coke bottle like I was getting before. You see, once it stops I open the tank cap and and give it one kick, it roars into life and shows no negative/hot symptoms. So, I thought I'd ask, what are the signs of a partial seizure? Am I right in thinking there warning signs that show up before hand like gradual loss of power as it gets hot, engine losing it's smoothness, generally getting baggy? The rebuild has been otherwise flawless until now. Thanks for any help. I love this little bike :) |
10-08-2012, 05:38 AM
#2 |
Oddometer: 4,314
It is probably a lean seizure due to lack of fuel. Fix the cap before riding further. Sooner or later you'll kill it.
In reality there's no such thing as a partial seizure. If it sticks and stops running it's a seizure. There are varying degrees of damage from seizure. Pull the pipe and have a peek into the exhaust port to see the damage. Post up some photos if ya can.
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
10-08-2012, 06:08 AM
#3 |
Oddometer: 58
Cheers anotherguy. Now after getting the tank cap vents much cleaner I'm wondering whether it's that or something further down the line... any ideas? If it is the cap, any other ideas on how to get those little vent holes clear?
Will pull the exhaust and have a look and take photos ASAP before any more riding. I hope I haven't messed this up :(. Just to clarify the terminology, no fuel = seizure? I presume if no fuel/oil gets up into the combustion chamber above the piston, then the rings get no oil and they stick, right? I'm a complete noob. There is one other thing I have noticed that the bike has nearly always done. That is, particularly in 1st or 2nd and early in the ride (after warm up, of course), it will often not rev completely freely. At low rpm it will be fine and then it will only rev up until a ceiling and 'stick' at a constant rpm. After a few accelerations it will stop doing it. What could this be? Thanks for your reply. KayAitch screwed with this post 10-08-2012 at 08:15 AM Reason: too verbose |
10-08-2012, 08:17 AM
#4 |
Unsprung Weight
Oddometer: 1,100
Are you using the oil pump or premixing? How are the crank seals? Have you tested your venting theory by letting the fuel free-flow into a container
to see if the flow stops at some point? BTW-ccol bike.
1991 Honda XR628R 1978 Yamaha XT500 1965 Hodaka Ace 90 |
10-08-2012, 08:21 AM
#5 | |
Unsprung Weight
Oddometer: 1,100
10-08-2012, 08:25 AM
#6 |
Oddometer: 58
I am using the oil pump to the right setting and it is definitely working. The spark plug, new from the beginning of the running-in process looks just about perfect. If anything it looks slightly rich, but not too rich.
I haven't been to the crank seals yet. Anything a noob like me can look for? I guess I'm going through a process of elimination and I was kind of hoping it would end at this top-end rebuild :) It's an old thing so I'm fearing the worst. A while back before I cleaned the cap I needed to empty the tank and the flow would be fine for a while and reduce to a trickle/nothing, then if i opened the cap it would start again. On the basis of what I have read this lead me to confirm the venting/flow issue. It'll be cooler when it stresses me a tiny bit less :)
KayAitch screwed with this post 10-08-2012 at 08:50 AM |
10-08-2012, 08:30 AM
#7 | |
Oddometer: 58
This 'rpm ceiling' is occurring straight out of the driveway for the first 2 or 3 accelerations in 1st and 2nd so maybe that is just loading up from warming up? I do blip the throttle a bit. Perhaps once warm it should be given some heftier twists to clean it up? KayAitch screwed with this post 10-08-2012 at 08:44 AM |
10-08-2012, 10:34 AM
#8 | |
Unsprung Weight
Oddometer: 1,100
10-08-2012, 07:18 PM
#9 | |
Oddometer: 58
I believe this to be the case. Pre top-end rebuild I would ride along and release the cap every 5 minutes or so because I was aware of this venting issue (I have pulled the hose off the tap previously after it has cut out to find no fuel coming out of the tap. Also, emptying the tank I would get a little run out of the tap but then it would stop. Releasing the fuel cap would start the flow again).
During the running in I wasn't bothering to open the fuel cap because I thought the vents were clear. What does a leaky crankcase do that would cause this? Again, apologies. I'm learning as we go :). Yes it is a rotary valve with the carb inside the engine case. I have heard of leaks between the carb and the mount before. Again, would this cause this cutting out condition? The loading up does clean up after a couple of accelerations, thanks. I really hope I don't need to split the case. Thanks again. Quote:
10-08-2012, 09:29 PM
#10 | |
Unsprung Weight
Oddometer: 1,100
10-11-2012, 11:39 PM
#11 | |
Oddometer: 641
![]() You did pretty much describe how it feels...and the motor will lock up temporarily....you'll know if its seizing or not.
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack Sierra Thumper screwed with this post 10-11-2012 at 11:47 PM |
