Old 10-16-2012, 10:53 AM   #1
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,350
640 FCR 37 install
After reading a few positive posts on running an FCR 37 in place of the BST I decided it was worth a try so I picked out one out of the many listed on EBAY... The one I ended up with came from a 05/06 RMZ 250 and had all the cables and the twist grip... The box showed up in the mail and upon first inspection the carb looked to be in good shape... This particular carb had the usual enricher circuit but was equipped with a hot start circuit as well...The slide looked good with not to much wear showing so I cycled the throttle cam, as the slide lifted out came a shot of rotten smelling fuel from the A.P. nozzle... I was thinking, wow this guy mailed out the carb and did not even empty out the crappy fuel, at least I know the A.P. is working... I then pulled the float bowl and noticed that there was quite a bit of rotten fuel varnish coating the inner workings so I ordered up a rebuild kit... The throttle cable also looked a bit pooched so one for an SXC is on the way...
The first thing I noticed when comparing is the bell to bell measurement on the FCR is about 15-20mm shorter than on the BST..
Also the FCR has a smaller air box end Bell
I did some measuring and found that I could make an adapter piece out of some 2 1/4" SS exhaust pipe...
Very close to the size required with a bit of work...
I ground the lip off the airbox bell end of the FCR and tested my sample adapter piece...
With some persuasion I figured it would fit so I coated the bell with 648 retaining compound...
I then heated the piece to expand it and persuaded it on with the help of a block of wood and a hammer... This proved to be a very tight fit, so much so that it will have to be cut off with a dremmel if I ever have to remove it...
I then measured the final product FCR against the BST
And see that to be perfect, I could of left a couple more MMs length on my adapter... Oh well, the slightly shorter length will make it a bit easier to install the carb when the time comes...
Next up will be to clean out the carb and install the rebuild components when they arrive....
I will also have to figure out what jetting to go with to fit my setup... I would imagine I could go with something similar to what guys are using on the FCR 39s for starters... I really don't care so much about increases in top end performance as I do about the bottom end trail power... I am hoping to get a little more front end lofting snap out of this carb to help when bouncing small logs, rocks, roots and other trail obstacles... I would like to tune this in leaving the snorkel and airbox intact therefore keeping with the water tight integrity of the original design...
f
gunnerbuck is offline   Reply With Quote
Old 10-16-2012, 01:11 PM   #2
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 10-16-2012, 05:43 PM   #3
bmwktmbill
Traveler
Oddometer: 5,218
Originally Posted by ChrisC View Post
Ditto.
I wait in amazement.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 10-16-2012, 06:59 PM   #4
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,350
I'll get back on this in a few days when my parts show up....
Does anyone have some jetting #s that they are using in a 39 for comparison? I haven't looked at the #s of whats in the carb right now but looking at the Suzuki parts data it lists a 178main, 42 idle pilot, 100 idle air, #68 starter,#60 power as stock for this carb....
Old 11-03-2012, 02:04 PM   #5
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,544
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 11-03-2012, 02:55 PM   #6
smokeeater495
smokeeater495's Avatar
Oddometer: 605
I hope your homebuilt spacer works for you. I read a test where a guy put an FCR39 on his XR650L with an exhaust pipe adapter and it ran like crap. Google "Noss adapter". It attaches to the intake side of the carb and provides a smooth transition. The 37mm carb should have awesome low end snap.
Harley, been there done that. Don't want to be a pirate.
smokeeater495 is offline   Reply With Quote
Old 11-03-2012, 05:15 PM   #7
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,350
Parts
After a bit of a wait the parts showed up yesterday...
I paid about $33 shipped for the longer cables and around $28 for the carb kit..
I was pleased to see new jets in the kit with the main being a #162 VS a #178 that came with the carb....
The big thing is to try to figure out a starting point for the jetting, the #162 may be ok as I think the SXC runs the next size up on a FCR 41...
The jetting info I pick up on line is not very use full as most people that swap carbs also gut the airbox and add a more open exhaust.. So I'm kinda going by trial and error with this thing...
Old 11-03-2012, 05:29 PM   #8
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,350
Part of the XR 650 guys problem could of being getting the pipe to properly seal... I pressed mine on with retaining compound and once I get the thing fully cleaned up I will add a bead of sealant around the pressed on rim just to make sure air can't leak in...
I was going to get my machinist friend to make me up an adapter but he was busy at the time so I figured I would try the SS pipe for a start... Even without the adapter the FCR has quite an abrupt entrance into the bell... The SS pipe really doesn't change anything with that except adding a longer throat to the airbox... If it turns out to run poorly I'll think about adding a stabilizing vane to the throat...
gunnerbuck screwed with this post 11-03-2012 at 05:58 PM
Old 11-03-2012, 11:08 PM   #9
johnno950
Oddometer: 1,076
I had a lc4 with a 39mm fcr (carb from a jap bike),the bell could be ordered from ktm to fit the carby,if the 37mm is the same as 39mm, have a look at the part numbers from a 00-06 ktm 660 rallye.
johnno950 is offline   Reply With Quote
Old 11-04-2012, 01:18 AM   #10
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,350
Some of the FCR 37s have a bolt on bell that can be changed and some don't... This carb is not the bolt on bell type...
gunnerbuck screwed with this post 11-04-2012 at 10:04 AM
Old 11-04-2012, 09:54 AM   #11
Droptarotter
Oddometer: 1,303
You were working on that late last night Gunner!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 11-04-2012, 10:06 AM   #12
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,350
Cheers
Must of been half asleep too looking at my last post..
Old 11-04-2012, 03:32 PM   #13
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,350
Carb Clean up
I'm still waiting for an extended mixture screw which I hope shows up tomorrow, in the meantime I started the tear down and clean up of the carb...
There was quite a bit of varnish inside and the power jet was completely clogged and needed the help of a piece of wire to clear it..
Still a bit of varnish showing but most of it came off with carb cleaner and a tooth brush scrub...
My part comparison chart, new VS old...
Now to figure out which combo to use upon assembly to be in the ballpark... I think the 162 main may be a better choice over the 178, I'll use the 42 pilot... The SXC runs a 85 starter jet so we'll see if the 68 will be big enough... The power {leak} jet is a bypass jet so the smaller the # the more fuel goes into the A.P. , I will go with the #55 for starters...
I dont know what this needle is for but it is way off for this application...
f
gunnerbuck screwed with this post 11-04-2012 at 07:29 PM
Old 11-08-2012, 09:38 PM   #14
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,350
Mounting it on the Bike...
The other day I put a thick bead of sealant around my adapter to make sure no air could leak in and now it was dry... I rigged some vent hoses...
I found and soldered on a male TPS plug that fits the FCRs port so that made it simple..
I rigged a bridge vent to eliminate 2 of the 4 hoses and then ran one tube to the airbox and the other down behind the swingarm..
It was a tight fit and I had to jockey around some hoses... I got everything hooked up and then rolled the bike out to give it a test with a remote tank...
After about half a dozen cranks to advance the fuel she fired up in a startling fashion...
The good news is that it runs great at over 5000 RPM but the bad news is: I was unable to test the bottom end power because the revs wouldn't drop below that... I called it quits after that... Next I'll have to see where the fuel is leaking in from to give it the high revs, likely the slide is sticking and not bottoming...
f
Old 11-09-2012, 03:01 AM   #15
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 2,001
An FCR on a 640 would be fun fun fun. Maybe fire off a message or call Motolab. He might have some jetting suggestions, or even JDjetting. To me a 162 main at sea level sounds lean for the air a 625cc pumps through
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Times are GMT -7.   It's 04:18 PM.
