Old 10-13-2012, 07:42 PM   #1
maigashi OP
maigashi's Avatar
Oddometer: 117
Chain tension
Measurement says no load. Does this mean on the centre stand or just standing there
maigashi is offline   Reply With Quote
Old 10-13-2012, 08:48 PM   #2
Hucker
Lost
Oddometer: 689
Two parts:
1. Side stand.
2. Looser than you think. DAMHIK
Hucker is offline   Reply With Quote
Old 10-14-2012, 01:54 AM   #3
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
it doesnt make much difference IMHO, but on sidestand it's according the Riders manual and REPROM.
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 10-14-2012, 06:06 AM   #4
GH41
Oddometer: 822
The manual probably says side stand because the center stand is not standard equipment. I do mine on the center stand. It is all but impossible to find the tight spot any other way. All bikes will not be the same but the tight spot on mine is a half inch tighter than the loose spot. GH
GH41 is offline   Reply With Quote
Old 10-14-2012, 06:14 AM   #5
JRP
Old guy
JRP's Avatar
Oddometer: 1,514
The tightest spot is when the rear axle, swing arm pivot point and counter shaft sprocket are all in a line. Achieve that anyway you like.
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 10-14-2012, 07:59 AM   #6
maigashi OP
maigashi's Avatar
Oddometer: 117
How tight should the chain be at the tightest spot
Old 10-14-2012, 10:00 AM   #7
JRP
Old guy
JRP's Avatar
Oddometer: 1,514
30-40 mm with motorcycle on the side stand, this just about lines up those three points, if the bike is heavily loaded or on the center stand I would go closer to the 40 mm
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
Old 10-14-2012, 11:46 AM   #8
LukasM
Oddometer: 5,418
Yeah, buts chain don't always wear evenly so you should check for the tightest spot along it's entire length, too.
Old 10-14-2012, 12:00 PM   #9
Endurodude
Endurodude's Avatar
Oddometer: 177
The correct way is probably to check tension over various parts of the chain. Personally, I have the bike on the side stand (even though I do have a centre stand) and tighten it until it touches the swing arm. That seems to correspond to the correct chain tension suggested in the manual. I do this unloaded.
Endurodude is offline   Reply With Quote
Old 10-14-2012, 02:23 PM   #10
GH41
Oddometer: 822
JRP, you are missing something. When they say adjust at the tightest spot they mean to locate the tightest spot by rotating the wheel and checking the slack in the chain. The spot with the least slack is the tightest spot. Remember that a hot chain will be tighter than a cold chain. I you are not sure or unable to find the tight spot I would adjust to the long side of the recommended range. GH
Old 10-14-2012, 02:47 PM   #11
CheckerdD
CheckerdD's Avatar
Oddometer: 1,286
Put it on the sidestand with the bike in Neutral. I have a clear plastic ruler where I have taped the limit which is 35-45 mm between top and bottom without yanking the chain. I also loosen the axel nut so it slides more easily. I then loosen the lock nuts and take one turn up or down till the wrench stops against the top or bottom (actually only a quarter turn), each side till it comes within specification and retighten the lock nuts and axel nut - 100 ft pounds torque. And recheck to see if it's still within 35-45 mm. Note I stop adjusting as soon as I show I am within the limit. Usually I am a mm or 2 of 40. If you try to get it to an exact number of mm's you will go nucking futs. After that move the chain up and down with your hand to get a feeling where the right spot is without measuring. As pointed out by others it's looser than you think and about where the chain hits the swingarm. . It's better to err on the side of too loose rather than too tight.
You will see that you need to adjust very little untill the chain is starting to age then you might move it as much as an 1/8 th to 1/4 of an inch. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD screwed with this post 10-14-2012 at 03:40 PM
CheckerdD is offline   Reply With Quote
Old 10-14-2012, 11:39 PM   #12
JRP
Old guy
JRP's Avatar
Oddometer: 1,514
I'm not missing anything, I simply said that is the spot where the chain will be tightest , if the axle moves up or down from that point the chain will get looser.
Adjust it anywhere you like (manual says on the side stand) just make sure you have at least some play where ever the chain is tightest. And yes, turn the wheel to check for tight places in the chain itself.
This is not rocket science
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
Old 10-15-2012, 04:51 AM   #13
Steveman
Steveman's Avatar
Oddometer: 471
How comes?
BTW, having a center stand and not using it seems a bit weird, but well you will know why. My personal hint, use the center stand if you have one and adjust as loose as possible while being inside the given limit or even a fraction out of limit..
Most people tend to adjust to tight.
Another hint: before tightening the nut of rear axel slide a big screw driver between chain and sprocket and push the wheel forward with force, jam the screw driver between chain and sprocket. In this position push the brake pedal and tighten the nut of the rear axle. This procedure ensures that when you tighten the nut you wont pull the rear axel away form the tension screws/tension brackets and the chain tension does not change after tightening the rear axle/nut.
Steveman is offline   Reply With Quote
Old 10-19-2012, 12:21 PM   #14
picard
engage!
picard's Avatar
Oddometer: 1,280
I respectfully disagree.
The chain will be tighter on the side stand than on the center stand because on the side stand the drive gear is closer to the line-up position between sprockets and the swingarm pivot. If you adjust looser than spec while the bike is on the center stand your chain will be too loose.
Under load (esp. heavy) while riding the chain will often be looser than when the bike is on the side stand because your suspension is compressed and the swingarm is beyond the line-up point (hope that makes sense).
"Rumors of my assimilation are greatly exaggerated." (Capt. Picard)
picard is offline   Reply With Quote
Old 10-19-2012, 01:15 PM   #15
GH41
Oddometer: 822
With my normal load in the Jessie side and Vario top case my suspension is not compressed at all on the side sand. I agree that the geometry change when the swing arm moves is real but with the center to center difference of only 3 1/4" between the sprocket and swing arm pivot the change is minimal. Not enough to matter how the bike is propped up when adjusting the chain. Lets just agree to disagree. GH
Times are GMT -7.   It's 03:42 PM.
