Old 02-25-2009, 08:40 AM   #1
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
F800GS front brake rotors.
Has anyone put different aftermarket rotors on the front wheel? Like the Wunderlich ones? If so, did it "quiet things up" on the front of the bike?
After re-torquing my steering head bearings, the noise and loose feeling that I was constantly complaining about went away for the most part. I still have a bit of a clack/chatter noise in the front when I hit rough spots in the road. The floating rotors on this bike are VERY loose. I'm assuming that they are the culprit. The ones that Wunderlich sells are non-floating. So I was wondering if anyone has any experience with them. Thanks!
The Griz screwed with this post 02-25-2009 at 08:52 AM
Old 02-25-2009, 11:51 AM   #2
tmex
tmex's Avatar
Oddometer: 2,039
I cannot find the Wunderlich rotors for the F800GS. Can you provide a link?
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 02-25-2009, 01:24 PM   #3
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
http://www.wunderlich.de/frame.php?M...prodid=8130021
http://www.wunderlichamerica.com/mm5...w=&range_high=
Old 02-25-2009, 04:21 PM   #4
LarryC
LarryC's Avatar
Oddometer: 21
Can you tell me what the torque specs are for the caliper bolts? I ordered my F800GS Manual but have been told it is back ordered 2 months. Thanks in advance
LarryC is offline   Reply With Quote
Old 02-25-2009, 04:26 PM   #5
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
I'm not sure. I don't have a service manual either.
Old 02-25-2009, 04:27 PM   #6
tmex
tmex's Avatar
Oddometer: 2,039
Larry, the caliper bolt torque specs are in the owner's manual. I cannot recall what the value is off hand, so you best look it up or wait for someone else. I did find it in the manual, however.
Old 02-25-2009, 04:38 PM   #7
tmex
tmex's Avatar
Oddometer: 2,039
The rotor in the picture is not mounted on an F800GS. A give away is the caliper bolts which are female. The caliper bolts on the F800GS are male. I do not know what bike that is, but it is not an F800GS. I do not think Wunderlich sells rotors for the F800GS.
My F800GS caliper below:
Caliper picture from your reference:
tmex screwed with this post 02-25-2009 at 04:44 PM
Old 02-25-2009, 04:39 PM   #8
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Seek, and ye shall find.
Ask, and it shall be given to you.
http://f800riders.org/HoW/showentry....s&searchid=639
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 02-25-2009, 04:54 PM   #9
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Then why would Wunderlich have them on their site listed under F800GS? I know for sure that Lucas (out of France) makes them for the F650/F800GS twins and Wunderlich sells them. I called Wunderlich-USA. Those female bolts you see on there were probably just replaced by the Wunderlich staff who installed the rotors. Or maybe those are the bolts they used by BMW for a while. Just because a couple of bolts look a little different doesn't mean that it's not an F800GS. In fact, I know for sure that it's an F800GS because no other bike's fork protector, axle, and fender connection looks like that. It's unique to the F800GS.
P.S. You'll also notice the Wunderlich neoprene fork gaiters on there!
P.S.S. Wunderlich-America doesn't stock them. They have to order them from Germany, which is why it takes 2-3 weeks to ship.
Old 02-25-2009, 05:17 PM   #10
tmex
tmex's Avatar
Oddometer: 2,039
OK. The only reason I was doubtful is that I was simply not able to find a proof positive English reference to their availability. The price is certainly reasonable, and might justify a switch if you tweaked an OEM rotor not to mention that you would wait longer than a few weeks replacing any major OEM part on an F8.
I do believe you are correct in the source of the clack. You can prove this by riding the same set of bumps with and without the front brake lightly applied. Short of the clacking, I prefer the floating rotors, but the rigidly mounted rotors might well dissipate heat better.
Old 02-27-2009, 10:11 AM   #11
Motomantra
Registered Lurker
Motomantra's Avatar
Oddometer: 1,346
The rotors are less apt to warp due to heat if they are allowed to float. Even the rotors on my 9 will make some noise.
Not trying to change your mind, or be a smart ass, just wondering if you've considered this.
For those that fight for it, freedom has a flavor the protected will never know.
Motomantra is offline   Reply With Quote
Old 02-27-2009, 10:32 AM   #12
RedHawk47
RedHawk47's Avatar
Oddometer: 448
Bolts
The caliper bolts on my F800GS are Torx socket heads as shown in the second photo. (what you referred to as female)
Dan
It's never too late to have a happy childhood. -- Tom Robbins
13 Moto Guzzi Stelvio NTX
09 BMW F800GS
99 KLR 650 A13
RedHawk47 is offline   Reply With Quote
Old 02-27-2009, 10:35 AM   #13
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
An Ipod may cure your problems.
johngil is offline   Reply With Quote
Old 02-27-2009, 11:00 AM   #14
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Very true!
Old 02-27-2009, 12:08 PM   #15
Bike4Fun
Smooth IS Fast
Bike4Fun's Avatar
Oddometer: 1,768
Yeah for ever since it will quickly lead to you taking a dirt nap!
just my .02
Bike4Fun is offline   Reply With Quote
Times are GMT -7.   It's 01:23 AM.
