Old 12-02-2012, 08:53 PM   #31
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,342
Check out Russell filters:
I am looking at using one of these but only 40 micron size filters.
http://www.russellperformance.com/mc...ers-comp.shtml
I think we need 10 micron which they have in the other series of filters but they are larger.
You can buy barbed 1/4" x NTP fittings for each end.
But the larger Pro filters are hard to tuck away due to size:
http://www.russellperformance.com/mc...ters-pro.shtml
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 12-02-2012 at 10:39 PM
Indy Unlimited is offline   Reply With Quote
Old 12-03-2012, 09:31 AM   #32
C5!
Oddometer: 275
somebody had posted this, but expensive
Mini and Super Mini Reusable Filters
Form and function
After success with our first fuel filter, we at GS Performance made a decision to manufacture new fuel filters for the High Performance Motorcycle and Go Kart Industries, and today we have the best billet, stainless steel, washable, reusable and performance fuel filters in those two industries.
Filter Element: Designed and engineered for the aerospace industry, for rugged, high temperatures, and extreme filtration environments, made of pleated, 304 stainless steel, 10 micron (.000392"), 1.000 Diameter. Totaling four square inches of effective filtration area, mini/super mini filter provides a maximum flow of 6 gallons per minute simultaneously with no restriction. Filter elements are washable and reusable indefinitely, cleaned easily with air or soluble rinse.
Bodies: Machined on CNC from 6061 aluminum, chrome plated or clear bright anodize finish.
Specification:
Mini Fuel Filter Part Numbers
60-04AN 4-AN Fittings
60-06AN 6-AN Fittings
60-250C 1/4 Barbed Fittings
60-312C 5/16 Barbed Fittings
60-375C 3/8 Barbed Fittings
Super Mini Fuel Filter Part Numbers
70-250G 1/4 Barbed Fittings
70-312G 5/16 Barbed Fittings
Length: Mini: 1.500" long, not include Barbed Ends.
Super mini: 0.675" long long, not include Barbed Ends
Diameter Mini and Super Mini: 1.375"
Weight: Mini: 1.5 Ounces / Super mini: 1 Ounce
Sizes in barbed: Mini: 0.312" (5/16), 0.375" (3/8)
Super mini: 0.250" (1/4), 0.312 (5/16)
Sizes in AN fittings: Mini only: 4-AN, 6-AN, 8-AN
http://www.golanproducts.com/filters.html
C5! is offline   Reply With Quote
Old 12-03-2012, 02:05 PM   #33
C5!
Oddometer: 275
I also found that one
http://www.jpcycles.com/product/7200330
the sales tech on chat told me it is good for 50 psi and it is approx 10 microns...
for $6.99 I'll try that
Old 12-03-2012, 05:10 PM   #34
ebrabaek
Oddometer: 4,728
That sounds intriguing.... It would be great if you could doc. the install, as this is a great price....
Erling
Old 12-03-2012, 05:45 PM   #35
JRWooden
Oddometer: 4,249
replacing comments ....
JRWooden screwed with this post 12-04-2012 at 07:45 AM
Old 12-03-2012, 09:00 PM   #36
Indy Unlimited
Oddometer: 1,342
That JPCycles product is made by Russell Peformance and they are for carbed bikes only! Beware!!! See manufacturers web site and they have other models for fuel injection filters. These small ones are not made to handle 50 psi:
http://www.russellperformance.com/mc...s-street.shtml
On another note we can make these work from Russell and they only have a 40 micron filter option:
I can't find any 10 micron 50 psi rated compact fuel filters!
Current Stable:
Old 12-04-2012, 07:51 AM   #37
JRWooden
Oddometer: 4,249
Looks like maybe the Holley will do the trick - see page 5 #162-550
1.5" diameter x 3.5" long...
Rated as post filter for EFI systems with replaceable filter... ???
http://www.holley.com/162-550.asp
or
http://www.summitracing.com/parts/hly-162-550/overview/
Old 12-05-2012, 05:28 AM   #38
jttele
jttele's Avatar
Oddometer: 253
or
This Holley filter does look like the best option I've seen so far. As long as you can get 1/4" barbed fittings for each end. Guess I'll try a search for "3/8"NPT to 1/4" barb", and see where that gets me.
Jttele
jttele is offline   Reply With Quote
Old 12-05-2012, 05:37 AM   #39
Indy Unlimited
Oddometer: 1,342
Thanks JRWooden! Great find. I will go with the Holly for a compact 10 micron EFI fuel filter. Barbed fittings for 3/8" NPT are very common. Nice replaceable filter and o-ring system as well.
I think I can also fit one on my berg as well.
Current Stable:
Indy Unlimited screwed with this post 12-05-2012 at 05:50 AM
Old 12-05-2012, 07:24 AM   #40
JRWooden
Oddometer: 4,249
No problem glad I thought to check there....
I don't have any troubles yet ... but have long long ride planned for in the spring ....
I'm starting to compile the list of crap I should do before I leave .... at 30K miles I'm wondering if
"ripping out OEM filter and installing the Holley should be on the list ..... "
I never hear of folks having to replace FI-fuel-filters on cars ...
even after 10 times the volume of gas has gone through them that we use ...
HAS ANYONE ACTUALLY CUT OPEN ONE OF THE OEM UNITS?
It looks plenty big in terms of "loading capacity" but maybe its just a small crappy filter in a big can?
Old 12-05-2012, 07:36 AM   #41
toro618
toro618's Avatar
Oddometer: 976
http://www.petersonfluidsys.com/filters.html
Peterson makes good filters also.
toro618 is offline   Reply With Quote
Old 12-05-2012, 08:20 AM   #42
TowPro
Lets ride
Oddometer: 3,168
They look good, but none are rated near 10 micron on the page posted.
I think my approach will be to wait until the problem first shows up, then switch to external hoping my pump survived the blockage.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 12-05-2012, 04:35 PM   #43
Bayner
Oddometer: 1,561
I'd say about half of the cars coming into the shop still have fuel filters and they usually require replacement after around 20k miles... it's amazing the crap that collects in them.
Certainly not as many are equipped with filters as 10 years ago so maybe you don't hear about it much because there are less filters out there?
Bayner is offline   Reply With Quote
Old 12-05-2012, 07:00 PM   #44
JRWooden
Oddometer: 4,249
Bayner:
20K miles??? wow....
No argument ... I really don't know ...
I can say that I have a 2003 FI Toyota Highlander with 120K miles on it, and a 1986 Toyota Supra with 140K miles on it both have the original filters ... I know only because I bought them both new myself and they never go to any garage but mine ....
I'm sure fuel quality varies a lot from place to place ...
I may just be blessed by living in a relatively trouble free area....
For my bike I think I'll go with TowPro's approach and hope I don't burn out the pump!
JRWooden screwed with this post 12-05-2012 at 07:18 PM
Old 12-05-2012, 07:31 PM   #45
Indy Unlimited
Oddometer: 1,342
Lets not forget where the crap is coming from.
The stock fuel lines and stock fuel pump is a major contributor to the crap in our stock filters.
Current Stable:
Times are GMT -7.   It's 11:43 PM.
