Old 10-08-2012, 08:48 PM   #1
Shawnee Bill OP
Shawnee Bill's Avatar
Oddometer: 2,101
Rear Wheel Speed sensor replacement
Well, the bearings went out in my rear wheel. Fixed that fairly easy but with the bearing out the rear wheel moved over and screwed up the rear wheel speed sensor pickup so I bought a new one.
Problem is how to replace it. The wire goes from the mount by the rear wheel and disappears into the deep dark center of the bike. I can't figure out how to get in there. It seems to end up somewhere under where the seat lock is.
I would really appreciate some advice, hints, clues as to how to get in there.
Thanks in advance!
I'm considering just cutting and splicing the new pickup onto the old cable.
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Shawnee Bill is offline   Reply With Quote
Old 10-08-2012, 10:59 PM   #2
MonsterJ
I have motopsychosis
Oddometer: 262
Bill, hopefully someone'll chime in soon on how to do it. .....but I would caution you on cutting and splicing. I don't think it's quite that simple with an inductance-type pick up. I'm not saying it *can't* be spliced but, you'll probably have to splice the shielding as well. I've had to do it many times in aviation applications and it can be a PITA if you're not careful.
-Nooner
Temple, TX -> Cape May, NJ -> Mobile, AL -> ECity, NC -> Kodiak, AK -> Mobile, AL -> Sacto, CA -> Cape Cod, MA -> New London, CT -> San Francisco, CA -> Juneau, AK (summer of '13) -> where to next?
MonsterJ is offline   Reply With Quote
Old 10-09-2012, 08:12 PM   #3
Shawnee Bill OP
Oddometer: 2,101
Thanks for bringing that up, I'll think about that. I do have some experience splicing shielded cables. If I can't find some hints somewhere I will cut the old one and see what's inside the wire.
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Old 10-29-2012, 10:28 AM   #4
Shawnee Bill OP
Oddometer: 2,101
Figured it out. Looking at the top shock bolt thread I found how to get the cover off of that and discovered the wheel speed sensor plugin is anchored on that cover so from there it was easy to replace.
On a side note my turn signal auto cancel had stopped working when the rear speed sensor was messed up. Replacing that not only fixed the ABS (expected) but the turn signals again auto cancel.
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Old 10-29-2012, 08:11 PM   #5
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
it recognizes changes in speed thus knowing when to cancel your signals... i.e. after accelerating from a stop light turn
Motorfiets is offline   Reply With Quote
Old 10-30-2012, 07:26 AM   #6
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Isnt the auto cancel based on distance and adjustable via access to the bikes computer?
It would use the speed sensor for a distance measure, no?
Times are GMT -7.   It's 02:50 AM.
