Old 10-08-2012, 10:01 AM   #1
cbmind OP
Oddometer: 35
2012 Adv R Fuel Pump Wiring
Well, I did it, f'd up...Pulled the left tank off yesterday, managed to pull the wiring out of the back of the plug on the fuel pump side...I have a red, blue, black wire coming from the fuel pump, but only a brown, red/black on the other side of the connection (going to the computer or relay something) Can someone here help? Been looking for wiring diagrams, can't find anything on this model. Presume it's the same for previous 990s. Need what wire goes to what, thanks, fantastic site.
cbmind is offline   Reply With Quote
Old 10-09-2012, 12:01 AM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,070
Mine is a 2006Adv European
The pattern is correct. Three wires on the pump side since on the SuperDuke there is a fuel level sensor on the pump and passes through the third wire. The Adv has a separate fuel level sensor, so one is unused.
Cheers.
Old 10-09-2012, 02:51 PM   #3
cbmind OP
Oddometer: 35
Understand, thanks for the info, but also needing the wiring color coding... A red wire, blue wire, black wire are coming from the pump side of the connection and a red/ black wire, brown wire on the bike side of the connection.
Old 10-14-2012, 06:10 PM   #4
cbmind OP
Oddometer: 35
Solved.
I'll post here in case anyone needs this reference for their work...from the pump the blue is not used, red goes to the red/ black, black goes to the brown wire. Hope this helps.
Old 05-20-2013, 02:00 PM   #5
Izn0g00d
Trail's body
Izn0g00d's Avatar
Oddometer: 4
yes It's helping ... at least ME !! thank you
Izhappy
Izn0g00d
Husaberg 570 2011
KTM 990 Adventure 2008
Izn0g00d is offline   Reply With Quote
Old 06-20-2013, 10:00 PM   #6
Single Track Magnet
I'd hit it...
Single Track Magnet's Avatar
Oddometer: 73
Helped me too! Thank you!!!
At least, on my 2008 the bike side has a blue and brown wire. I assume the blue is positive and the brown is negative? Can anyone verify? I'd appreciate it.
I'm still not using the blue wire that comes from the fuel pump.
Single Track Magnet screwed with this post 06-20-2013 at 10:06 PM
Single Track Magnet is offline   Reply With Quote
Times are GMT -7.   It's 04:01 AM.
