Old 10-16-2012, 07:34 PM   #1
wiznas OP
Oddometer: 18
Broken Turn Signal Switch - '83 R65
Hey all, I've been an airhead owner for about 4 blissful days, got my first little problem to work out. Previous owner is supposed to send me the Haynes manual but I have yet to see it. Any wisdom would be greatly appreciated, trying to get it inspected and registered asap.
The problem is I sheared off part of the electronic switch inside, so now the lever your thumb uses can't grab the sliding contact switch. You can see the broken piece and where it goes in the picture.
https://picasaweb.google.com/1179483...99698398196770
Is there a way to remove just this brown plastic piece? If so I could maybe make another one, or I could replace just that piece if there was a place that sold them. I only saw the complete assemblies (lights, horn, signals) for 100 bucks or so. ouch.
Tomorrow I'll try drilling a small hole and inserting a machine screw to take the place of the broken nib. But replacing the whole shabang would be ideal, this plastic is old and brittle.
Thanks for any input!
wiznas is offline   Reply With Quote
Old 10-16-2012, 07:37 PM   #2
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,552
I mad my own switxhes for 20 bucks. Left a.d right indicators separate. Not pretty but works and cozts 5 dollars to replace.
Uncle Pollo is offline   Reply With Quote
Old 10-17-2012, 04:32 AM   #3
ME 109
ME 109's Avatar
Oddometer: 3,151
Get a new one, or a s/hand one.
Fix it today.........fix it next week...........and the week after......etc, etc.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 10-17-2012, 10:13 AM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,282
Your link didn't work for me, so I can't suggest a fix. But I'll bet there's a way to make it work.
From your description I don't really understand what broke. There's the whole switch assembly, and out of the front there's a flat metal post that swivels for the signals, with a plastic piece screwed to it. Did the plastic end break off?
Or did the metal piece break off or come out?
Old 10-19-2012, 03:17 PM   #5
wiznas OP
Oddometer: 18
Link modified,
https://picasaweb.google.com/1179483...COn7lc3zrJadXg
yes the plastic sliding piece broke (which the lever comes in contact with). I couldnt figure out a way to save or rebuild the plastic piece without worrying about it breaking again, so I soldered on two switches instead. A bit rough looking but it'll hold me til I can afford a new switch cluster.
wiznas screwed with this post 10-19-2012 at 03:39 PM
Old 10-19-2012, 08:43 PM   #6
Wirespokes
Wirespokes's Avatar
Oddometer: 8,282
I'd have tried super glue to replace that nub.
As for the toggles, you know - a double pole toggle would have eliminated the need for two switches. Three positions - wire it so you've got left, off, and right.
Old 10-20-2012, 05:05 AM   #7
Uncle Pollo
happy cachiporra
Oddometer: 48,552
Originally Posted by wiznas View Post
Link modified,
make a tab out of aluminum and hang the switches from the instrument cluster screw , between the handlebar assembly and the cover.
That is what I have .... no one can see them and they are easy to get to.
Old 10-21-2012, 01:44 PM   #8
wiznas OP
Oddometer: 18
Spokes, I first bought a 3 way switch to do a cleaner solution, but after playing with it a little, there just wasnt enough travel to make it user friendly, I kept skipping over the middle stop. There's a good bit of pressure on those nubs, superglue was tempting and might have worked but I was worried about it popping far from home.
Pollo, that's a good idea to have them outside, it's pretty cramped in under that cluster with my new switches.
Thanks for all the advice!
Old 10-28-2012, 04:12 AM   #9
Pharoah
Grouchy Smurf
Pharoah's Avatar
Oddometer: 24
I had the same part break on my R80 this summer when I had my little incident. I was able to crazy glue it together and so far no problems.
Pharoah is offline   Reply With Quote
Times are GMT -7.   It's 05:56 PM.
