Old 10-08-2012, 08:00 AM   #1
bigdon OP
Oddometer: 2,072
Final Drive Vent Question
I have an 03 1150 GS Adventure with 66,000 miles on it.
Because of my internet reading I rebuilt my Final Drive and Driveshaft.
Not long after the rebuild my big seal started leaking a bit. I thought that it might have been because of using Synthetic Lube.
I very carefully changed the seal and used non synthetic lube in it. I did not see any more leaks.
Saturday morning we had our first cold snap. The last time I rode the bike it was 100 degrees. Saturday it was about 50 degrees and I rode about 200 miles. I noticed that my seal was leaking again. It may have been worse this time.
My question, could my vent be stopped up causing pressure to build and forcing oil past seal? I'm sure that there would be more chance of this because of the colder temps.
How do I remove and check vent?
Thanks, Don
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is online now   Reply With Quote
Old 10-08-2012, 09:41 AM   #2
def
I have little to say
def's Avatar
Oddometer: 6,305
Send a message via Skype™ to def
Don't know the reason for the leak but it surely isn't because of synthetic GL-5.
def is online now   Reply With Quote
Old 10-08-2012, 10:39 AM   #3
Girthy Knobkers
Girthy Knobkers's Avatar
Oddometer: 57
Too much fluid blows the seal on my 1100...
Girthy Knobkers is offline   Reply With Quote
Old 10-08-2012, 10:40 AM   #4
def
def's Avatar
Oddometer: 6,305
Flush FDs with ATF after draining and before refilling with fresh GL-5.
Old 10-08-2012, 11:45 AM   #5
jachard
Oddometer: 395
When you replaced the seal, did you make sure to only install it so it's flush with the housing? I found if you push it in too far it will leak.
Cheers, James
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
www.racersandranchers.com
jachard is online now   Reply With Quote
Old 10-08-2012, 01:28 PM   #6
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,488
And this, my friends, is why preventive maintenance on the Final Drive is a bad idea. If it is not broken, do not fix it.
Jim
JimVonBaden screwed with this post 10-08-2012 at 01:43 PM Reason: spelling
Old 10-08-2012, 01:34 PM   #7
bigdon OP
Oddometer: 2,072
Originally Posted by JimVonBaden View Post
And this, my friends, is why preventive maintenance on the Final Drive is a bad idea. If it is not proken, do not fix it.
Jim
Where were you 3 months ago!
Ride Pooie Ride
Old 10-08-2012, 01:43 PM   #8
JimVonBaden
"Cool" Aid!
Oddometer: 41,488
Sorry!
Jim
Old 10-08-2012, 04:58 PM   #9
Wallowa
Oddometer: 4,474
Hmmmm.
Jim
Jim,
"maintenance" not including changing FD lube or lubing spline...correct?
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
Wallowa is offline   Reply With Quote
Old 10-08-2012, 05:56 PM   #10
JimVonBaden
"Cool" Aid!
Oddometer: 41,488
Originally Posted by Wallowa View Post
Jim,
Right, I should have been more clear. Preventive rebuilding.
Jim
Times are GMT -7.   It's 12:28 PM.
