Old 12-25-2010, 02:51 PM   #1
maybilcatchfire OP
maybilcatchfire's Avatar
Oddometer: 75
I NEED HELP.. F800 touratech skid install
So i got this skid plate for christmas and i keep trying to take the rubber mount off to install the ones that are given to you by touratech and i cant get them off. I tried heating them up and they still wont move..
Hope some one can help me soon
maybilcatchfire is offline   Reply With Quote
Old 12-25-2010, 04:18 PM   #2
Bayner
Oddometer: 1,523
Shucks, I don't know what to say? Mine were easy to remove...
Bayner is offline   Reply With Quote
Old 12-26-2010, 02:38 PM   #3
Tor
Native Viking
Tor's Avatar
Oddometer: 803
Try using a deep socket on the rubber dampers. You need to reach all the way up to get them, because they are divided, with rubber in the middle. You need to be able to reach all the way up against the bottom of the engine. I assume you got the old plate off already....
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 12-26-2010, 04:21 PM   #4
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 752
When I removed a friends original plate, the bolts came out of the oil pan.
Not to worry... I just used opposing wrenches and got the original bolts off. I don't recommend using heat, due to the rubber.
Good luck.
Cheers,
S.
"Death in the pursuit of happiness is triumphant!"
rediRrakaD is offline   Reply With Quote
Old 12-26-2010, 08:41 PM   #5
maybilcatchfire OP
Oddometer: 75
thanks for the help I got them off by just turning them until it snapped off. its just odd you have to pretty much twist the rubber 360 degrees. The whole time i was scared I would tear the rubber off but that wasn't the case. Thanks for the tips though
Old 10-12-2012, 04:56 PM   #6
Hayate
ADV Monkey
Hayate's Avatar
Oddometer: 59
Same here, I couldn't believe that they just kept on going further and further before it budged at all. I was sure I was going to twist that rubber into breaking.
ad·ven·ture 1.an exciting or very unusual experience.
W
hat a great 40,000 mile adventure on the trusty F800GS. Looking forward to the next 40k.
Minnesota Parallel "Twin" Cities GS Riders
Daniel Betlock Adventure Rider
Hayate is offline   Reply With Quote
Old 10-13-2012, 03:42 AM   #7
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,612
Happy you managed to get them off... but why do you open your present 10 month later or 2 month before the actual fest.
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road – One month to find the rising sun
Loutre is offline   Reply With Quote
Old 10-13-2012, 07:40 PM   #8
C-Stain
C-Stain's Avatar
Oddometer: 5,956
Check the date of the original post...
Originally Posted by Mr_Gone View Post
C-Stain is wise.
C-Stain is offline   Reply With Quote
Old 10-14-2012, 11:43 AM   #9
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,612
darn my bad. I read 12/10 or like you would read it 10/12
Times are GMT -7.   It's 05:31 PM.
