Old 10-09-2012, 01:06 PM   #1
lochridge OP
Oddometer: 135
r80st front break caliper questions
i noticed a thread last week (i think) where a guy had a picture posted of his r80st that has two front calipers.
i would seriously like to do that to mine. is there a certain part number that i would need to look for, for the left side caliper?
also what else would need to be modified.......thinking spacers or whatnot.
from my understanding the g/s and st calipers are different.
lochridge is offline   Reply With Quote
Old 10-09-2012, 10:03 PM   #2
Mark Manley
Somewhere else
Mark Manley's Avatar
Oddometer: 373
I have a G/S which I have fitted twin discs and a friend has an S/T which he has done and they are the same parts. It was a while ago but from what I can remember the wider spacer has to be remade 5.5 mm longer, in theory you need to replace the 12mm diameter master cylinder with a 16mm one but in practice if the 12 is in good condition it will do the job, we have both used stainless steel hoses. The extra calipers and discs were bought second hand from a breakers.
If it's in the Touratech catalogue then you don't need it
No man is an island, except for the Isle of Man
Mark Manley is offline   Reply With Quote
Old 10-10-2012, 07:19 AM   #3
lochridge OP
Oddometer: 135
i have a stainless line on there now, it is only about 2 years old.
i did not know about the larger master cylinder though. where can you get one of those?
since i ride in traffic everyday around here, i have people pull out in front of me all the time, and i would just like to have a little better stopping power for when i need it.
thank you
Old 10-25-2012, 05:38 AM   #4
Clay Spinner
Woodfire or Bust
Clay Spinner's Avatar
Oddometer: 398
lochridge... don't bother with the twin disc set up (IMO), you'll be better off getting a front caliper from a r1100 GS (or whatever uses the same one), milling off the tabs a bit (0.158 inch) and using that. I have this setup on mine and it is like having real brakes on the bike. I expect it will be cheaper and lighter than a double disc. once the calliper is milled... its a bolt on bolt off job.
Clay Spinner is offline   Reply With Quote
Old 10-25-2012, 05:49 AM   #5
desmo
desmo's Avatar
Oddometer: 209
http://www.advrider.com/forums/showthread.php?t=625343
Did this on my R100GS. EBAY caliper for $50.00! What a difference!
2002 BMW 1150GSA (some changes)
2003 BMW 1100s BCR(140/200)
1994 BMW R100GS (Bumble Bee)
2007 Suzuki DR 650SE
2001 Porsche 911 (Speed Yellow)
desmo is offline   Reply With Quote
Times are GMT -7.   It's 11:12 PM.
